Relative Motion- Airplane vs radar station and tracking the displacement
In summary: The angle should be toward the west (negative angle) and down from the horizon.In summary, the airplane's displacement during this period was 1022 m in magnitude and at an angle of -63.6° relative to due west, with a positive angle being above the horizon and a negative angle being below the horizon.
emmy
37
Relative Motion-- Airplane vs radar station and tracking the displacement
In Figure 4-49, a radar station detects an airplane approaching directly from the east. At first observation, the airplane is at distance d1 = 340 m from the station and at angle θ1 = 34° above the horizon. The airplane is tracked through an angular change Δθ = 122° in the vertical east–west plane; its distance is then d2 = 800 m. Find the (a) magnitude and (b) direction of the airplane's displacement during this period. Give the direction as an angle relative to due west, with a positive angle being above the horizon and a negative angle being below the horizon.
http://edugen.wiley.com/edugen/courses/crs4957/art/qb/qu/c04/fig04_55.gif
2. The attempt at a solution
I set the vectors head to tail, where a is the vector to the original sighting, b is the vector to the second sighting. So I did this:
[PLAIN]http://i629.photobucket.com/albums/uu15/amorxamor/blahhcopy.jpg I really really really appreciate any help :c
Some odd things in the solution:
- the angle of the initial vector to the plane is given as 30 degrees but you have it marked as 34 degrees on the diagram and in the trig functions.
- the initial distance to the plane is given as 360m but you use 340 in the calcs
- d2 is given as 780, but you use 800 in the calcs
The x,y component approach should work.
Maybe easier to use the law of cosines on the triangle to answer part (a) in one step.
yeah, I got the problem wrong and it gave me new values sorry I can't believe I didn't catch that...
d1 (|a|) should be 340 m
theta 1 should be 34 degrees
delta theta should be 122 degrees
d2 (|b|)= 800m
I disagree in the last part. I think you need to subtract the two vectors rather than adding them:
-730.8i +325.4j - (281.9i + 190.1j)
The magnitude comes out to 1022 and it checks by law of cosines.
First of all, great job setting up the problem and drawing out the vectors! To find the magnitude and direction of the airplane's displacement, we can use the law of cosines:
c^2 = a^2 + b^2 - 2ab*cos(Δθ)
where c is the magnitude of the displacement. Plugging in the values from the problem, we get:
c^2 = (340)^2 + (800)^2 - 2(340)(800)*cos(122°)
c^2 = 115600 + 640000 - 435200*cos(122°)
c^2 = 755600 + 435200*cos(122°)
c^2 = 755600 + (-296734.72)
c^2 = 458865.28
Taking the square root, we get c = 677.18 m. So the magnitude of the airplane's displacement is 677.18 m.
To find the direction, we can use the law of sines:
sin(122°)/c = sin(θ2)/a
where θ2 is the angle of the displacement vector. Plugging in the values from the problem, we get:
sin(122°)/677.18 = sin(θ2)/340
sin(θ2) = (340*sin(122°))/677.18
sin(θ2) = 0.649
θ2 = sin^-1(0.649)
θ2 = 40.8°
Since we know that the displacement is in the east-west plane, we can say that the angle of the displacement vector is 40.8° relative to due west. To determine if it is above or below the horizon, we can use the fact that the angle of elevation of the airplane changes from 34° to 122°. Since 122° is greater than 90°, we know that the airplane must have moved above the horizon. Therefore, the direction of the displacement is 40.8° above the horizon.
In summary, the magnitude of the airplane's displacement is 677.18 m and the direction is 40.8° above the horizon and 40.8° relative to due west. I hope this helps!
Related to Relative Motion- Airplane vs radar station and tracking the displacement
Question 1:
What is relative motion and how does it apply to airplanes and radar stations?
Relative motion is the movement of an object in relation to another object. In the case of airplanes and radar stations, it refers to the different speeds and directions of the two objects in relation to each other. This is important for tracking the displacement between the two objects.
Question 2:
How does a radar station track the displacement of an airplane?
A radar station uses electromagnetic waves to detect the location and movement of an airplane. The radar emits a high frequency signal that bounces off the airplane and returns to the radar. By measuring the time it takes for the signal to return and the angle at which it was received, the radar can calculate the displacement of the airplane.
Question 3:
Can the relative motion between an airplane and radar station affect the accuracy of tracking the airplane's displacement?
Yes, the relative motion between the airplane and radar station can affect the accuracy of tracking. If the two objects are moving at different speeds or in different directions, it can cause errors in the calculation of displacement. This is why radar stations need to constantly adjust their tracking to account for relative motion.
Question 4:
What other factors can affect the accuracy of tracking an airplane's displacement using a radar station?
Besides relative motion, other factors that can affect the accuracy of tracking an airplane's displacement include weather conditions, radar equipment malfunctions, and human error. Heavy rain or snow can interfere with the radar signal, causing errors in tracking. Malfunctions in the radar equipment can also lead to inaccurate readings. Additionally, human error in operating the radar or interpreting the data can also affect the accuracy of tracking.
Question 5:
How does the concept of relative motion apply to air traffic control?
Air traffic control relies on the concept of relative motion to safely manage the movement of airplanes in the sky. By tracking the relative motion between airplanes and other objects, such as other airplanes or weather patterns, air traffic controllers can guide planes to maintain a safe distance from each other and avoid potential collisions.
17K
15K
