In magnetism, what is the difference between the B and H fields?
In summary: The first thing to do is to guess at the magnitude of the induced magnetization (assuming that it exists at all), and then use that to weight the contributions from the free and bound fields.In summary, the difference between the B and H fields is that the B field is the magnetic induction field (created by changing electric fields) and the H field is the field that's induced by the B field. The B and H fields are the same field away from matter, but in or near matter the matter soaks up some of the B, and all we measure is what's left, the H.
  • #71
What's the advantage?
  • #72
Why have the [itex]\mu_0[/itex] in one equation, but not in the other (post 70)? Why give the field vector due to bound currents a different unit from the field vector due to free currents?
  • #73
I think one good answer is that I've given in #69. In other words, magnetic field and magnetization are different quantities with different meaning, use and therefore different units.
Suppose we defined magnetization in the way you suggest. What benefit is there in calling magnetization ##\mathbf M## a quantity which does not give average magnetic moment of element, but gives ##\mu_0## times that magnetic moment?
  • #74
Yes, I agree that you'd lose the interpretation of M as mean magnetic moment per unit volume - but not if the magnitude of magnetic moment for a current loop had been defined as [itex]\mu_{0} I \Delta S[/itex] rather than [itex] I \Delta S[/itex] in the first place (Georgi?)! At this stage, I hear howls of protest!
  • #75
So you see it, such definition puts the awkward constant ##\mu_0## into another equation. It is equally bad as the SI convention.
I think the best thing to do is to stick to SI when talking to general audience, and to use whatever system suits you in your own research. I like the convention where only ##c## appears in the Maxwell equations and no crazy ##\epsilon_0,\mu_0## appears at all. But when communicating with others, the ugly SI convention is beneficial because it is widely known and accepted.
  • #76
To the contrary of the previous opinions I consider the use of the SI in theoretical electrodynamics a desease ;-)). Even Jackson in his newest 4th German edition of his textbook commits this sin, only to change back to Gaussian units in the part on the relativistic formulation. My reasons are the following:
There is only one electromagnetic field. Introducing a (local) inertial reference frame with corresponding space-time basis vectors you can split it in electric and magnetic components. Why should those have different units? Of course there is no contradiction in introducing different units for all kinds of things as the SI shows, but IMHO it obscures the physics of the electromagnetic field.
The macroscopic fields [itex]\vec{D}[/itex] and [itex]\vec{H}[/itex] are emergent quantities that can be derived by averaging over the microscopic fundamental quantities as are charge-current densities and magnetization of the fundamental consituents ("elementary particles") of matter. Thus there is no need either to introduce new units for those fields. The physics of the matter is hidden in the constitutive relations, which usually are given in linear-response approximation (see Jackson's or Schwinger's books on this; I'm not aware that there is a textbook writing the relations in relativistically covariant form, which is another great sin in didactics of theoretical electromagnetism, but that's another story).
So I prefer to use rationalized Heaviside-Lorentz units as is the standard in theoretical high-energy physics.
  • #77
I don't think either of us (Jano L. or I) were trying to defend SI for use in theoretical electrodynamics.
  • #78
SI unit system is a very good one. I used cgs system when I worked in transformer/inductor/magnetics design in the first half of the 80's. The cgs system has its drawbacks as well. The permeability and permittivity of free space is "1", without any units. Also, speed of light in relation to mu and epsilon works great in SI system. I don't understand why anyone would say that SI is sub-optimal. It is rationalized, it accounts for important phenomena, and to me cgs is inferior. But maybe there are compelling reasons to favor cgs that I do not know. Anyway my 2 cents.
Claude
  • #79
It is interesting that you find bad what I'd call a good thing about the traditional Gaussian units ;-). I think it's a good thing not to introduce superfluous "constants". Why should the (classical) vacuum have another permeability and permittivity than 1? The classical vacuum is really empty after all, and why should there be anything to be polarized, i.e., react to the electromagnetic field.
