Assembly language programming?
In summary, the project is simple if you know assembly language, but there is some tricky memory concepts involved. A good website to learn assembly language is available.
mathrocks
106
I'm working on a project that I believe should be pretty simple to do if I actually knew assembly language.
For my program I'm suppose to start at data memory location 0x30 and perform the increment, decrement, complement, and clear operations. The operations are all performed on location 0x21...i.e. add 1 to location 0x21 (increment).
So given that, is this program really that simple? Or is there some tricky stuff involved?
Does anyone know of a good website to learn assembly language? And if you guys have any hints or suggestions on how I should get started with this program please help me out! I'm really just having trouble with the whole memory concepts, I'm not used to messing around with that.
Thanks!
Technology news on Phys.org
The best way to learn assembly is to use inlining. If you're using the Microsoft Visual C++ compiler, you can embed assembly into your C++ code like this:
PHP:
int multiplyByTwo(int a)
   __asm
       mov eax, a
       mul eax, 2
The return variable is left in the eax register. You can refer to C++ variables (like a) directly in the assembly instructions.
(You can inline asm with other compilers like gcc, but the syntax is much more convoluted.)
If you need a reference to the Intel x86 instruction set, the best place to go is Intel itself: ftp://download.intel.com/design/Pentium4/manuals/[/URL]
Look into the mov, inc, dec, clr and other instructions in those manuals.
If you have any more specific questions, let us know!
- Warren
in TC (if anybody is using that now)
you have
asm{
mov ax,dx
etc
gnome said:
The commands to perform those memory operations are very simple, but you need to know the overall structure of an assembly language program before you can write one. Here are a couple of links:
http://www.osdata.com/topic/language/asm.htm
http://atrevida.comprenica.com/
This is my code as of now. I'm pretty sure it's totally wrong, but logically it seems right to me, increment 0x21, decrement 0x21, complement 0x21, and then clear it? I think it's just the memory stuff that's giving me a hardtime(i hope).
list P=16F84
include P16F84.INC
; Define the direction bit types
f equ 1
w equ 0
; Define the data storage locations
org 0x20
cnt res 1;the number of instructions to execute (1<=n<=8)
acc res 1 ;the accumulator
org 0x30
prg res 8 ;location of the program
; start defining the program
; no interrupts, so start at 0x0
org 0x0
goto INC
INC
org 0x30
incf 0x21, 0
goto DEC
DEC
org 0x31
decf 0x21, 0
goto COM
COM
org 0x32
comf 0x21, 0
goto CLR
CLR
org 0x33
bcf 0x21, 7
goto endless
endless nop
goto endless
end
Ok, I'm understanding this a little better now, my other code was totally wrong.
I'm suppose to perform the operation according to the opcode. If its 0x00 I increment, 0x01-decrement, 0x02-complement, 0x03-clear. My only question now is how do I look at the bits and see if it's a 0, 1, 2, or 3? I'm sure there's a certain operation that looks at the bits but I'm not familiar with it. This is my code thus far, I hope I'm at least on the right track.
list P=16F84
include P16F84.INC
f equ 1
w equ 0
org 0x20
cnt res 1 ;the number of instructions to execute (1<=n<=8)
org 0x30
org 0x0
movlw 0x21
goto main
Main
*Check sign for 0x00*
goto INC
*Check sign for 0x01*
goto DEC
*Check sign for 0x02*
goto COM
*Check sign for 0x03*
goto CLR
INC
org 0x30
incf 0x21, w
goto main
DEC
org 0x31
decf 0x21, w
goto main
COM
org 0x32
comf 0x21, w
goto main
CLR
org 0x33
bcf 0x21, 7
goto endless
endless nop
goto endless
end
Does anyone have any suggestions?
What is that?
It doesn't look anything like the 80x86 assembly language I learned a couple of years ago.
gnome said:
What is that?
I'm using assembly language to program a PIC...PIC16F84 to be specific. I don't know, I guess it can differ?
I guess so. It's totally different. If you're curious, I can post an example of a simple TASM (that's Borland Turbo Assembler) program for 8086. (If not, I won't clutter up your thread.)
Yeah, that would be fine. I'm interested in seeing how different it is.
Here's a pretty simple example. The stuff following the semi-colons on each line are comments, so it should be fairly easy to follow what it's doing. As you can see, much of the action involves moving data into and out of cpu registers.
Code:
% TITLE 'Arithmetic/DOS functions'
	IDEAL
	MODEL small
	STACK 100h
; equates
CR	equ	13
LF	equ	10
delimiter equ	'$'
	DATASEG
n1	dw	200
n2	dw	?
n3	dw	?
temp	dw	?
x	db	10
y	db	20
z	db	?
c	db	?
