Exploring Energy: A Position or Change?
In summary: Work is the effect of changing someone else's energy. You can think of it as the force that is required to move something from its original position to a new, changed position.
jefswat
92
I have always been curious as to what energy is. you can't see it or touch it so it can't be an actual material. I finally came to the conclusion that energy is just a way of describing a position or change in position. would i be correct by looking at energy in this way? I couldn't think of any exceptions but my experience is limited.
Well technically speaking energy is measured in joules, which is really a measurement of force times distance, and force is mass times acceleration, so it can be seen as the amount of work required to accelerate a mass over a measured distance.
Energy is defined as the capacity to do work. Work is force times distance. Change is position is just distance.
Yes, so couldn't you say that because of the position of a given object it has energy? What I am saying is any kind of energy is related to the position of the object.
It is related to the position of the object (or rather, the change in position), yes. That's not quite what you said in the first post, though.
If you can confidently answer that question in your own way, you've done what many physicists have tried to do and a few have accomplished.
Taking the fundamentals of thermodynamics with a brief mentioning of particle physics, Energy describes the relationship between movement, capacity to move, and to give off light. More specifically, the 2nd law tells us that heat transfer is necessary for work. The 1st law tells you E = k + u. You can make your deductions from there.
Of course...particle physics and quantum mechanics opens another door.
You are exploring different types of energy and laws associated it, not defining energy itself.
Energy is a scalar quantity (a number) that characterizes a system. In a way, it's a lot like mass- a scalar that characterizes a material object.
this question is difficult as we use energy to define certain things and work , but on its own energy is a fundamental thing that cannot be physically defined exactly as you have to use few undefined quantities to define other things ( like Axioms ) , same as it is very difficult to define charge , but it is a fundamental quantity that is there but we can not exactly define it. If there is no matter than it does not mean that there is no energy as few of us regarding it with movement of matter.
well if its just a change in position then what about potential energy? or am i just reading wrong?
It isn't just change in position. That's what I said. Potential energy is a change of position of a certain amount of mass up or down in a gravitational or magnetic field. Again, you need the change in position and the mass to know the energy (and, of course, the field strength).
I've always thought of energy as a "book keeping device"! As physics progressed, more and more types of energy- kinetic, potential, heat,...- were added to keep energy conserved; culminating in "E= mc2".
Energy is clearly a property of a physical system, like charge, spin, mass, length, etc, so I think it's more than just a 'book keeping device".
I also agree that the different *expressions* of energy- gravitational potential, entropic, kinetic, electromagnetic, electrostatic, strain, etc. can complicate the issue.
And even worse, many physical processes are associated with energy *changes* (free energy, for example) rather than a definite energy state.
Even so, the energy can be written down and there are clear relationships between processes and changes to the energy.
I guess this puts me in the 'shut up an calculate' school of thought...
But then, what is "work"? :wink:
Energy is the capacity to do work, and work is the effect of changing someone else's energy...
It's not so easy to define, just as it ain't easy to define "mass" or "charge". You can try to define mass in terms of how it resists being accelerated by a force, but then how do you define "force" without using mass?
Energy is not a capacity to do work. Entropy, for example, is a form of energy but can not, by definition, perform work.
On the face of it, F = ma is a definition of mass. It's really a defintion of force-a kinematic relationship of a dynamic quantity to something measurable (the acceleration).
Similarly, dU = Q - W is simply a conservation law- it is not a definition of energy in terms of heat or work, nor does it restrict forms of energy to dissipationless work and workless dissipation.
What is energy?
Energy is the ability to do work or cause change. It exists in many forms, including thermal, electrical, mechanical, and chemical energy.
What is the difference between potential and kinetic energy?
Potential energy is the energy an object has due to its position or condition, while kinetic energy is the energy an object has due to its motion. Potential energy can be converted into kinetic energy and vice versa.
How can energy be transferred from one object to another?
Energy can be transferred through various processes, such as conduction, convection, and radiation. In conduction, energy is transferred through direct contact between objects. In convection, energy is transferred through the movement of fluids. In radiation, energy is transferred through electromagnetic waves.
What is the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that the total amount of energy in a closed system remains constant.
How does energy play a role in everyday life?
Energy is essential for all living things and is used in almost every aspect of our daily lives. It powers our homes, transportation, and electronic devices. It also plays a crucial role in the growth and functioning of our bodies. Understanding and managing energy is crucial for sustainable living and protecting the environment.
  • Other Physics Topics
  • Atomic and Condensed Matter
