Justify the number of significant figures for x
In summary: If the 0.6... is not an exact number, then x would only have the number of sig figs that the sig fig rules allow. So in this case, x would have 2 sig figs.
koat
40
hi we did an experiment at school and in my homework i am asked to justify the number of significant figures for x.
what do they mean with justify here? i don't understand the question.
my x value has 3 s.f.
thanks in advance
If your x value is a product or sum of different numbers, then it can only contain a certain amount of significant figures, and you can't justify any more than that. So if in your experiment you ended up multiplying 2.13 by 4.17, your calculator gives an answer of 8.8821, but per the sig fig rule, you can only justify the answer to 3 sig figs, so the answer is 8.88. Is that what you mean for your 'x' value?
thanks but that's not actually what i mean with my x- value.
the x value was an unknown in an equation and i had to work out this x value.
it represents the mass of a mug.
then after i have made the x value the subject of my equation they ask me that question which i have written in my first post.
what do i have to do?
and what does justify mean in this context?
Yes, I think that is the example of what i said.. Please show the equation that you used to solve for x. You said that x had 3 sig figures...does it?? You can only justify as many sig figures in your answer as sig fig rules allow. If y = zx, then x =y/z, and if y is 2.42 and z is 1.23, then the answer for x is 1.97, not 1.96747967..., because there are only 3 sig figures in the values of y and z, and therefore x can only have 3 sig figures, not a whole bunch of them. Am I understanding your question correctly?
Oh I think I understand .
But say the equation was y=0.6zx
so x= y/0.6z
x and y are given to 3 s.f
But the 0.6 is just given to 1 s.f.
will x still have 3 s.f. or does the 0.6 affect the number of s.f of x?
When multiplying or dividing, the answer is only as good as the number of the least significant digits of any numbers in the problem. Since 0.6 has only 1 sig fig, then the answer can only have one sig figure. Unless the '0.6' is an exact known number. As for example how much is 9 times 9...you can't say 80 , which is correct to one sig fig, or you'll flunk 2nd grade. But if you weighed something by experiment and it weighed 9 N, then 9 of those somethings would weigh 80 N. If you weighed it at 9.0 N, then 9 of them weigh 81 N. Sig fig rules get confusing.
but in my equation the 0.6 is an exact known number and all the other numbers are measured to3 sf
how about now?
how about now?
Then the answer should have 3 significant figures.
sorry to ask again but is it right what I have understood so far.
When I 've got y=0.6zx then you get x=y/0.6z
At school we measured y and z to 3 sf. So does it mean that 0.6 is kind of a constant value and it doesn't affect the value of x which I am trying to work out? Because I didn't work out 0.6. This was the only number given in the equation but the other numbers which I have plugged into the equation are measured values.
So does x also have 3 sf then?
Can you explain that again please. I am slightly confused.
Thanks in advance
Thanks in advance
Yes, if the 0.6 is an exact known number, it theoretically has an infinite number of significant digits, that is, you can call it 0.6000000000000000000. In multiplying or dividing, the result can have only as many significant figures as the least number of significant values in any number used in the problem, so that in your case, x must have 3 significant figures. As an example, if y = 1.23 (3 sig figures) and z = 0.629 (3 significant figures), then x = y/0.6z = 1.23/0.6(.629) = 3.26 (3 sig figs). The real difficulty is in determing the number of sig figs in a number, for sample, if experimentaly, one value is 0.002 (1 significant figure) and the other value is 0.111 (3 sig figures), and you wanted to multiply them together, then the answer is (.002)(.111) = 0.0002 (which has 1 sig fig), not 0.000222, which would have 3 sig figs, which is too many to use. Confusing.
When you say 0.6 is an exact known number is that the same as saying it's a constant?
And are you trying to tell me that a constant doesn't affect the final result ?
Am i right?
If I would have this example:
(0.333)(0.550)/0.2
where 0.2 is the value already given in the equation( so a constant?) and 0.333 and 0.550 are measured values. Is the answer going to have 3 sf?
Am i right?
(0.333)(0.550)/0.2
Yes, correct, as long as the constant that is given to you is an exact known number. Sometimes the number 'pi' is given to you as 3.14 even though its value is 3.14159... .
Thus, if you were asked to calculate the circumference of a circle (C = pi(diameter)) having a measured diameter of 123.4 units (4 sig figures), and the problem said use pi= 3.14 (which has 3 sig figs), then the answer is C = 387 units (3 sig figs). But if it said calculate the circumference of the circle but did not put an approximation on pi, then C = 387.7 units.
Ok I understand what you are saying but can you also answer the last bit of my question with the calculation please :)
And does 0.550 actually have 2 or 3 sf?
And how do I know that 0.2 is an exact known number- this value is just given in the equation ?
thanks
yes, the ans has 3 sig figs
it has 3. The number 0.005 has 1. Google on 'significant figures'.
thanks
You don't know for sure unless you can identify it as such or were given it as such. For example, the area of a right triangle is 0.5(b)(h). The 0.5 is exact in this example.
Related to Justify the number of significant figures for x
1. How do you determine the number of significant figures for a measurement?
The number of significant figures in a measurement is determined by counting all the digits that are known with certainty, plus one estimated digit.
2. Why is it important to use the correct number of significant figures?
Using the correct number of significant figures ensures that your measurement is as precise and accurate as possible. It also helps to maintain consistency and avoid misleading results.
3. Can you explain the concept of significant figures?
Significant figures represent the digits in a number that are known with certainty, plus one estimated digit. They indicate the precision or accuracy of a measurement.
4. How do you round a number to the correct number of significant figures?
To round a number to the correct number of significant figures, start from the leftmost significant figure and work your way to the right. If the first digit to be dropped is 5 or greater, round up the last digit. If it is less than 5, leave the last digit as is.
5. Can you give an example of using significant figures in a calculation?
Sure, let's say we are calculating the volume of a cube with sides of 2.34 cm. The volume would be 2.34 cm x 2.34 cm x 2.34 cm = 12.213504 cm^3. However, since 2.34 only has 3 significant figures, the final answer should be rounded to 12.2 cm^3.
