Specific Heat Capacity, Heat Energy, Thermodynamics Physics
In summary, the problem involves determining the final temperature of melted water after supplying 60KJ of heat energy to a block of ice with a mass of 150g and a temperature of -4°. The suggested approach is to first calculate the amount of heat energy required to melt the ice (using latent heat), and then use specific heats to determine how much of the remaining 60KJ goes into heating the water and ice, and finally calculate the final temperature using the relevant physical parameters provided.
RCF
A block of ice has a mass of 150g and a temperature of -4°. The ice is melted by supplying 60KJ heat energy. Determine the final temperature of the melted water.
Equations i think can be used:
Q = ml and H = mcΔθ
I have attempted the solution with even different specific heat capacities but i am getting very high temperature which does not make a lot of sense. Can you please help me out.
Have you heard of latent heat? (if they still call it that. Anyway heat of melting.)
yes but how to solve it using latent heat studies?
Well if you know what latent heat is calculate the amount of heat energy that melts that amount of ice, which is without change of temperature, then the rest of the supplied 60 kJ goes into heating the water and ice, then use specific heats to calculate how much those kJ raise the temperature. You have presumably been supplied with the relevant physical parameters to use, else you will have to find them out.
As a scientist, it is important to understand and apply the principles of thermodynamics in order to accurately solve problems involving heat energy and temperature changes. In this case, we are given a block of ice with a mass of 150g and a temperature of -4°, and we are told that it is melted by supplying 60KJ of heat energy. Our task is to determine the final temperature of the melted water.
To solve this problem, we can use the equation Q = ml, where Q is the heat energy, m is the mass, and l is the specific heat capacity. We can also use the equation H = mcΔθ, where H is the heat energy, m is the mass, c is the specific heat capacity, and Δθ is the change in temperature.
Since we are given the mass and heat energy, we can rearrange the first equation to solve for the specific heat capacity, l.
l = Q/m
Plugging in the values, we get:
l = (60,000J)/(0.150kg)
l = 400,000 J/kg
Now, using the second equation, we can solve for the final temperature, Δθ.
Δθ = H/(mc)
Δθ = (60,000J)/((0.150kg)(400,000 J/kg))
Δθ = 0.25 K
Therefore, the final temperature of the melted water is -4° + 0.25 K = -3.75°.
It is important to note that the specific heat capacity of water is not a constant value and can vary depending on the temperature. However, for simplicity, we have assumed a constant specific heat capacity in this problem. Additionally, our final temperature of -3.75° may seem high, but it is important to remember that we are dealing with a small amount of ice (150g) and a large amount of heat energy (60KJ), so the temperature change will be significant.
In conclusion, by using the principles of thermodynamics and the equations Q = ml and H = mcΔθ, we can accurately determine the final temperature of the melted water in this problem.
FAQ: Specific Heat Capacity, Heat Energy, Thermodynamics Physics
1. What is specific heat capacity?
Specific heat capacity, also known as specific heat, is the amount of heat energy required to raise the temperature of one gram of a substance by one degree Celsius. It is a measure of how much energy a substance can store as heat.
2. How is specific heat capacity different from heat energy?
Specific heat capacity is a property of a substance, while heat energy is a measure of the total energy transferred to or from a substance. Heat energy takes into account both the specific heat capacity and the mass of the substance.
3. How is specific heat capacity measured?
Specific heat capacity is typically measured through an experiment where a known amount of heat energy is added to a substance and the resulting change in temperature is recorded. The specific heat capacity can then be calculated using the formula Q = mcΔT, where Q is the heat energy, m is the mass of the substance, c is the specific heat capacity, and ΔT is the change in temperature.
4. How does specific heat capacity affect the transfer of heat?
The higher the specific heat capacity of a substance, the more heat energy is required to raise its temperature. This means that substances with a high specific heat capacity can absorb more heat energy without experiencing a large change in temperature. This can be beneficial in applications where temperature control is important, such as in cooking or in industrial processes.
5. How does thermodynamics relate to specific heat capacity and heat energy?
Thermodynamics is the study of the relationship between heat, work, and energy. Specific heat capacity and heat energy are important concepts in thermodynamics, as they help to understand how heat energy is transferred and used in different systems and processes. The laws of thermodynamics also govern the behavior of specific heat capacity and heat energy, providing a framework for understanding the behavior of matter and energy.
