Feynman's QED Lectures: Questions about partial reflection
In summary, Feynman describes partial reflection using the concept of "little arrows" that cancel out when the glass is a certain thickness. This means that the arrow corresponding to the shorter path is in the opposite direction of the arrow corresponding to the longer path, resulting in a net amplitude of zero. This is a fundamental concept in quantum mechanics, where the spinning arrow represents the oscillation of a wave and the wavefunction is the probability amplitude. This can also be used to explain the interference patterns observed in the double-slit experiment.
STS816
43
In Feynman's lectures he describes partial reflection as occurring because the "little arrows" cancel out when the glass is certain thickness. I realize that there isn't an actual model of how QED works but what exactly does he mean by "cancel out"?
Also when do you shrink and turn the little arrows and when do you "add" them together, head to tail? Do you shrink and turn arrows until you get a final arrow and then proceed to "add" several final arrows together? If so, does that mean that shrink and turning arrows gets you one step(i.e. whether a photon is reflected or transmitted) in an event(i.e. whether a photon will pass through a pane of glass)?
Thanks for the help. And FYI, I'll more than likely be back with more questions as I read more :).
EDIT:4 minutes after my original post and I already have another question lol. Feynman states that an electron "orbits" a proton in a hydrogen atom because the two are continuously exchanging photons. In his diagram, however, I can't find any path of a photon that would "push" the electron towards the proton. All of his pathes seem like they should "push" the electron away, not toward, the proton. I have a sneeking suspicion that this has something to do with positrons traveling backward in time but I'm not sure. Once again,thanks for the help.
It just means that the arrow associated with the shorter path (reflection off the front surface) is in the opposite direction of the arrow associated with the longer path (reflection off the back surface), so they add up to zero.
You add the amplitudes of different paths from event A to event B to get the amplitude for detection at B given emission at A. I'm not sure what shrinking and turning you're referring to.
I don't know if there's any way to see that an interaction that can be described as an exchange of virtual particles can be attractive, other than doing the QFT calculations explictly, but maybe someone else has a better answer.
I don't understand one thing. Why the two arrows, one corresponding to front reflection and the other to back reflection, are subtracted and not added?
Follow my argument.
If the angle difference between the stopwatch hands is phi, then from what says Feynman, the percentage of the reflected light would be:
P=0.16*cos( (pi-phi)/2 )^2 .
But from the theory of interference we have that intensity of the sum of two plane waves with phase difference delta is:
I=2*I_0( 1 + cos(delta) )
Where I_0 is the intensity of each of the two reflected waves. It should be I_0=0.04, since 4 percent of the light is reflected.
If we want that P=I, then the following relation should be valid:
phi+delta = pi.
But this would mean that the angle phi between the two hands is not the phase difference delta.
Somewhere in these considerations I'm definitely wrong. Where do I do a mistake? Or at least how to show that Feynman's stopwatch approach is equivalent to simple interference? For example, how to show with classical interference methods that there is almost no reflection from a very very thin film?
Ok. I guess, I found the answer myself. Everything is well, when we account for the phase change by pi after reflection from optically densier medium :)
Well it is the actual model of quantum mechanics. Think of the spinning arrow as tracing out the oscillation of a wave. This wave is the probability amplitude i.e. the wavefunction
I am not sure that I understand what you mean by "tracing out".
Could the doubleslit experiment, i.e. the interference pattern on the back wall, be modeled by a figure of Feynman arrows? I suppose the areas of destructive inteference should have a wide array of arrows changing fast and cancelling each other out, and the constructive areas more slowly changing arrows that (mostly) add up to a length larger than zero?
1. What is partial reflection in Feynman's QED Lectures?
Partial reflection in Feynman's QED Lectures refers to the phenomenon where a light ray hits a surface at an angle and only a portion of the ray is reflected, while the rest is transmitted through the surface.
2. How is partial reflection explained in Feynman's QED Lectures?
In Feynman's QED Lectures, partial reflection is explained through the concept of virtual particles. When a light ray hits a surface, it interacts with virtual particles that are constantly popping in and out of existence. The interactions between these particles determine the amount of light that is reflected and transmitted.
3. What is the significance of partial reflection in Feynman's QED Lectures?
Partial reflection is significant in Feynman's QED Lectures because it helps explain the behavior of light at a microscopic level. It shows how virtual particles play a role in the reflection and transmission of light, providing a deeper understanding of the physics behind these phenomena.
4. Can partial reflection be observed in real-life situations?
Yes, partial reflection can be observed in real-life situations. For example, when looking at a glass window from an angle, you can see a reflection of yourself and the objects behind you, but you can also see through the window to the objects on the other side. This is due to the partial reflection of light on the glass surface.
5. How does partial reflection relate to the larger concepts of quantum electrodynamics?
Partial reflection is one of the many phenomena that can be explained through the principles of quantum electrodynamics (QED). QED is a theory that explains the behavior of light and matter at a subatomic level, including the interactions between particles and the role of virtual particles. Partial reflection is just one example of how QED can be used to understand and predict the behavior of light.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
