- #71
PeterDonis
Mentor
- 47,097
- 23,483
TrickyDicky said:Well the thing is in many GR texts the non-linearity of the EFE is attributed precisely to the very thing you are dismissing here as unnecessary or irrelevant for the physics:The gravitational field energy behaviour and the "gravity gravitates" issue. So they must have a different idea , or at least broader of what the physics of GR is.
Without seeing some specific references, I can't say for sure, but I strongly suspect that nothing in the texts you refer to about the nonlinearity of the EFE is in any way inconsistent with what I am saying. But let me try to clarify a bit more how I think "nonlinearity" fits in.
Mathematically, "nonlinearity" simply means that solutions to the EFE can't be superposed: you can't take two solutions, add them together, and get another solution. This is why, for example, the two-body problem can't be solved by simply adding together two one-body Schwarzschild metrics centered on different points: the result is not a solution of the EFE.
Physically, what this means is that fields from different "sources" (where "source" is to be interpreted, strictly speaking, in the precise way I have said: nonzero SET regions in the past light cone) don't just add together: they "reinforce" each other, so to speak. I put "reinforce" in scare-quotes because that word is likely to raise further questions about whether gravity gravitates, etc. So a more precise way of saying it would be: the law that governs how the field "propagates" from multiple sources cannot be derived just by "adding together" multiple copies of the law that governs how the field "propagates" from a single source. The law of field propagation can't be "broken up into pieces" like that. There is nothing physically mysterious about this; it just happens to be the way the law of "field propagation" (the EFE) is structured. The main impact it has is to make it much harder to come up with solutions for spacetimes with multiple sources, because you can't take any shortcuts; you have to look at *all* the sources in the spacetime, all at once, and arrive at a *single* solution to the EFE that takes them all into account. And in doing so, you don't have to add any "extra" sources corresponding to "gravity gravitating"; everything is determined by the standard (nonzero SET) sources.
TrickyDicky said:Dark energy in its most accepted interpretation, that which is compatible with GR, is thought to be precisely a repulsive gravitational field, and as you admit it is a nonzero SET. But you insist that the usual attractive gravitational field doesn't count as SET source, while the standard view is that precisely the fact that gravity gravitates is what makes the EFE non-linear.
The fact that the particular form of the SET that is associated with dark energy happens to create a spacetime which can be viewed as having "repulsive gravity" is a *derived* phenomenon; it is not fundamental. The precise fundamental definition of "dark energy" is just what I said before: the SET is proportional to the metric. That's all. (Btw, dark energy only creates "repulsive gravity" if its SET is a positive number times the metric; if it is a negative number times the metric, such as as negative cosmological constant, the "gravity" it creates is attractive.)
Similar remarks apply to what you are calling "the usual attractive gravitational field"; the fact that it is attractive is a *derived* phenomenon, not a fundamental piece of the physics. The fundamental physics is that the SET of "ordinary" matter or energy (e.g., a perfect fluid or EM radiation) always turns out to obey a number of energy conditions; the strong energy condition is, IIRC, the most important one (since it's the one that, for example, a "dark energy" SET violates). The EFE then ensures that any SET obeying these conditions will produce "attractive" gravity.
(And "gravity gravitates" is an approximate way of looking at a *different* piece of the physics still--the fact that, as I said above, solutions to the EFE can't be superposed. You appear to agree that this is what "gravity gravitates" refers to. But an "attractive gravitational field" can be present even when there is only one "source"--one region of nonzero SET--in the spacetime--which of course is the most commonly analyzed case.)
(It's also worth mentioning that "attractive gravity" vs. "repulsive gravity" is only a portion of the full curvature of the spacetime; there are also tidal effects that can vary in different directions.)
