Calculating Video Recording Capability of 4500 ft Object w/ Camcorder
  • Thread starter Max CR
  • Tags
    Video
In summary: The video camera will be able to record the object, but it will only be able to capture footage at a resolution of 380 Kpix.
Max CR
121
I am working on this as an outside of school project.
An object is 4500 feet away from the video camera. Will my video camera be able to video record it? I have no idea how to calculate this, and I seriously need some help in understanding this. Please include any math equations you use to figure this out since I need to do this again with other cameras.
Object specifications:
3.5 inches by 65.5 inches
Camera specifications:
42X optical zoom lens
Camcorder Sensor Resolution 800 Kpix
Camcorder Effective Video Resolution 380 Kpix
Camcorder Effective Still Resolution 0.3 Mpix
Optical Sensor Type CCD
Optical Sensor Size 1/6"
Min Illumination 2 lux
Digital Zoom 2000 x
Max Shutter Speed 1/8000 sec
Min Shutter Speed 1/30 sec
Image Storage JPEG 640 x 480 ¦ JPEG 640 x 360
Type Zoom lens - 1.8 mm - 75.6 mm - f/1.9-4.3
Focal Length 1.8 mm - 75.6 mm
Focus Adjustment Automatic, manual
Lens Aperture F/1.9-4.3
Optical Zoom 42 x
Zoom Adjustment Motorized drive
Features Built-in lens shield
Low Lux / Night Mode Yes
Digital Still Camera Function Yes
Type LCD display - TFT active matrix - 2.7" - color
Display Form Factor Rotating
Display Format 123,200 pixels
The link where I got this information is at:
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A1538817&cs=19&c=us&l=en&dgc=SS&cid=27530&lid=627063
What do you mean be able to record it? How small is the object? If it's a mountain, I don't think you'll have a problem...
Honestly, this is one of those things you can VERY easily determine experimentally. Calculations are all well and good but nothing beats actually seeing the result.
Here's how: take a video of an object of known size (such as a ruler) at a known distance, then count how many pixels across it is. Use trigonometry to calculate the resolution in arcsec per pixel, then compare that resolution to the angular size of the object provided by Jeff.
What do you mean by "Use trigonometry to calculate the resolution in arcsec per pixel, then compare that resolution to the angular size of the object provided by Jeff." This is where I got lost.
THanks to everyone else. I have read your posts.
Jeff Reid said:
You can calculate the subtended angle of the 3.5 inch (3.5 / 12 foot) width:
http://en.wikipedia.org/wiki/Visual_angle
In this case, angle = tan-1(3.5 / (2 x 12 x 4500)) = .001857 degrees, not much.
Where did you get these numbers and formaulas from? Please show your work. Thanks
Max CR said:
Where did you get these numbers and formulas from?
From the wiki article. Imagine a right triangle where the hypotenuse goes from the lens to one edge of the 3.5 inch wide object. The adjacent side is the distance from the lens to the center of the object, and the opposite side is goes from the center of the object to the edge, or 1.75 inches (3.5/2) in this case. The adjacent side of the triangle is 4500 feet, and the opposite side is .14583333 feet (1.75/12). The tangent is (1.75/12)/4500.
Unfortunately for that formula Jeff, we don't know that the veiwing field at a distance of 1 foot is 3.5 inches, or did I miss something in the camera specs?
Max CR, do you actually have this camera on hand, so you can experiment with it, as suggested? If so, you don't need curious formula, just comparison of similar triangles and a measuring tape or ruler.
3.5 inches is the stated width of the target object.
To answer this question, calculate the following; if the result is larger than 1, your camera should be able to see the object:
( Dt / Lt ) × Nt × ( L / D )​
where
Lt and Dt are the length of and distance away, respectively, of a nearby test object. Note, Dt should be at least 3 times larger than Lt.
Nt is the number of pixels that the test object takes up in the image, along it's entire length.
D and L are the distance away and length of, respectively, of the object of interest.
In your case, D is 4500×12 inches, and L is 3.5 inches, so L/D is 1/15,400.
Jeff, thanks for posting that link. I reviewed your work and I believe I understand it, but red belly's formula seems much easier to work with. I am going to try and see if I can use her formula and if there is no success I will try yours. Thank you. Phrak, I am going to experiment with it using Red's formula.
Red, the only thing that I would like to know is why aren't we using meters in this formula since it is standard notation? Why are we using inches like you suggested?
What units did you use in your OP?
Negitron answered it. But to elaborate a little ...
As long as you use the same units for Dt and Lt, and also use the same units for D and L, the formula will work. The ratios in the formula, Dt/Lt and L/D, will have the same values no matter what units are used.
