Neuroscience Neural impulse, references and ideas
In summary: The notation is a bit different from what I'm used to, so here's my guess. For a simple model I usually write CdV/dt = GR(ER-V) + GS(t)(ES-V). This is a model with...A model with feedback.
  • #36
Neuron counts are estimates. I usually hear 100 billion. It's probably give or take an order of magnitude anyway...
There can be multiple synapses on a single dendritic process.
Likes 1 person
Biology news on Phys.org
  • #37
I see, thanks for the information.
  • #39
Makes you wonder if the things we consider intelligent only belong to a limited region of brain.
I wonder how that patient would deal with outrunning tigers, finding water, and hunting mammoth.
  • #40
Hello guys,
I'm retaking the "work" I started months ago, my goal is to finish it within the next seven days more or less.
I am reading about the Integrate-and-fire model and it is not clear to me whether Lapicque's (I guess he's the first who "invented" this model?) paper was a leaky IAF model or simply an IAF model.
Some references seem to claim that the model had a capacitor with a resistor but that the model was not a leaky one. I do not understand how a model can have a resistor and not be a leaky model.
N.Brunel and M.C.W. van Rossum said:
Lapicque starts his paper by arguing that nerve membranes
are nothing but semipermeable, polarizable membranes.
Polarizable membranes can in first approximation be mod-
eled as a capacitor with leak. The paper then compares his
data to both an RC model of the membrane and a heuristic
law of excitability obtained by Weiss (Irnich 2002).
but later in the same paper one reads
Richard Stein introduced in 1965 a leaky integrate-and-fire model with random Poisson excitatory and inhibitory inputs
(Stein 1965).
Another reference claims:
A.N.Burkitt said:
Lapicque (1907) put forward a model of the neuron mem-
brane potential in terms of an electric circuit consisting of
a resistor and capacitor in parallel, representing the leakage
and capacitance of the membrane.
so it seems what we would call a leaky Integrate-and-fire model, or I'm missing something?
All in all, I do not know how to introduce the Integrate-and-fire model in my document. Is it just a parallel RC circuit or something like wikipedia claims to be, i.e.
Wiki the Great said:
One of the earliest models of a neuron was first investigated in 1907 by Louis Lapicque.[1] A neuron is represented in time by [tex]I(t)=C_m \frac{dV_m (t)}{dt}[/tex]
where there is no mention of any resistor.
  • #41
I have re-read my work and in post 5 I think I made a worrying mistake. I claimed that the DE [itex]\frac{dV}{dt}=-\frac{V}{\tau} +m +\sigma F(t)[/itex] became [itex]\frac{dV}{dt}=-\frac{V}{\tau} +m [/itex] when the white noise is removed, but I think this is false. Since m is the mean of the white noise, if I remove it, m should be worth 0.
So that the DE becomes [itex]\frac{dV}{dt}=-\frac{V}{\tau}[/itex] and the solution is simply [itex]V(t)=Ke^{-t/\tau}[/itex], a decaying to 0 potential function.
  • #42
Hello guys, I have another doubt/question. I would like to know whether in the Integrate-and-fire model, if one has a periodic input function, do one get a periodic somatic potential? It is a doubt because I think that the answer is yes but I haven't seen any demonstration so far.
Just to put water in the bath, here is the DE: [tex]a\frac{dV}{dt}=-V+RI(t)[/tex] and we consider I(t) as a periodic function. Does this imply that v will be periodic?
I am not posting this into the DE forum because I think that one of you may know the answer since it may be a very trivial result in neuronal models.
P.S.:a is a constant, V is the somatic potential, R is the resistor equivalent of the neuron and t is time of course.
  • #43
Technically, yes, but for applications purposes, it depends on "a" and R and the frequency of periodic function I(t). In one regime, the system's intrinsic behavior dominates (a transient to the steady state with little oscillations around it). In the other, the oscillations dominate.
