- #71
DrGreg
- 1,959
Dadface said:If so do a thought experiment where a heat source is placed in a closed box which is suspended from strings.If a single hole is made in the top of the box the expanding air will move out of that hole.If the hole is at the bottom the air will move out of that hole.
It is understood that the box itself must be too heavy to rise due to buoyancy. If the hot air is initially under pressure when you drill the hole, air will escape at the top or bottom simply due to the excess pressure.
Consider what happens if you drill two small holes, one at the top and one at the bottom. If there is excess pressure, then at first hot air will escape from both holes due to pressure. But after the pressure has equalised, yes, more hot air will escape from the top, but at the bottom cold air will rush into the box. How does your theory explain that?
