An object above absolute zero radiates energy
In summary, the conversation discusses the relationship between motion and the amount of radiation emitted by an object. It is explained that an object above absolute zero radiates energy, regardless of its speed or motion. The speed of the Earth's orbit does not affect the amount of infrared radiation it emits, as motion is relative and does not determine the total emitted light. The increase in temperature caused by collisions leads to more radiation, as collisions result in accelerated charges. This is why objects that are banged about more, such as a jet fighter, radiate more energy.
eightsquare
96
An object above absolute zero radiates energy. This implies that object on Earth too radiate energy(infrared?) My question is, if the Earth were not moving, we would be much slower, so would we radiate in some other wavelength of the spectrum? We are essentially traveling really fast because of the Earth's movement.
I couldn't see it affecting the amount IR radiation coming from our bodies
Dave
How so? We would be slower.
why would we be slower ?
if you walk a kilometre your body is still going to expend the same amount of
energy making your legs move regardless of whether the Earth is stationary or moving
Dave
You seem to think that the speed of an object affects the amount of radiation it admits. Where did you get that idea?
Slower relative to WHAT? Motion is relative. The radiation of the Earth has nothing to do with the speed that it is traveling with respect to other bodies. That speed, by the way, varies from zero to .999999% of c with all values in between. Why would picking one of those frames of reference have anything to do with how much the Earth radiates?
Well greater speed means more kinetic energy and higher kinetic energy means higher temperature and higher temperature means more radiation(that's the way I learned it in school). Which part is wrong?
its wrong in the way you are relating things ( or not relating things)
as phinds said ... motion is relative
did you read my post post #4
does that not make sense to you ?
Dave
If the Earth would not orbit the sun, observers at other stars would see a slightly different spectrum and this spectrum would not depend on the position of Earth in its orbit. The difference would be extremely small, however - we orbit sun with a velocity of ~30km/s, or 1/10000 the speed of light. Observers at other stars could (at most) see a shift of just 2/10000 between "earth moves away from us" and "earth moves towards us".
The total emitted light in the frame of Earth is independent on the motion of Earth relative to anything else.
The total emitted light as seen in other frames might depend on those other frames.
No it does not. Temperature is related to unordered kinetic (and other) energy. The motion of the whole Earth is not unordered.
Nice to get a civil explanation. So this basically means the more the atoms are banged about the more they radiate? Why is this?
because the collisions cause an increase in temperature
Bang a piece of metal plate with a hammer ... you will find that both the head of the hammer and the metal plate get warm
Dave
I know that. I'm asking WHY this increase in temperature causes more radiation.
Collisions lead to accelerated charges, and those produce radiation.
More unordered motion -> more (and higher-energetic) collisions.
Likes 1 person
trying to think of an example if something that gets hotter the faster it moves ...
take a jet fighter ... it does ... its metal skin warms up. and altho the fighter traveling at say, mach 1 ( the speed of sound) has lots of kinetic energy, its not that that is warming the metal skin up.
Its the friction of that metal against the air ( air resistance). if you flew that fighter in a vacuum (with no air)
then the skin wouldn't warm up ... no friction generated heat
cheers
Dave
Perfect. Thanks for the answers.
What does it mean for an object to be above absolute zero?
Absolute zero is the lowest possible temperature, at which all molecular motion ceases. Therefore, an object above absolute zero means that it has some level of molecular motion and is not at the coldest possible temperature.
What does it mean for an object to radiate energy?
Radiation is a process in which energy is emitted by a body in the form of electromagnetic waves. All objects above absolute zero radiate energy, with the amount of energy depending on the temperature of the object.
Why do objects above absolute zero radiate energy?
Objects above absolute zero radiate energy because of their molecular motion. As molecules move, they emit electromagnetic waves, which is how energy is radiated.
Does an object have to be hot to radiate energy?
Yes, all objects above absolute zero radiate energy, but the amount of energy radiated increases with temperature. The hotter the object, the more energy it will emit.
What are some examples of objects that radiate energy above absolute zero?
All objects above absolute zero, including humans, animals, and even inanimate objects such as rocks, radiate energy. The amount of energy radiated depends on the temperature of the object.
  • Other Physics Topics
16K
