What makes a semiconducting material a semiconductor?
In summary, a semiconductor is a material that has a band gap and an increasing resistivity as temperature is decreased.
Ravian
42
what really makes a semiconductor? Is it just the presence of a band gap but then insulators and metals also have band gaps or carrier concentration? Or we need to perform Hall measurements and also need to study I-V characteristics? Or do we need all of these parameters to establish a material as semiconductor?
In metals you have half-filled bands, so that the fermi level is within the band. In semiconductors and insulators the fermi level is in the band gap, so at 0 K the bands are either completely filled (valence band) or completely empty (conduction band).
I think that the difference between semiconductor and insulator is that in insulators the gap is much larger than in semiconductors.
Thanks! So what sort of experimental measurements we should make in order establish a material as a semiconductor, metal or insulator? Apparently having a band gap is not enough.
One indicator is to measure how resistance changes with temperature.With intrinsic(pure) semiconductors resistance reduces with temperature.
Do a resistivity versus temperature measurement. Metals will have a decreasing resistivity with decreasing temperature, whereas a semiconductor/insulator will have an increasing resistivity with decreasing temperature.
Zz.
On a side note this property, namely decreasing resistance when the temperature is increased is used in http://en.wikipedia.org/wiki/Thermistor" .
You can test this yourself by connecting the thermistor to a multimeter:
http://www.hk-phy.org/energy/commercial/print/act_experiment_e.html
http://www.practicalphysics.org/go/Experiment_701.html
http://www.brighthub.com/engineering/mechanical/articles/27687.aspx
The way I understand it is.
Perfect Insulator: No energy band is partially filled. Relatively large amount of energy required for a particle to reach the next energy level.
Conductor: Partially filled energy band, very little energy required to move to the next highest energy level.
Semi: Highest energy band is mostly empty, band before that is almost but not full. Some particles start to gain energy and quickly reach a gap, others are free as if they were in a conductor.
1. What is a semiconductor?
A semiconductor is a material that has electrical conductivity between that of a conductor and an insulator. This means that it can conduct electricity, but not as well as a metal.
2. How is a semiconductor different from a conductor or an insulator?
A conductor has a high electrical conductivity, meaning it can easily conduct electricity. An insulator has a very low electrical conductivity, meaning it does not allow electricity to flow through it. A semiconductor's electrical conductivity falls in between these two extremes.
3. What makes a material a semiconductor?
A material is considered a semiconductor if it has a band gap, meaning there is a range of energy levels between the valence band (where electrons are tightly bound to atoms) and the conduction band (where electrons are free to move and conduct electricity). This allows the material to conduct electricity under certain conditions, but not as easily as a conductor.
4. What are some examples of semiconducting materials?
Some common semiconducting materials include silicon, germanium, and gallium arsenide. These materials are often used in electronic devices such as transistors, diodes, and solar cells.
5. How is the conductivity of a semiconductor controlled?
The conductivity of a semiconductor can be controlled by manipulating the number of electrons in the conduction band. This can be achieved through processes such as doping, where impurities are intentionally added to the material, or by applying an external electric field. This allows for the precise control and manipulation of electrical currents in electronic devices.
  • Atomic and Condensed Matter
