Chain Problem involving Kinetic Friction
In summary: W=\int_0^L{F_tdx}=\int_0^L{\left(F-\mu \rho g (L-x)\right)dx}. Then, use the work-energy theorem to determine the work done by the force of friction:W=\int_0^L{\left(F-\mu \rho g (L-x)\right)dx}. Finally, use the Pythagorean theorem to determine the distance L from the point of application of the force of friction:L=\sqrt{W^2+F^2}.
Tanya Sharma
1,540
135
A heavy chain with a mass per unit length ρ is pulled by the constant force F along a horizontal surface consisting of a smooth section and a rough section.The chain is initially at rest on the rough surface with x=0 .If the coefficient of kinetic friction between the chain and rough surface is μ , determine the velocity of the chain when x=L .
I am applying work energy theorem . Work done by constant Force will be Force × displacement of centre of mass i.e FL but not able to find work done by friction .The friction force at an instant when chain length x lies on the rough surface should be μρxg.This force is continuously decreasing .i feel calculus is involved here but i am unable to apply it.Please help me .thanks.
Is the force of friction constant here?
It is the sum of energy taking small mass dm across the rough surface.
μgƩxdm where dm/dx=ρ
x varies from 0 to L
From this you can find the definite integral.
There is not enough information. To see that, imagine the entire chain is on a smooth surface. The work of friction is zero, so the entire work must be equal to the kinetic energy at distance L. But the velocity cannot be determined because the total mass cannot be determined.
The force of friction on chain is μN ,where N =(mass of chain on rough surface) ×g=ρxg.Thus frictional force at any instant when chain of length x is on rough surface is μρxg.But now as the chain is being pulled to right ,the length x decreases , hence frictional force decreases continually.Now i am not able to calculate the work done by this variable frictional force .What should be the limits of x when we consider dx displacement.Please reply...
i feel sufficient information is provided.here mass per unit length ρ is provided.
Care to check azizlwl's reply, Tanya. :smile:
I don't understand azizlwl's reply.Kindly explain
You got the force of friction right. Find the work done by force of friction for small displacement dx. Integrate it from x=0 to x=L.
why integrate from x=0 to x=L.This is the portion on smooth surface.
Yes, it is. We have to find the work done by the force of friction when x=L i.e. L length of the chain is on the smooth surface now.
hey Pranav...please can u give a detailed explanation.thanks. i feel limits should be between length and length - L coz intially length (full chain)was on rough surface and finally L moves to smooth surface so length - L remains on rough surface so technically we should integrate between the limits length to lenth - L.Plz help.
What is the total length of the chain?
I made assumption length=L.
The force acts at the right end of the chain, and the displacement of that point can be called x. x changes from zero to L, length of the chain. If the right end is at position x, L-x long piece of chain is on the rough surface. The force of friction, as you wrote correctly is proportional to the length on the rough surface. So the total force is Ft=F-μρ(L-x)g. The work of the total force is
[tex]W=\int_0^L{F_tdx}=\int_0^L{\left(F-\mu \rho g (L-x)\right)dx}[/tex].
According to the Work-Energy Theorem the work is equal to the change of kinetic energy.
ehild
L is not specified as the length of the chain. Nor is that apparent from the original drawing. Am I missing something?
Ops, you are right. But it seemed plausible that L is the length of the chain. Now, if it is Lc, than the work is the integral above for L≤Lc and ∫Fdx from x=Lc to L. But one does not know the mass of the chain as you pointed out, and the problem can not be solved.
ehild
You are right, L should be the length of the chain...
ehild
It seems there's some confusion amongst the previous posters on this thread, so I'm going to start from the beginning.
Two questions for Tanya:
If this problem were about a point particle of mass m, rather than a chain, would you know how to solve it?
What makes the solution for a chain different from the solution for a solid block?
My suggestion for a solution strategy for this problem is as follows. First, write down (in integral form) the equation for the change in kinetic energy of a point particle of mass m as it is pulled across both the rough and smooth portions of the table. Second, consider the chain at a given instant in time as being composed of two point particles; one on the smooth section of the surface, and one on the rough section. How does the motion of the chain affect the mass of these two imaginary point particles? Can you express that change in mass mathematically as a function of the position of the chain? If so, you should be able to write down the correct expression for the integrand of the work integral in terms of the chain's position. The last step is then to integrate.
I am really grateful for all the prompt responses especially echild .Yes it seems that the length of chain should be L which is not mentioned in the question, but seems plausible as mentioned in above posts.Thanks a ton...
1. What is a chain problem involving kinetic friction?
A chain problem involving kinetic friction refers to a scenario where a chain or rope is being pulled over a surface with friction, causing the chain to move at a certain velocity. This type of problem is commonly encountered in physics and engineering, and involves calculating the forces and motion of the chain.
2. What factors affect the kinetic friction in a chain problem?
The kinetic friction in a chain problem is affected by several factors, including the weight and tension of the chain, the surface roughness and material, and the speed at which the chain is being pulled. These factors can influence the magnitude of the frictional force acting on the chain and affect its motion.
3. How is the coefficient of kinetic friction determined in a chain problem?
The coefficient of kinetic friction, denoted as μk, is a dimensionless quantity that represents the ratio of the frictional force to the normal force acting on an object. In a chain problem, this coefficient can be determined experimentally by measuring the weight and tension of the chain and the resulting acceleration.
4. What are some common challenges in solving chain problems involving kinetic friction?
One common challenge in solving chain problems involving kinetic friction is accounting for the changing tension and weight of the chain as it moves. This requires considering the acceleration and velocity of the chain at different points along its length. Another challenge is accurately measuring and accounting for the coefficient of friction, which can vary depending on surface conditions and other factors.
5. How do chain problems involving kinetic friction relate to real-world applications?
Chain problems involving kinetic friction have many real-world applications, such as in the design and operation of conveyor belts, elevators, and other systems that involve the movement of chains or ropes over a surface. Understanding and solving these types of problems is crucial in industries such as manufacturing, transportation, and construction.
