Why is Torque the Cross Product Between r and F?
In summary, torque can be calculated by taking the cross product of the position vector and the force vector. This formula aligns with the intuitive idea that a larger force or a greater distance from the pivot point will result in a greater tendency for an object to rotate. The formula also accounts for the angle between the position and force vectors, with maximum torque occurring at a 90 degree angle. The reason for the sine relationship in the formula is to account for the perpendicular component of the force, which is the component that affects rotation. This can be seen in the example of pushing on handles of different lengths on a vertical shaft. The relationship between torque and angular momentum is also explained through the time derivative of angular momentum, which is equal to the cross
kevinze
Examine T= r x F (cross product),
where |T|=|r||F| sin t, where t is the angle between r and F
The intuitive idea of torque (let's only consider torque about the pivot for now) is that the stronger the force or the further away you are from the pivot point, the more the object will TEND to rotate.
The cross product formula above does match this intuitive idea. For example, larger force, the magnitude of the torque really does increase. It also matches the observation that no torque is generated when t is zero, and max torque when t is at a 90 degree angle.
My question is, what about the angles in between? Using the formula, does this really match with what nature is telling us? Does the formula truly reflect the intuitive idea of torque in terms of the tendency of making an object rotate? I don’t see a reason why it has to obey the sine relationship/curve other than the fact that at t =0 and t=90 we see min and max respectively. For example, why can't it be a linear relationship for angles in between?
Thanks!
think of the sin(t) as a means to decompose the F vector into two components:
F sin(t) and F cos(t) where F sin(t) is perpendicular to R and F cos(t) is parallel to R then you can see that the F cos(t) doesn't have any effect on the rotation whereas F sin(t) does.
Consider a long vertical shaft, like the drill shaft on an oil rig.
Now weld two handles on that shaft.
The first handle is one meter long and extends horizontally.
The second handle is 1.4 meters long and extends at a 45 degree angle diagonally upward so that its end is also about one meter away from the shaft.
The welds are solid and the handles strong.
Would you agree that pushing on the end of either handle provides the same rotational torque as pushing on the other?
Or would you claim that pushing on the longer handle provides only 70% as much torque as pushing on the shorter handle?
Thanks this was really helpful in seeing what was really happening. Yes so we indeed only consider the perpendicular component of the force which is accounted for in the cross product formula. There's no way it can be a linear relationship.
Thanks again :).
Once you have a notion of angular momentum, the relationship between that and torque is clear.
If you accept that [itex]\ell = r \times p[/itex] and that [itex]dp/dt = F[/itex] (force is the time derivative of momentum), then the time derivative of angular momentum is
[tex]\frac{d\ell}{dt} = \frac{dr}{dt} \times p + r \times \frac{dp}{dt} = v \times p + r \times F[/tex]
Of course, [itex]v \times p = 0[/itex], and we get [itex]d\ell/dt = r \times F[/itex]. We call this torque.
Related to Why is Torque the Cross Product Between r and F?
1. What is torque and why is it important?
Torque is a rotational force that causes an object to rotate around an axis. It is important because it helps us understand how objects move and how to control their motion.
2. How is torque calculated?
Torque is calculated as the cross product between the force applied to an object and the distance from the axis of rotation to the point where the force is applied. This is represented as T = r x F, where T is torque, r is the distance vector, and F is the force vector.
3. Why is torque the cross product between r and F?
The cross product between r and F is used to calculate torque because it takes into account the direction of the force and the direction of the distance vector. This results in a vector quantity that represents the rotational force, rather than just the magnitude of the force.
4. Can torque be negative?
Yes, torque can be negative. This occurs when the force and the distance vector are in opposite directions, resulting in a negative cross product and a negative torque value. This indicates that the object will rotate in the opposite direction of the applied force.
5. How does torque affect rotational motion?
Torque affects rotational motion by causing an object to rotate around an axis. The greater the torque, the faster the object will rotate. Additionally, torque can change the direction of rotational motion, depending on the direction of the force and the distance vector.
  • Mechanics
  • Mechanics
  • Mechanics
