Half Question/Half-Challenge: Dimensions of of the Earth-Moon System
In summary, the original question considered was whether a classical astronomer could determine the size of the moon to an arbitrary level of accuracy using only one-way measurements from a single spot on Earth. Various qualifications were set, including the use of imaginary telescopes and not knowing any distance or velocity values for other solar system objects. The solution proposed involved using an extremely accurate telescope to measure the gravitational lensing of the moon, but there were concerns about the method. Other suggestions were the use of parallax and the measurement of the moon's eccentricity to determine its velocity. However, obtaining the moon's velocity may be a challenge.
Vorde
788
I've been considering this problem for about a year now (whenever I remember about it, that is), and I've come to the conclusion that I can't figure out a way to do what I want to see is possible, and so I've decided to ask it here to see if anyone else can.
The original question I considered was: could a classical astronomer determine the size of the moon to an arbitrary level of accuracy? Since then I've sort of refined the question, and here are my qualifications:
1) The process has to be able to be theoretically done from a single spot on the Earth (so triangulation is allowed, but only one point of the triangle can be on Earth).
2) You are only allowed one-way measurements, so you can throw something at the moon and measure that, or measure something coming from the moon (or somewhere else), but you can't involve the measurements of one object going to and from the moon (including light).
3) An arbitrary amount of accuracy is allowed with imaginary telescopes and the like.
4) You don't know any distance or velocity values for other solar system objects.
With that in mind, the question is: What is the radius of the moon?
My solution is to, using an extremely accurate telescope, measure the gravitational lensing of the moon, thereby getting its mass. Using a tide-measuring system, and knowing the moons mass, you could figure out the acceleration/force you are experiencing from the moon, and thereby figure out the distance to the moon, and then the radius.
However to me this fails on two counts. 1) I'm not positive the gravitational lensing test will produce a value for M instead of an M/D ratio, and 2) It feels like the use of GR goes against the original purpose of the question.
Does anyone have a more elegant solution? Or knowledge that there isn't one?
Astronomy news on Phys.org
Joke answer: send an astronaut to the moon with a meter stick to measure the distance, and have him beam back a radio signal with the answer. One object went, and a different one came back :)
Serious answer: The closest method that comes to mind is of course to use the parallax method. You've thrown in the monkey wrench of not being able to use triangulation from different points on the Earth, but you could avoid that by using the parallax occurring from the Earth's rotation (for example, measure the angular position on the sky at sunset and then again at sunrise). Unfortunately, the Moon will move through space during that several hour period (though it works better for more distant objects whose proper motions are smaller in that period -- David Gill used this to measure parallaxes from a single spot to high accuracy, for his time anyway). If you're allowed to know the velocity of the moon (and surely one can measure that using classical techniques) then one might be able to account for that proper motion during the interim period, but I haven't given it much thought as to exactly how you would do it.
That would work, I think, if you knew the velocity of the moon, but how would that be obtained?
Well, the moon's orbit is eccentric. Suppose one could figure out the degree of eccentricity of the orbit using the change in apparent angular size of the moon from perigee to apogee. Then, one could in principle use the Doppler effect to figure out what the non-circular component of the velocity is, and perhaps from there work out what the total velocity must be? Just a guess, I haven't even worked it out to see if this is enough information.
I find your line of thinking and problem-solving skills impressive. It is always important to question and refine our ideas and theories in order to reach a more accurate understanding of the world around us.
In terms of your specific question, I would suggest considering using the method of parallax. This involves measuring the apparent shift in the position of the moon when viewed from two different points on Earth. With this information, along with the known distance between the two points on Earth, one can calculate the distance to the moon and therefore its radius.
Another potential approach could be to use radar ranging, where a radar signal is sent to the moon and the time it takes for the signal to bounce back is measured. With this information, the distance to the moon can be calculated and therefore its radius.
Both of these methods rely on the principles of trigonometry and do not require knowledge of other objects in the solar system or the use of general relativity. However, they may still have limitations in terms of accuracy and potential sources of error.
In conclusion, while your proposed solution using gravitational lensing is intriguing, it is important to consider alternative approaches and potential limitations. I encourage you to continue exploring this problem and perhaps even collaborate with other scientists to find a more elegant solution.
1. What are the dimensions of the Earth-Moon system?
The Earth-Moon system has a diameter of approximately 384,400 kilometers and a mass of about 81 times that of the Moon.
2. How does the distance between the Earth and Moon affect tides on Earth?
The distance between the Earth and Moon plays a significant role in the formation of tides. The closer the Moon is to the Earth, the stronger its gravitational pull on the Earth's oceans, resulting in higher tides.
3. What is the average distance between the Earth and Moon?
The average distance between the Earth and Moon is about 238,855 miles (384,400 kilometers). This distance is constantly changing due to the elliptical shape of the Moon's orbit.
4. How does the Moon's size compare to the Earth's?
The Moon is significantly smaller than the Earth, with a diameter of about 3,474 kilometers compared to the Earth's diameter of 12,742 kilometers.
5. How long does it take for the Moon to orbit the Earth?
The Moon takes approximately 27.3 days to orbit the Earth, which is also the same amount of time it takes to complete one rotation on its own axis. This phenomenon is known as synchronous rotation.
  • Astronomy and Astrophysics