Basically, because the membrane is a capacitor, it's function in an oscillating circuit depends on the capacitive reactance, which is proportional to R/(w*C), where R is the resistance, w is the frequency of your oscillations and C is the capacitance. In your system, it's R/(w*a). That "a" basically sets the time scale of the intrinsic behavior (which is just a linear V).
Likes 1 person
  • #44
Thank you, that makes sense.
  • #45
I've got other questions.
1)What are the main difference(s) between Morris-Lecar and FitzHugh-Nagumo models? They both seem 2 dimensional simplifications of the 4 dimensional Hodgkin-Huxley model. Do their goal differ and in what exactly/more or less?
2)As I understand it, the Gerstein-Mandelbrot's model is just a special case of the Integrate-and-fire model? It appears when the synaptic input signal is considered as a white noise? Does my understanding looks correct?
3)One reads in a Burkit's paper (A review of the integrate-and-fire neuron model: I. Homogeneous
synaptic input), that, if I understand well, for the Gerstein-Mandelbrot's model with positive drift (this information is not mentioned but this is the only case where it makes sense I believe), the density of the first passage time is [tex]f _\theta (t)=\frac{\theta}{\sqrt{2\pi \sigma _W ^2 t^3}} \exp \left [ - \frac{(\theta - \mu _W t)^2}{2\sigma _W ^2 t} \right ][/tex]. Let's discard the meaning of all the variables for now. Then the paper reads that the mean of the interspike interval distribution is [itex]T_{\text{ISI}}=\theta / \mu _W[/itex].
My question is, does this mean that for the Gerstein-Mandelbrot's model with positive drift, the mean time between 2 spikes is worth "[itex]\theta / \mu_W[/itex]" ?
I guess so, but I would like to be 100% sure. The math is over my head here.
I will give some data, [itex]\mu _W[/itex] is the drift constant. I am puzzled as what is theta. Apparently it is the difference of potential between the threshold and resting potentials but then the units of [itex]T_{\text{ISI}}[/itex] would be volts instead of seconds. This does not make sense.
  • #46
1):
I believe The Morris-Lecar neuron has a larger bifurcation set:
http://www.sciencedirect.com/science/article/pii/S0925231205001049
and is therefore capable of a large variety of dynamics. The excitable parameter regime in the Morris-Lecar model consists of three fixed points: a stable point, a saddle-node, and a focus. I usually only see Fitzhugh-Nagumo with one fixed point.
Finally, the Morris-Lecar neuron is modeled after a real experimental neuron (a barnacle muscle fiber) whereas I think Fitzhugh-Nagumo is meant to be the most mathematically reduced generality of an excitable system (based on Hodgkin-Huxley reductions, I believe).
Likes 1 person
  • #47
Pythagorean said:
1):
Thank you very much. Extremely helpful information!
Edit: Here I found a 3 fixed point "analysis" on the FitzHugh-Nagumo model: http://icwww.epfl.ch/~gerstner/SPNM/node22.html.
  • #48
Yes, because of the cubic nature of the differential equation describing V, you can always intersect the cubic three times with a straight line. But Fitzhugh-Nagumo displays excitability without the three intersection points.
In the physiological parameter regime of the Morris-Lecar model, the three fixed points have some kind of physiological meaning and the system only becomes an oscillator when two of the fixed points collide and annihilate, leaving only the unstable focus behind:
So on the left, you see the excitable regime, on the right you see the oscillatory regime. This correlates well with the effect of persistent currents and constant stimuli in neural systems and it's kind of the intrinsic dynamics of neuron function that I've become familiar with in my experience with the Morris-Lecar model.
Maybe the Fitzhugh Nagumo has meaningful physiological correlates, too. I don't know, I'm not that experienced with the model and always had in mind that it was kind of a toy model.
  • #49
I see Pythagorean.
I would like to know your opinion on the Izhikevich's model. From what I've read, it's "very" simple mathematically (a system of 2 DE's where one of them is non-linear but quadratic). It has only 4 parameters (except from the input current) and can describe a plethora of phenomenons experimentally observed.