msg1	db	CR,LF," input a character",CR,LF,CR,LF,DELIMITER
msg2	db	"you pressed the character :  ",DELIMITER
msg3	db	"now the character is :  ",DELIMITER
	CODESEG
START:
	mov	ax,@data
	mov	ds,ax
	mov	ax,[n1]	;ax=n1
	sub	ax,25	;ax=ax-25 (=n1-25)
	mov	[n2],ax	;now n2=n1-25
	mov	ax,1	;ax=1
	sub	[n1],ax	;n1=n1-ax (=n1-1)
	mov	ax,[n1]	;ax=n1
	add	ax,[n2]	;ax=ax+n2 (=n1+n2)
	mov	[n3],ax	;n3=ax (=n1+n2)
	sub	[n3],10	;n3=n3-10 (=n1+n2-10)
	mov	ax,[n1]	;ax=n1
	mov	[temp],ax ;temp=ax (=n1)
	mov	bx,[n2]	;bx=n2
	mov	[n1],bx	;n1=bx (=n2)
	mov	[n2],ax	;n2=ax (=temp)
	mov	ah,[x]	;ah=x
	mov	al,[y]	;al=y
	sub	al,ah	;al=al-ah (=y-x)
	mov	ah,00	;ah=0
	mov	[n3],ax	;n3=ax (=(int)y-x)
	sub	[n3],1	;n3=(int)y-x-1)
	mov	ah,9	;storing DOS string output function# in ah
	mov	dx,OFFSET msg1	;stores label of string to print in dx
	int	21h	;DOS call
	mov	ah,1	;storing DOS key input function# in ah
	int	21h	;DOS call
	mov	[c],al	;retrieve char input from al register
	mov	dx,OFFSET msg2	;stores label of string to print in dx
	int	21h	;DOS call
	mov	ah,2	;DOS char output function#
	mov	dl,[c]	;storing char to output in dl
	int	21h	;DOS call
	mov	dl,CR	;storing ASCII CR code in dl (function# 2 is already in ah)
	int	21h	;DOS call
	mov	dl,LF	;storing ASCII LF code in dl (function# 2 is already in ah)
	int	21h	;DOS call
	mov	bx,OFFSET c	;stores address of c in bx
	mov	al,[x]	;copies x to al (al=x)
	add	[bx],al	;add al to c (c=c+al) ([bx] is pointer to c)
	sub	[byte ptr bx],7	;subt 7 from c (c=c-7) ([bx] is pointer to c)
	mov	ah,9	;DOS string output function#
	mov	dx,OFFSET msg3	;stores label of string to print in dx
	int	21h	;DOS call
	mov	dl,[c]	;stores char to output (c) in dl
	int	21h	;DOS call
	mov	ah,4ch	;stores DOS terminate program function# in ah
	int	21h	;DOS call
	END	START
mathrocks said:
how do I look at the bits and see if it's a 0, 1, 2, or 3?Does anyone have any suggestions?
I don't know that particular uP, but you can always use an AND instruction to test bits.
like:
AND data1,11111101b
jump_not_zero The_number_is_not_two
AND data1,00000010b
jump_not_zero Only_bit_2_on /* the value is two */
jump_zero The_value_is_zero
Notes:
Some uP will require a separate move to work register for data1.
This example requires two such moves since the first test is destructive.
Other uP put the result in a work register.
In this case the test is not destructive.
Almost all uP will set the zero flag on an AND without a separate compare instruction.
You need to learn the available instructions in order to be effcient.
Some uP have specific instructions to test bits.
...and most people (including me) will assume that you're talking about x86 assembly unless you specify otherwise. :smile:
- Warren
Take Chroot’s recommendation and go to Intel and read their manual. Whether it is worth your while learning an assembly language depends on your interests, your job, and the people you will be working with. If you are working with engineers building embedded systems, or designing embedded system yourself, I’d say it would be a very good idea to be familiar with the assembly language of the microcontrollers that you or they are working with.
Sorry...The above response was to another thread that I pasted in the wrong place..
i don't really know, one thing that's amazing is that i know assembly and I am only 11. Here are sites i visited to help, Art of assembly, emu8086, fasm, osdev, intel. But who cares what sites. did you know i learned some imaginary assembly then i jmped when i saw real assembly(not real-mode, x86 assembly)
I need a list of all IO port numbers
First: Don't hijack threads; start a new one for a new topic.
Second: See RBIL or HelpPC.
Related to Assembly language programming?
1. What is assembly language programming?
Assembly language programming is a low-level programming language that is used to directly communicate with a computer's hardware. It is considered a low-level language because it is closer to the machine code that the computer understands, making it more difficult to read and write than high-level languages.
2. What are the benefits of using assembly language programming?
One of the main benefits of assembly language programming is its efficiency and speed. Since it is closely tied to the computer's hardware, programs written in assembly language can be executed quickly. It also allows for precise control over memory and other system resources, making it useful for tasks such as device drivers and operating systems.
3. Is it necessary to learn assembly language programming?
It is not necessary for most programmers to learn assembly language, as there are higher-level languages that can accomplish the same tasks with less effort. However, for tasks that require optimal performance or direct hardware access, knowing assembly language can be beneficial.
4. What are some common applications of assembly language programming?
Assembly language is commonly used in embedded systems, device drivers, and operating systems. It is also used in reverse engineering and security research, as it allows for direct manipulation of the hardware.
5. What are some challenges of programming in assembly language?
One of the main challenges of assembly language programming is its complexity and steep learning curve. As it is a low-level language, programmers must have a deep understanding of computer architecture and memory management. Additionally, programs written in assembly language are not easily portable and may need to be rewritten for different hardware or operating systems.
13K
15K