I agree that the unrationalized nature of the traditional Gaussian units, i.e., the appearance of (superfluous ;-)) factors of [itex]4 \pi[/itex] in the fundamental equations is not nice either, but there is no problem to use rationalized Heaviside-Lorentz units as is common in theoretical HEP.
Of course, the SI is the right choice for experimental physics and engineering, because it gives nicely handable numbers for everyday situations, i.e., 1 V and 1 A are common everyday voltages and currents, respectively. You'd also not give your height in fm or your weight in GeV ;-).
  • #80
It depends on what is it you are trying to do with the unit system. For basic lab measurements of macroscopic properties SI is great. In theoretical physics, sometimes one deals with such involved calculations that obscuring relativistic nature of the theory by using the asymmetric SI convention for units of E, B is not reasonable.
  • #81
Bold quote - "Why should vacuum have permeability/permittivity other than 1 since it is empty?" Good question. It deserves a good answer. Remember that I approach this world from an engineering viewpoint. I make widgets and things that function, so I value μ and ε being a physical constant with units.
If I place 2 conducting plates, flat rectangles with area "A", apart with a gap "g", I know that to compute capacitance I use:
C = ε0A/g.
Though the medium between the plats is air (or vacuum), it still possesses energy storage ability with units. An empty space between the plates stores energy in the form of an E field. A similar scenario holds for inductors with air (vacuum) core. The energy storage ability, electric and/or magnetic, using vacuum as a core/dielectric, has units and constants.
To a theoretical scientist this property may not be as relevant as it is to me, but as I've stated, I cannot fathom how anyone can say that SI is not pure enough. Units are man made and arbitrary, I don't know that there is one "right" way to define them. Comments welcome.
Claude
  • #82
Sure, but if there is an electromagnetic field, it's not vacuum but there is a field, and it has energy. Why do you need some [itex]\epsilon_0[/itex] there? The capacitance is (neglecting finite-size effects) [itex]C=\epsilon_0 A/d[/itex], where [itex]A[/itex] is the area of the plates and [itex]d[/itex] the distance of the plates. In Heaviside-Lorentz units [itex]\epsilon_0=1[/itex] and the capacitance is measured in centimetres instead of Farad. So what?
  • #83
Wow, that was a point I was going to make, that capacitance in cgs is measured in "cm", and I feel that is horrendous. You say "so what" as in "no big deal". Frankly, I have an issue with a centimeter being both a unit of length and a unit of capacitance. This makes little sense. But like I said, I'm not a theoritician, I invent widgets, so what is convenient for me may not be for others.
Either system works, and a highly skilled practitioner should be able to use either and get the right answer. Just thought I'd mention it.
Claude
  • #84
The book 'Electromagnetic theory' by Attay Kovetz has a section (23) on relativistic response functions. Incidentally although Kovetz's book is mostly on macroscopic electromagnetism, its definitions of P and M as 'charge-current potentials' agree with the microscopic definitions given in post 46 of this thread and no averaging over microscopic scales is used.
Francis Chen in the preface of his book on plasma physics says:
"It is, of course, senseless to argue about units; any experienced physicist can defend his favorite system eloquently and with faultless logic."
An interesting argument for E and B having different dimensions is given here http://arxiv.org/abs/physics/0407022.
  • #85
It's of course true. Physics is independent of the system of units used, but there are units that are more natural than others. Of course there is no objective reasoning for the preference of the one or the other system, but I think the SI makes electromagnetism more difficult to learn than Gaussian or Heaviside-Lorentz units.
I further don't understand in which sense you do not need averaging (coarse graining) to go from the microscopic description (QED) to a macroscopic approximation (classical macroscopic electrodynamics). Also the quantities in post #46 only make sense to me in a macroscopic picture. In the microscopic formalism all these quantities are represented by operators! The book by Craig mentions the usual coarse-graining argument already on page 5!
  • #86
My EM professor explained that he preferred Gaussian units in EM for much the same reasons he (and a score of others) preferred natural units in SR/GR; we used Gaussian units throughout the class and to be honest it made everything so much more elegant. Practicality of course is an entirely different story.
