Orthologous vs Paralogous genes
  • Thread starter BoundByAxioms
  • Tags
    Genes
In summary, paralogy refers to duplication while orthology refers to separation by speciation. Paralogous genes are those that arose from a common ancestor and are present in the same genome, while orthologous genes are genes that have the same function in different species. Orthology is used to describe the relationship between genes, while paralogy is used to describe the relationship between genes and their duplication.
BoundByAxioms
99
I am having trouble wrapping my mind around these concepts. Can anyone explain them clearly, and in relatively simple terms?
Biology news on Phys.org
Orthologuous means proteins that have the same function in different species and that may or may not have arisen from a common ancestor.
Paralogous means genes that have arisen from a common ancestor and are present in the same genome. Pararolgue may or may not have the same function.
Ortho same function different species, para common ancestor one species.
Great, thank you!
Actually paralogy or orthology do not refer to function and only to a limited amount on the occurrence within or between species, but rather to the mode they were separated.
Both concepts, homology and orthology assume a relatedness of the genes, meaning that they are always derived from common ancestors. In other words, you can trace both back to an ancestor in phylogenetic tree. The way the divergence of any two genes can be traced back defines whether they are paralogous or orthologous to each other.
Orthologous genes diverge by speciation events, whereas paralogous genes are the result of gene duplication.
Well lots of people had this question, so my professor reiterated these ideas in class.
Orthologous genes are genes that are passed from one generation to the next; these genes may be found in separate gene pools due to speciation.
Paralogous genes are genes that are duplicated, by chance, but remain in the same genome. Then, if one of the copies begin to change and mutate, a new, favorable trait may arise. The original function of the gene is still being carried out, however, due to the copy of the gene that did not change.
Hmm while partially correct, it is not used in the sense in which the term was coined (depends on what precisely was said though, maybe a bit was misinterpreted).
Again: orthology refers to a separation by speciation. This means that it refers to two genes in two different species that derive from a single gene of the last common ancestor
For instance a species 1 (S1) splits into two species: S2 and S3.
S1 carries a gene A. S2 got a copy of this gene (gene A2) and S3 got a copy (gene A3). Gene A2 and A3 are orthologs of each other.
Paralogy is more complicated, it refers to separation by duplication, but it can happen either before, or after speciation. In other words, it can be found in a single genome, but it does not has to be.
Let us take the above scenario, gene A2 gets duplicated. We then got gene A2, gene B2 (its duplicate) and finally gene A3 (from species S3). Here gene A2 and B2 would be paralogs, whereas both would be an ortholog of gene A3.
But we can do more complicated. Let us assume that in the last common ancestor of species 2 and 3 there is a duplication event resulting in the paralogous genes X and y Now assume three species each carrying one of those copies, e.g. species 1 carries gene X, S2 gene Y and so on. despite the speciation, gene X and Y would be considered paralogs, as their split was due to a duplication event.
As you can imagine in very complicated trees it is hard if not impossible to really trace down the relationship between any two genes. Moreover, while it has been sometimes added to the definition, the function has in reality nothing to do with the classification as orthologs or paralogs. While in some cases orthology correlates with function, in many more other cases (transcription factors are notorious for that) it does not.
In any case, the original definition only tracks back their relationship, not their functions.
FAQ: Orthologous vs Paralogous genes
What are orthologous genes?
Orthologous genes are genes that are found in different species and have a common ancestor. They have a similar sequence and perform the same function in each species.
What are paralogous genes?
Paralogous genes are genes that are found within the same species and have arisen from gene duplication events. They have a similar sequence but may have diverged in function.
How do orthologous genes differ from paralogous genes?
Orthologous genes are found in different species, while paralogous genes are found within the same species. Additionally, orthologous genes have a common ancestor and perform the same function, while paralogous genes have arisen from gene duplication events and may have diverged in function.
Why is it important to distinguish between orthologous and paralogous genes?
Distinguishing between orthologous and paralogous genes is important for understanding the evolutionary relationships between species and how genes have evolved over time. It also helps in predicting gene function and identifying potential drug targets.
How are orthologous and paralogous genes identified?
Orthologous genes can be identified through sequence similarity and phylogenetic analysis, while paralogous genes can be identified through sequence similarity and gene duplication events. Other methods such as synteny analysis and functional studies can also be used to confirm the orthologous or paralogous relationship between genes.
