Are there any GUT's that do not violate baryon number?
  • Thread starter ensabah6
  • Tags
    Baryon
In summary, the existence of baryon number violation in GUTs has been falsified by current bounds on proton decay. While some GUTs, such as SO(10) and SU(5), have not been strictly ruled out, there have been attempts to modify existing models to avoid this problem. Additionally, strong bounds from astrophysics on matter/antimatter asymmetry suggest that baryon number may not be conserved in the early universe. However, the possibility of baryon number conservation cannot be considered until more antimatter is observed in the universe. Theoretical efforts have been made to explain this discrepancy, such as adding a fifth force or particles. Overall, the question of baryon number conservation in
ensabah6
695
It's my understanding SU(5), SUSY SU(5) and SO(10) have been falsified by current bounds on proton decay.
Alternatively, given the current bounds of proton decay is 10^33 years 95% confidence and counting, if physicists a century from now of looking for proton decay and come up with null results conclude that baryon number is conserved, would this falsify all GUT scenarios?
I think there have been a lot of efforts modifying exsiting models to avoid such a problem. Maybe search a little bit in the recent literature, lots of stuff would jump out. :)
No, if you put leptons and quarks into the same multiplet, there will always be interactions which transform quarks into leptons.
However, there are GUTS that do not violate present experimental bounds on baryon-number-violating interactions, e.g. proton decay. I don't think that SO(10) or susy SU(5) have been strictly ruled out.
SO(10) and SuSy SO(5) are most assuredly not ruled out. Its known that you can add R Symmetry in various ways to escape the bound.
Baryon number cannot be conserved either. Strong bounds from astrophysics on matter/antimatter asymetry more or less conclusively point to some baryon violation at least in the early universe.
Theoretically there is no good reason to expect such a thing to be conserved either, and more or less an artifact of the standard model.
You could alway do like Glennys R. Farrar and add a fifth force/particles to explain dark matter.
jal
WHat are their predicted proton half-lives and how many years before Kakimonde will reach that number?
Do you believe in magnetic monopoles?
Thanks
Doesn't more recent work show that even the standard model predicts proton decay? (Although from what I understand, the half life it predicts is so long that it does not matter)
I do wonder:
how many more decades of a null result before physicists consider the possibility that baryon number is conserved. I understand that Kakimonde puts the bounds at 10^35 years. Perhaps quarks and leptons are not in the same multiplet.
"how many more decades of a null result before physicists consider the possibility that baryon number is conserved."
That just can't happen until we see more antimatter in the universe.
Its a general theorem that in order to create the sort of condition where you have the observed ratios, you need three conditions in the early universe. A healthy amount of CP violation, departure from thermal equilibrium and baryon number violation. Where the quantitative values depend on each other.
Point being, there has to be some new physics *somewhere* where this is allowed to take place. No one knows how this works really, but if you can solve this problem, proceed to Copenhagen.
Do you mean Stockholm?
Perhaps we do observe matter-antimatter anhilation as very high energy gamma rays.
I'm kinda curious as to why ultra-high cosmic rays could not be the result of matter-antimatter anhilation, since presumably that would also result in high energy gamma rays.
Perhaps there is a mechanism that keeps matter and antimatter seperate.
I do know that there are attempts to create significant quantities of antimatter-hydrogen to test their gravitational properites.
Perhaps there is an unknown mechanism that keeps them from coming together, or
perhaps it was sheer luck that moments after the big bang, half of the matter was on one side, the other half on the other side, and with early inflation they separated.
Perhaps there is parity in loop quantum gravity which causes matter to be more likely to be created than antimatter.
ensabah6
...after the big bang, half of the matter was on one side, the other half on the other side, and with early inflation they separated.
I thought that the scientists had killed the big bang and replaced it with a "bounce"
and that the inflation had been replaced with "re-heating"
I'm waiting for them to annouce a new mechanism for expansion.:smile:
jal
FAQ: Are there any GUT's that do not violate baryon number?
1. What is a GUT?
A GUT, or Grand Unified Theory, is a theoretical framework that attempts to unify the fundamental forces of nature, such as electromagnetism, strong nuclear force, and weak nuclear force, into a single unified force.
2. How do GUTs relate to baryon number violation?
In GUTs, it is theorized that the strong and electroweak forces were once unified and have since separated. This separation may have led to the violation of baryon number conservation.
3. Are there any GUTs that do not violate baryon number?
Yes, there are some GUTs, such as the flipped SU(5) model, that do not violate baryon number. However, these theories are still under debate and have not been proven.
4. How do scientists test GUTs for baryon number violation?
Scientists use various experiments, such as particle accelerators, to study the fundamental forces and particles predicted by GUTs. They look for evidence of baryon number violation by observing the behavior of particles and their interactions.
5. Why is baryon number conservation important in GUTs?
Baryon number conservation is important because it is a fundamental principle in particle physics that states that the number of baryons, such as protons and neutrons, should remain constant in any particle interaction. Violation of this principle in GUTs could help explain the asymmetry between matter and antimatter in the universe.