  • #87
I believe the microscopic magnetization in iron for example can be measured by spin-polarized neutron scattering. My reference is the article 'The microscopic magnetization: concept and application' by L.L. Hirst which begins by discussing the view that magnetization is a macroscopic quantity defined by averaging.
  • #88
Also worth noting is that in cgs system, which I consider a good system (not the best), not only is capacitance expressed in cm, but so is inductance as well. So we have length, inductance, and capacitance all expressed in the same units.
They are not the same entity at all. While L & C are closely related, I think that they are distinct from length. L & C behave differently, they exhibit markedly different circuit characteristics. To fully distinguish them differing units are needed.
Like I said, I've used cgs in magnetics design and consistently arrived at the correct answer. But SI for me makes more sense to a widget designer who works in industry, not a theoretical research lab. To me, I like the distinction between H & B. They are both important and neither is "derived" from the other. In Halliday-Resnick elementary physics, the authors stated that the decision to treat B as the basis, and regard H as derived from B, is purely arbitrary. I concur.
Neither is the more "fundamental" at all. Our universe consists of free space as well as molecular structures and quantized atomic energy levels. Polarization, electric or magnetic, is just as "real" as a vacuum. Besides, more than one poster has attempted to propagate the crackpot heresy that B is the counterpart of E, while H is that to D. This is nonsense.
The problem is that E behaves like B in one respect, relativity frame transformations show that E corresponds with vXB. Likewise D with vXH. Same units. So in 1 respect, B appears to correlate with E and H with D.
But there are 2 cases where it is the opposite. If we energize a dielectric capacitor, we get the D-E hysteresis curve. If E is taken down to zero, D remains, as well as remnant energy. The D represents the polarization or remnance.
But in the magnetic domain, if we energize a ferrous core with current, we get the B-H hysteresis curve. When the current is taken down to zero, it is H that vanishes. In the dielectric cap case, it was E that vanished. The remnance and stored energy is B, not H. So in the 2 cases, external power is cut, the vanished quantities are E & H, while the remnant quantities are D & B. This correlation is opposite to that of relativity frame transformations.
Another example which demolishes the "E relates to B, D to H" nonsense is as follows. A capacitor is formed with 2 dielectrics in series between the plates. The E fields for the 2 media differ, but the D fields are the same except for the case of surface charge at the boundaries, where the 2 D values differ by the constant rhos, the charge density. So for the 2 series configured dielectric regions D1 = D2, except at the boundaries where D1 - D2 = rhos.
If the 2 dielectrics are in parallel, we get equal E in both media, but D varies in accordance with ε. I.e. E1 = E2, and D1/D2 = ε1/ε2.
In magnetic domain take a ferrous core with a gap (air), a series mag circuit. The flux densities B are the same for series media of differing μ values. H, however differs. So B1 = B2, while H1/H2 = μ2/μ1.
If the gap is ferrous media in *parallel* with air, we get the same H value for both, with differing B values. H1 = H2, and B1/B2 = μ1/μ2.
In parallel the E values are the same, as are the H values. In series D values are the same (differing by only a constant at a boundary with surface polarization), and B values are the same.
This case clearly relates E with H, and D with B.
Now the final test. E and D can exist as conservative vector fields, as well as non-conservative. They can be closed loops, solenoidal, with a curl and no divergence, or as curvilinear segments with a beginning and end, having no curl but non-zero divergence.
But B and H do not exist in the segmented form, only closed loop form. The divergence of these vector fields is always zero. There is no correlation between E & H, nor E & B, when considering this property.
Is it B or H that is the counterpart of E? One test shows it to be B, two tests show it to be H, and one test shows it to be neither. So I can only conclude that it is impossible to say which is the counterpart of E, neither B nor H can be said to be the case.
All 4 quantities are real, significant, helpful, and relevant. Setting 2 as basis quantities, and treating the other 2 as derivations is not a problem, but the choice of which are basis quantities is arbitrary. Personally, I recommend the following. Don't worry about it.
