Summation of geometric number of iid exponentially distributed random variables
Gamma function and the fact that the Gamma distribution is the continuous version of the geometric distribution.In summary, the conversation discusses the problem of finding the cumulative distribution function of a sum of independent, exponentially distributed random variables with a geometrically distributed number of terms. The suggestion is made to use the Gamma function and the fact that it is the continuous version of the geometric distribution to solve the problem.
redflame34
Hello, I am having difficulty approaching this problem:
Assume that K, Z_1, Z_2, ... are independent.
Let K be geometrically distributed with parameter success = p, failure = q.
P(K = k) = q^(k-1) * p , k >= 1
Let Z_1, Z_2, ... be iid exponentially distributed random variables with parameter (lambda).
f(z) =
(lambda)*exp(-(lambda)x) , x >= 0
0, otherwise
Find the cdf of Z_1 + Z_2 + ... + Z_K
I think there is some relation to the Gamma function here, but I'm not quite sure how...
Any hints/suggestions?
Well, I would try something like this. Let S be your "random number of random variables", ie. Z1+Z2+...+ZK
P(S<X) = sum_n P(S<X | K=n) * P(K=n)
Then analyze P(S<X | K=n) by finding the PDF or CDF for a random variable that is the sum of n exponential random variables. You could use the result that the resulting distribution function is the convolution of the n distribution functions.
After you have found P(S<X | K=n), you can perform the sum of n.
Torquil
What is "Summation of geometric number of iid exponentially distributed random variables"?
The summation of geometric number of iid exponentially distributed random variables refers to the process of adding together a certain number of independent and identically distributed exponentially distributed random variables, where the number of variables being added is determined by a geometric random variable.
What is an iid exponentially distributed random variable?
An iid exponentially distributed random variable is a type of random variable that follows the exponential distribution and is independent and identically distributed, meaning that each variable has the same probability distribution and is not influenced by any other variables in the sample.
How is the summation of geometric number of iid exponentially distributed random variables calculated?
The summation of geometric number of iid exponentially distributed random variables is calculated by first determining the number of variables to be added, based on a geometric random variable. Then, the values of the exponentially distributed random variables are added together to get the final sum.
What is the significance of "Summation of geometric number of iid exponentially distributed random variables" in scientific research?
The summation of geometric number of iid exponentially distributed random variables is important in scientific research as it is used to model various real-world phenomena, such as the time between events in a Poisson process or the time until failure in reliability engineering. It also has applications in statistics and probability theory.
What are some limitations of using "Summation of geometric number of iid exponentially distributed random variables" in research?
One limitation of using the summation of geometric number of iid exponentially distributed random variables is that it assumes that the variables being added are independent and identically distributed, which may not always be the case in real-world situations. Additionally, it may not be appropriate to use this method if the number of variables being added is very large, as it can lead to computational difficulties.