You could even use inches for D and L, and meters for Dt and Lt.
Note, L is the smaller dimension of the 3.5" x 65" object size.
Correction, angle = 2 x tan-1(3.5 / (2 x 12 x 4500)) = 0.0037136 degrees
Don't forget to include the optical zoom factor, which is related to angle of view:
http://en.wikipedia.org/wiki/Angle_of_view
If you had a telephoto lens with a 10 degree angle of view (equivalent to ~ 205mm lens for 36 mm image), the maximum visible object width at 4500 feet would be 787.398 feet. Your target object width, at 3.5 inches is 0.00037042 or 1/2700 the size of the maximum sized object.
For a still shot camera, something like a Sony A900, 24.6 mega pixel, digital SLR, with 6048x4032 resolution (3:2 apect ratio, it also does 16:9 aspect ratio by cropping this to 6048x3048), with a 200mm lens, would be able to detect the object.
I just realized you meant video camcorder. The high end standard for current display devices is the Sony 4k digital cinema projector, at 4096x2160, cropped to various theater formats. In the past, 35mm or 70mm film was digitally scanned, but there are high end camcorders such as the Red One, that has 4096x2304 resolution if you've got $30,000+ (USA) to spend on a video camera.
http://en.wikipedia.org/wiki/Red_Digital_Cinema_Camera_Company
With a 300mm lens and 24.4 mm image capture width, the angle of view is about 4.6575 degrees. At 4500 feet, the maximum width is 366 feet. The target object is 3.5 inches ~= 1/1255 times the maximum width. The image would occupy about 3 pixels on the camcorder.
For a hi-def camcorder with true 1920 horizontal pixels, for the object to occupy 1 pixel, you need a view angle of 7.12 degrees. Assuming 1x view angle is 45 degrees, then a 10x zoom corresponds to a viewing angle of 4.744 degrees, the object width would be about 1.5 pixels, it would look like a very thin line.
To confirm the numbers, I tested viewing angle versus zoom factor with a Sony HC1 HDV camcorder. Widest angle was about 45 degrees (40 inch width at 48 inch distance), and zoomed at 10x it was a bit more than 4.6 degrees (3 7/8 inch width at 48 inch distance)
Normally, 10x is based on focal length <==> viewing width:
45 ~= 2 tan-1(39.76/(2*48))
4.744 ~= 2 tan-1(3.976/(2*48))
On a side note, adding to the spec confusion for camcorders, actual sensor size, is really about 2/3rds of the "stated" size, in this case the "stated" size of the HC1 sensors is 1/3 inch, but this translates into 6.00mm diagonal instead of 1/3 inch = 8.467mm. This should be a spec width = 4.8mm, height = 3.6mm sensor_sizes.htm, but it doesn't correspond to the stated focal length of the zoom lens 5.1mm -> 51mm.
Thanks anyways for your help Jeff, but reds formula worked for me just fine. I was able to calculate it flawlessly. Thank you. I have been looking far and wide for this formula. Thanks. I was finally able to figure it out!
Just curious. What did you get for your measured Lt and Dt?
Related to Calculating Video Recording Capability of 4500 ft Object w/ Camcorder
1. How do you calculate the video recording capability of a 4500 ft object with a camcorder?
In order to calculate the video recording capability of a 4500 ft object with a camcorder, you will need to know the resolution and frame rate of the camcorder, as well as the distance from the object to the camcorder. Using these factors, you can determine the amount of time it will take to cover 4500 ft and therefore calculate the total recording time.
2. What is the importance of knowing the resolution and frame rate of the camcorder?
The resolution and frame rate of a camcorder are important factors in determining its video recording capability. The resolution refers to the clarity and detail of the footage, while the frame rate refers to the number of frames captured per second. Higher resolutions and frame rates will result in larger file sizes and shorter recording times.
3. How does the distance from the object to the camcorder affect the video recording capability?
The distance between the object and the camcorder is crucial in determining the video recording capability. The farther the object is from the camcorder, the smaller it will appear in the frame and the longer it will take to cover 4500 ft. This means that the recording time will be longer and the total footage captured will be less.
4. Can the video recording capability of a camcorder be extended using additional equipment?
Yes, there are ways to extend the video recording capability of a camcorder. One option is to use a higher capacity memory card, which will allow for more footage to be captured. Another option is to use an external hard drive or recording device to store the footage, allowing for longer recording times.
5. Are there any other factors that can affect the video recording capability of a camcorder?
Yes, there are a few other factors that can impact the video recording capability of a camcorder. These include the lighting conditions, the stability of the camera, and the battery life of the camcorder. These factors can affect the quality and duration of the footage captured.
