Retrieving Indices of a vector whose elements fulfil a criteria
In summary, to find the ten indices i for which A(i) are the greatest 10 values in A, you can use the sort function in Matlab to return the sorted array and an array of permutation indices. To find a specific row in a vector, you can use a search function like min or max, or cache the value and avoid repeated calls within a loop.
mikeph
1,235
I have a 100x1 vector A, and want to know the ten indices i for which A(i) are the greatest 10 values in A.
I can find the values by:
Code:
B = sort(A)
B(1:10);
But I don't know how to find the indices, apart from starting a new if loop which searches the entire matrix (which seems very time consuming).
As another example, I have a matrix B which is 10,000x2 and I want to know the value of B(i,1) for which B(i,2) is the maximum value in the column vector B(:,2). Eg.
Code:
>> B = [(5:0.1:5.9)',rand(10,1)]
B =
   5.000000000000000   0.696266337082995
   5.100000000000000   0.093820026774866
   5.200000000000000   0.525404403859336
   5.300000000000000   0.530344218392863
   5.400000000000000   0.861139811393332
   5.500000000000000   0.484853333552102
   5.600000000000001   0.393456361215266
   5.700000000000000   0.671431139674026
   5.800000000000001   0.741257943454206
   5.900000000000000   0.520052467390387
>> for i = 1:10
if B(i,2) == max(B(:,2))
B(i,1)
end
end
ans =
   5.400000000000000
However I think this is taking absolutely ages in my code (I need to find this 20bn times so it's definitely an area for optimisation). Is there a simpler way to find the indices?
It looks like you are using Matlab. Matlab's sort function can return two values, the sorted array and an array of permutation indices.
Code:
[B,idx] = sort (A);
I didn't realize sort had that second output! I've been using it for ages as well.
Thanks for the fast response!
Following on from this, is there any way to quickly find a specific row in a vector?
For example, searching for the half-width half-maximum of a Gaussian
Code:
>> x = -20:0.0001:20;
>> f = 4*exp(-x.^2/3);
>> time = cputime; for i = 200000:400001
if abs(f(i) - max(f)/2) < 0.0001
x(i)
break
end
end; cputime-time
ans =
    1.4420
ans =
   45.2031
ie. I can find the value but it takes a long time. 45 seconds is ordinarily fine but I need to perform this many, many times.
Is there no "search" function?
BTW. In the example I realize that there is probably no i such that f(i) = 2 exactly. If there is no answer to this question, would there be an answer if there did exist an i where f(i) = 2?
In the above example, you are calling max(f) 200,001 times, each invocation of which requires searching over a list of 400,001 elements. Of course that is slow. Cache the value of max(f) outside the loop and you will see a dramatic speed bump.
What about instead of the loop, doing something like this (using your above definitions of f and x):
[junk, halfwidthIndex] = min(abs(f - max(f)/2));
x(halfwidthIndex)
FAQ: Retrieving Indices of a vector whose elements fulfil a criteria
What is the purpose of retrieving indices of a vector?
The purpose of retrieving indices of a vector is to identify the specific elements within the vector that meet a certain criteria or condition. This can be useful for data analysis and manipulation, as well as for programming tasks such as sorting or filtering.
How do I retrieve indices of a vector?
To retrieve indices of a vector, you can use a variety of methods depending on the programming language or software you are using. In general, you can loop through the vector and check for the desired criteria, or use built-in functions or methods specifically designed for retrieving indices.
What is the criteria for retrieving indices of a vector?
The criteria for retrieving indices of a vector can vary depending on the specific task or goal. Some common criteria include finding elements that meet a certain value, are within a certain range, or follow a specific pattern or condition. The criteria can also be user-defined, allowing for more flexibility and customization.
How do I use the retrieved indices of a vector?
The retrieved indices of a vector can be used in various ways, depending on the purpose of the retrieval. For example, you can use the indices to access and manipulate the corresponding elements in the vector, or to create a new vector containing only the selected elements. You can also use the indices to perform further calculations or analysis on the selected elements.
Can I retrieve indices of a vector in multiple ways?
Yes, there are often multiple ways to retrieve indices of a vector. Some methods may be more efficient or suitable for specific tasks, while others may offer more flexibility or customization options. It is important to consider the purpose and requirements of the retrieval in order to choose the most appropriate method for your needs.