I use B & H all the time, and laws of physics so far has not demonstrated that one is more basic than the other. I will likely get flamed for this, but I felt compelled to say this. Have a great Labor Day weekend.
Claude
  • #89
Claude, in macroscopic theory I agree with you, all EBDH are equally important. However nowadays we know about atoms and molecules and have the possibility to understand the macroscopic theory on the basis of microscopic theory. In microscopic theory, 4 independent field quantities make little sense. Usually we think that there is only one EM field with two components: electric and magnetic, as vanhees71 said. These may be denoted as ##\mathbf e, \mathbf b## (microscopic) and their meaning (definition) is that they give us the force on a point-like test particle
\mathbf F = q\mathbf e + q\frac{\mathbf v}{c} \times \mathbf b.
So in this picture, the fields e,b are more basic, since they directly give force. The macroscopic fields E,B can then be sought as a kind of average of these microscopic fields. The fields D,H are then necessarily only auxiliary quantities that play little role in the logic of microscopic theory; there is little reason to consider microscopic fields ##\mathbf d,\mathbf h##.
  • #90
I haven't read the paper in detail, but as far as I understand it this paper uses implicitly also averaging procedures, because it describes magnetization as "density of dipole moments". This is already a semiclassical description.
The most fundamental treatment is in-medium QED. Then you define in-medium (real-time Schwinger-Keldysh) Green's functions and then do some coarse-graining procedure for the Kadanoff-Baym equations, which are derived from the self-consistent 2PI formalism. Coarse graining then is formally done by assuming the separation of microscopic and macroscopic scales and use the gradient expansion of the KB equations to obtain semi-classical transport equations. There are various levels of description. Which one to use is a question of the application you have in mind and most of the approximation procedures are not derivable in a strict way from the fundamental equations of QED but are very much driven by phenomenology. Also the cited paper starts at a certain level that is already pretty far from QED in the sense that implicitly some averaging procedure has been assume. The very fact that you describe, e.g., magnetization as a density of dipole moments already is such an effective description from an averaging procedure! There is nothing wrong with this. To the contrary, it explains to a certain extent how the macroscopic phenomenology is related to the very fundamental level, as far as we know it today, and how the classical behavior can be understood as an emergent phenomenon from the most fundamental level of QED, so incomplete this understanding still is.
  • #91
Claude
From the point of view of classical electrodynamics (which itself is an approximation of QED) the fundamental field is the one and only electromagnetic field, whose components with respect to an arbitrary inertial reference frame (for simplicity let's consider special-relativistic spacetime, neglecting gravity) we use to call [itex]\vec{E}[/itex] and [itex]\vec{B}[/itex]. These are no "counterparts" but just components of the electromagnetic field, which in the manifestly covariant description are given as the antisymmetric 2nd-rank Faraday tensor field in Minkowski space, [itex]F_{\mu \nu}[/itex]. This is not crackpotery but well-established since Minkowski great work on these issues in 1908.
When it comes to the electromagnetism at presence of matter, you can describe this with pretty good accuracy with linear-response theory, and the usual (relativistic!) constitutive relations. It is very clear, and has been already clarified by Minkowski in 1908, that [itex]\vec{E}[/itex] and [itex]\vec{H}[/itex] are the components of the corresponding antisymmetric tensor [itex]D_{\mu \nu}[/itex]. Of course you have to distinguish between these two tensor fields and both are important in macroscopic electromagnetics, but it's not very clear to me, why these quantities should have different units. In the SI even the components belonging to the same tensor field have different units. This is pretty confusing rather than illuminating. It's of course not wrong, because you simply include the appropriate [itex]\mu_0[/itex] and [itex]\epsilon_0[/itex]-conversion factors of the SI, but it's unnecessarily complicated for the theoretical treatment, which best is done in the manifestly covariant way, which you can easily "translate" into the 1+3-dimensional formalism by splitting into temporal and spatial components whenever necessary for applications.
