Our weight if the earth spins faster
In summary, the faster spinning of the Earth would have a slight effect on our weight, with those living closer to the equator experiencing a slightly lower weight due to centrifugal force. However, the Earth's oblateness and its ability to hold its shape counteract this effect, resulting in a small increase in weight for those living at the poles. The change in the Earth's shape also affects the Earth's angular velocity, further impacting the centripetal acceleration at the equator. In conclusion, there are multiple factors involved in determining our weight on Earth, and the effect of the Earth's rotation is minimal.
PhysicoRaj
49
Our weight if the Earth spins faster...
I came up with this problem in a competition. They asked what would be the effect on our weight on the Earth if the Earth spun any faster.
Thinking deep, I came up to a conclusion that people who live nearer to the equator than to the poles find their weight reduced since any faster spinning of the Earth would push us slightly out, due to centrifugal force. Am i right?? would there be anymore effect??
Astronomy news on Phys.org
Yes, you would weigh slightly less at the poles than at the equator due to centripetal force. Acceleration due to gravity is reduced by about 0.03 m/s^2. You are also slightly closer to the center of the Earth at the poles - also due to the Earth's rotation [it causes the Earth to bulge a bit]. The net effect is a difference of about 0.05 m/s^2 between the equator and poles - meaning a sumo wrestler who weighs 200 kg at the south pole would weigh a mere 199 kg in Padang, Indonesia.
But isn't it just the opposite of it? We weigh less at the equator due to 2 reasons: firstly, g varies and secondly due to centrifugal force (inertia) of Earth's rotation.
Hey - i think we weigh less at equator
As already mentioned - firstly due to the fictitious centrifugal force and also because Earth's a bit more outwards at the equator
So, the reasoning that the faster spinning of Earth would lighten us is correct?
A dyslexic moment. Less at the equator, as asserted by the rest of my post.
So there are two factors involved in making us weigh more at the poles.
1. We are closer to Earth's center due to the Earth's oblateness
2. There is less centripedal force hurling us outward at the poles.
Excerpt
Taking into account both of the above effects, the gravitational acceleration is 9.78 m/s2 at the equator and 9.83 m/s2 at the poles, so you weigh about 0.5% more at the poles than at the equator.
http://curious.astro.cornell.edu/question.php?number=310
Thanks.
I wonder if the centripetal acceleration actually contributes as much as v2/r? I could see this if Earth were perfectly rigid, and able to hold its spherical shape. But it can't. That's why it bulges. So not only is v2/r happening to a person standing on the equator, but its also happening to the ground they are standing on, negating most or all of the effect.
That's quite a stumping reasoning...it can be verified experimentally too..
It is almost perfectly rigid, else we would have humongous earthquakes.
So it's not perfectly spherical, but it does hold its current shape perfectly.
It depends on what you mean.
If we use the formula [itex]\omega^2 r[/itex] for the centripetal acceleration instead, we can look at it this way:
As long as we are considering the Earth as it is, Then the angular velocity stays the same as we move from pole to equator, r increases, and the fact that the Earth bulges at the Equator only has the effect of increasing the maximum value of r. In this case, the formula does give us the full value of the centripetal acceleration. This is because the bulge is not actively changing.
On the other hand, assume you start with a rigid spherical Earth, and then left it "soften" so that it forms an equatorial bulge. As it does so, Its moment of inertia increases, and in order to conserve angular momentum, its angular velocity goes down. The decrease in angular velocity has a larger effect than the increase of radius and the centripetal acceleration at the Equator goes down. But this a comparison made between pre and post bulge formation. It is the change in the bulge that causes the decrease.
As far as I can tell, this discussion deals with the Earth "as is", in which case, the formula holds.
1. How does the Earth's rotation affect our weight?
The Earth's rotation does not directly affect our weight. Our weight is determined by the Earth's gravitational pull, which remains constant regardless of its rotation speed.
2. Does the Earth's rotation impact the force of gravity?
No, the force of gravity is a constant and is not affected by the Earth's rotation. It is determined by the mass of the Earth and the distance between the Earth and an object.
3. Would we weigh more or less if the Earth spun faster?
Our weight would not change if the Earth spun faster. As mentioned, our weight is determined by the Earth's gravitational pull, which remains constant regardless of its rotation speed.
4. Is there a connection between the Earth's rotation and our weight?
There is no direct connection between the Earth's rotation and our weight. Our weight is determined by the Earth's mass and gravity, while the Earth's rotation is affected by factors such as its tilt and orbit around the sun.
5. Does the Earth's rotation affect our body's mass and composition?
No, the Earth's rotation does not have any impact on our body's mass and composition. These factors are determined by our genetics, diet, and lifestyle choices.
  • Astronomy and Astrophysics
  • Earth Sciences
10K
