Can i kill milk bacteria in a microwave
In summary: If you put the milk in a microwave oven, it's possible that the microwaves could cause it to heat too quickly and cause it to break down.
grannydrums
Hi,
I am about to start making bulgarian yoghurt with unpaseurised gersey milk. The food forums say that the bacteria in the milk will compete with the yoghurt bacteria and so should be reduced (not necesserilly killed altogether) without destroying the enzimes and milk protiens.
In bulgaria the traditional way is to lightly simmer for an hour. The food forums have all sorts of different ideas what to do. I thought a scientist might be able to advise me better than foodies.
Would putting the milk in a microwave kill the bacteria without destroying the good stuff? Should I use a low setting for a long time? I would be making a litre at a time.
if i had to use a stove instead, how long should i boil it and what temperature is best to achieve my aim??
Biology news on Phys.org
I don't think there is a difference between using microwave and stove - in both cases what kills the bacteria is the elevated temperature.
yeah, both heat, but microwaves tend to heat the top more than the bottom - uneven heating, so I would stir it often (the top usually gets really hot and foams up and spills out while the bottom is still cold) and heat it until its all hot.
On a stove it is much easier to control the heat and monitor the process. As said, it is the heat that kills the bacteria, there is nothing magical that happens in a microwave that would preserve the regular milk proteins.
What do you mean "destroying" the enzymes and proteins?
In a microwave, or on a stove, they will at most denaturate. They still have the same nutritional content (i.e. amino acids).
I think the OP is referring to vitamin content. Cooking does degrade some vitamins, so does a microwave.
This article asserts that there is a positive effect of consuming live culture yogurts, the benefit (creation of new micronutrients) varies with the variety of the LAB used to make the yogurt. Since the bacteria in yogurt grow post-heating, getting rid of other bacteria is essential to making quality yogurt. The yogurt bacteria don't need competition.
http://www.ajcn.org/cgi/content/full/80/2/245
grannydrums said:
Hi,
I think you are getting conflicting answers because heating will both degrade vitamins and proteins as well as kill bacteria.
Side note- is 100 C really high enough to kill bacteria? AFAIK, food processing occurs at higher temperatures (pressure cookers), in the presence of acid or salt (water bath canning), or some other extra biocide-thingy.
In principle, there's no substantive difference between bringing milk to a boil in the microwave or on a stove. Processing times may vary, tho.
Monique said:
As said, it is the heat that kills the bacteria, .
Ok I understand the basis for this comment in light of the fact that the bacteria is immersed in lots of liquid. Would it be true if it were in a sponge/ dish cloth that were dry. Would the microwave energy not focus on the "molecules" in the bacteria?
Cells are full of water, that is they have an aqueous cytoplasm. Regardless of the medium, microwaves "heat" water molecules. The microwave doesn't care if this is water in a cell or water in a drink.
The heat from that is what kills the bacteria, in the case of the microwave, you're just heating them from the "inside".
I think one other element here is that you have all of the "downsides" of a stove top from your perspective, but there's one other issue:
Uneven heating. You might actually have to cook that sucker more than you think to get what you would with a brief pasteurization. I suggest a pressure cooker for ease and speed, but you can't have it both ways: you get it raw, or not.
I've never made yogurt... intentionally... but couldn't you just get pasteurized milk and inoculate it with the proper amount of the bacteria you want? When you "skim" or "fatten" milk, first the whole mess is separated, then combined and homogenized for precision. Why start with something you need to reduce, when you can ADD precisely?
I think there's something else you might want to consider.
The reason why you simmer the milk, on the stove, as opposed to letting it boil, is because the milk might curdle if you boil it too long. This is because of the Casein protein in mammalian milk.
Since the microwave is going to be difficult to control... I just recommend doing it the old fashioned way. The results will be better I think since you have better control.
Milk pasteurization is usually done below boiling point (or for a very short time) to prevent this curdling.
Oh that would be so unpleasant: a mixture of curdled or scorched milk, and cold spots. If it's going to be this milk, your method with a make-shift double boiler sounds like it would be the safest bet.
Related to Can i kill milk bacteria in a microwave
1. Can microwaving milk kill bacteria?
Yes, microwaving milk can kill bacteria, but it is not a guaranteed method of sterilization. Some bacteria may survive the microwave heat and continue to grow once the milk cools down. It is recommended to heat milk to at least 165°F (74°C) to kill most bacteria.
2. How long do I need to microwave milk to kill bacteria?
The time needed to kill bacteria in milk can vary depending on the power of your microwave and the volume of milk being heated. It is recommended to heat milk for at least 1-2 minutes on high power.
3. Can I use a microwave to pasteurize milk?
No, microwaving milk is not a suitable method for pasteurization. Pasteurization requires precise temperatures and heating times to effectively kill bacteria, which cannot be achieved in a microwave. It is best to purchase pasteurized milk from a store.
4. Is it safe to drink microwaved milk?
As long as the milk has been heated to at least 165°F (74°C), it should be safe to drink. However, it is important to note that microwaving can create hot spots in the milk, which can lead to burns if not stirred before consumption.
5. Can I reheat milk in the microwave multiple times?
It is not recommended to reheat milk multiple times in the microwave. Each time milk is reheated, it can create a breeding ground for bacteria to grow. It is safer to only heat the amount of milk you plan to consume and discard any leftovers.
32K
  • General Discussion
9K
