Calculating Battery requirements for EV
  • Thread starter robinfisichel
  • Tags
    Battery Ev
In summary: So figure on 30-60 kWh for your light vehicle's 100 mile range depending on how slow you go.In summary, the conversation discusses using a motor in an electric vehicle and calculating the number and specifications of batteries needed to run it. They also consider the power demand, voltage, temperature, and battery chemistry. The conversation concludes with a discussion on the calculations for battery storage requirements and the expected range of the electric vehicle based on speed and weight.
robinfisichel
39
I have a motor which i am planning on using in an electric vehicle i am designing.
http://www.azuredynamics.com/products/force-drive/documents/AC24_DMOC445ProductSheet.pdf
and want calculate the number and specs of batteries needed to run it.
I have the power demand from the motor at any given time and therefore i can use
P=I.V to calculate the current needed at any given time and then use that in Q = I.t to calculate the battery life in Amp.Hrs.
From that i guess i can calulate how many batteries i need. I will probably use Lithium Ion Phosphate batteries.
I assume looking at the spec sheet that the voltage i use is 156 v dc, is this correct?
Yes for the wiring configuration given.
A common rule of thumb for highway capable EVs is about 4 miles per kilowatt-hour of battery energy on board, or 25 kWh of battery capacity for 100 miles. That is for commercial vehicles with regenerative braking. You might assume 3 miles per kWh.
Also consider temperature. Assuming you go with Li-Ion, unless you provide some kind of thermal management system for your battery pack, expect the discharge energy, and thus your range, to drop by 20% in freezing temperatures (so down to 80 miles on a 25 kWh pack), and more than that if you need to use max power for some reason for an extended time. The batteries should yield a full charge again upon return to mild temperatures.
Extended operation at high temperatures will negatively impact battery life. For the newer LiFePO batteries, you can expect almost 3000 full depth of discharge cycles before the capacity falls to 80% of new - at moderate temperature operation. LiIon is much more efficient than Lead Acid (i.e. lower internal resistance), but you still want to allow for dissipation of 5-10% of your electrical power lost to heat inside the battery pack. If for some odd reason you want to use Li Ion Cobalt (laptop) chemistry, then you really need to consider safety at high temperatures (ie don't use Li Co), as they're famously prone to thermal runaway if you let them get too hot.
Apparently people want to look back at deep cycle lead acid batteries for these projects. The numbers are changing, but my last look yields a comparison something like this for the same amount of battery capacity (Lead Acid vs Li Ion):
Weight: Lead Acid ~3x heavier.
Cost: Lead Acid 2-3x cheaper initial purchase.
Cycles: Lead Acid 2x less (i.e replace them 2x faster).
Thanks for the useful info,
My calculations are coming out as half of that though! I did my calculation based on a 3 part drive cycle consisting of 10 mins on urban, rural and motorway.
This consumed around 5kW of energy per cycle (half hour long). so for 100 miles i needed around 12Kwh of storage, the averae speed was about 20m/s (50mph) for this period.
Bearing in mind this is a very lightweight vehicle (410 kilos) with a max power requirement of 33kW does this sound reasonable to you?
I would aslo say that i used that constant voltage for caluclating the storage requirements (didnt account for stop start voltage changes). I haven't accounted for the efficiency of the battery or motor yet either (though i have accounted for efficiencies of drivelines and mechanical workings of car/resitive forces).
No, 12kWh will not take you anywhere close to 100 miles at 50 mph, unless your vehicle is a ~one seater with the drag coefficient of an airplane. Above ~20-30 mph, wind resistance dominates the tractive load for regular cars, so the weight of your vehicle matters little compared to its drag coefficient on the highway. At 50 mph, figure on something like 15kW for your home built vehicle to maintain speed on level road. So 100 miles would require two hours at 50 mph, or 30kWh. Slow down to 15-20 mph in a light vehicle and yes you might make 100 miles w/ 12kWh of capacity, with care.
Some additional help. This is the energy v speed curve for a typical combustion engine sedan, tank-to-wheel efficiency = 25%:
Figure A.9. Simple theory of car fuel
consumption (energy per distance)
when driving at steady speed.
Assumptions: the car’s engine uses
energy with an efficiency of 0.25,
whatever the speed; cdAcar = 1 m2;
mcar = 1000 kg; and Crr = 0.01.
Note how drag dominates the rolling resistance.
At 50 mph (81 kmph) the above vehicle uses ~45 kWh/100km. The same vehicle powered as an EV and with perhaps 75% efficiency would use 1/3 that, or 15 kWh/100km (24 kWh/100 miles). You may do slightly better with your light vehicle.
90% +/- 5% Ii Ion for rated discharge
or motor
91%+/-3% at rated power. In my experience, assuming no exotic batteries or motors.
Good luck.
I aggree with you that at 50mph that i would need more energy.
However if you look at my drive cycle below you will reaslise that it will not do this average speed for 100miles continuous.
I am trying to compile a spreadsheet of the powers required to accelerte the vehicle and the resistive forces throughout.
The dominant force is not drag, the force required to accelerate the vehicle is allmost allways dominant.
If you want the total energy required for a trip you are now making, you should get a gps, record the trip data, and http://chargecar.org/participate" .
They take as input parameters the drag coefficient and weight of your vehicle, so this would make it an ideal tool for analyzing your hypothetical vehicle.
Here's a snippet of some of the data from one of my trips:
Show Trip Stats --> Total Distance: 3.79 miles
If I Had an Electric Car... --> Total Discharge: -1.63 kWh
which gives you 430 watt-hours per mile.
(actual mileage will vary depending on how you drive and maintain your vehicle)
Ok, but then it is not an average.
Units? Speed in km/hour vs seconds? No regen braking to capture that energy when you decelerate?
Ok, sorry on that graph, the x-axis is seconds, the speed is in kph. I am leaving regen braking out for now, ill wait until i can get a reasonable answer for just normal battery drain. Plus i have no idea about the effienency about how much energy from braking can be converted into electrical energy and stored!
I will hopefully post up a few more graphs by the end of today.
Related to Calculating Battery requirements for EV
1. What factors affect the battery requirements for an EV?
The battery requirements for an EV are affected by several factors such as the weight and size of the vehicle, the desired driving range, driving conditions, and the efficiency of the motor and other components.
2. How do I calculate the battery capacity needed for an EV?
The battery capacity needed for an EV can be calculated by dividing the desired driving range by the vehicle's efficiency. For example, if the desired range is 300 miles and the efficiency is 4 miles per kWh, the battery capacity needed would be 75 kWh (300 miles / 4 miles per kWh).
3. What is the most important factor to consider when choosing a battery for an EV?
The most important factor to consider when choosing a battery for an EV is the energy density. This refers to the amount of energy that can be stored per unit of volume or weight. A higher energy density battery will allow for a longer driving range and better performance.
4. How does temperature affect battery requirements for an EV?
Temperature can significantly impact the performance and lifespan of a battery for an EV. Extreme temperatures, both hot and cold, can decrease the battery's efficiency and reduce its capacity, resulting in a shorter driving range. It is important to consider temperature management systems when calculating battery requirements for an EV.
5. Can I use different types of batteries for an EV?
Yes, there are several types of batteries that can be used for an EV, including lithium-ion, nickel-metal hydride, and lead-acid batteries. Each type has its own advantages and disadvantages, and the choice will depend on factors such as cost, energy density, and environmental impact.
  • Electrical Engineering