You find a very good description of all this already in pretty classical textbooks like vol. III of the Sommerfeld Lectures (which, by the way also use the SI!) or Abraham/Becker/Sauter. A very nice more uptodate treatment is also found in vol. VIII of Landau and Lifshitz. A more formal transport-theoretical treatment is given in the book by de Groot and Suttorp, Foundations of Electrodynamics.
Of course, sometimes you have memory effects and spatial correlations in some materials like ferromagnets (hysteresis) etc. That's no contradiction to what I've said above.
  • #92
I already acknowledged that relativistic transformations per Lorentz, Lorentz force, etc., are expressed in canonical form via E & B, since B is independent of medium for this narrow condition. Computing force acting on a charge by a mag field w/o considering what generates said mag field is done best by using B as the basis as it is medium-independent.
But take another example where we generate a mag field by setting up a current in a wire loop. The loop is circular w/ radius R, the current is I, what is B/H at the center?
Per Biot-Savart: B = μI/2R, or H = I/2R.
If we want the mag field generated by a current loop, the canonical form would be the equation with H, not B, as it is medium independent. Do you see what I mean about this question being arbitrary? A particle physicist bangs particles together in a super-conducting super-collider, cyclotron, etc. The force on a free charge in the presence of a mag field is best expressed using B.
But a widget inventing nerd like myself, deals with motors, generators, transformers, relays, solenoids, etc. If I'm generating a mag field with a current, H is medium-independent and canonical.
Bottom line, if we wish to attract a charge to a wire loop, we cannot eliminate μ either way. The H field generated by a current loop is independent of μ. But the attractive force depends on μH since it depends on B. So a charge in the center of the loop will incur a force of e(vXB) = e(vH) = eμ(vXI/2R).
The permeability constant μ shows up no matter if you use H or B.
Likewise 2 parallel wires each carrying current incur attractive/repulsive force based on the product of the 2 currents, distance between them, and μ the medium.
If Lorentz force acting on a charge is more important to you than mag field surrounding a current loop, then it makes sense to use B as the basis quantity, then derive H as B/μ. Either method produces the correct answer. If the physics community prefers to regard B as the basis, no problems should be created by doing so.
I just want to emphasize that such a convention is arbitrary, one could just as well treat H as the basis. Depending on boundary conditions, like the ones I mentioned with ferrous cores having series and parallel boundaries, the quantity that is independent of media could be either, B or H.
It's no big deal, you can start at B basis, then derive H as B/μ. But you can do the opposite. If we carefully keep track of our variables, the answer should be the same either way.
One exception is when the medium is ferrous, operating at or near saturation. Then the relation B = μH is not linear any more. In such a case, the B-H curve must be examined, and graphical analysis can be used. B & H in this case, cannot be interchanged because μ is not constant.
I will elaborate. Comments/questions welcome.
Claude
  • #93
I do not know what do you mean by the word "canonical". Field H depends on the conduction currents which are well controlled and can be easily calculated as their function. Field B depends also on the properties of the medium and may be harder to calculate, especially in ferromagnetic material.
This does not imply any of them as more basic.
But the attractive force depends on μH since it depends on B. So a charge in the center of the loop will incur a force of e(vXB) = e(vXμH) = eμ(vXI/2R).
The force on charge is established to be e(vXB) in vacuum, where μ = μ0. In medium, I do not think one can simply take the same formula. The microscopic field in the medium varies on atomic length scale and most probably neither H nor B is sufficient to find the force.
I would say, in macroscopic theory, both fields are equally important and neither seems more basic. But in microscopic theory, which is more detailed than the macroscopic theory and explains it in more elementary notions, there is place only for one magnetic field. It used to be denoted by ##\mathbf h## but I think it should be written as ##\mathbf b##.
  • #94
My point exactly. I've been saying the same since day 1. I concede to your point with no argument whatsoever. The current loop was brought up by me not to establish H as a basis, but rather to illustrate the futility of trying to establish either as more basic. We agree perfectly.
Well then, we now have to form a consensus on just what is the most "elementary" .
  • #95
The main reason I consider ##\mathbf B## as basic is that microscopic theories give it as a result of (some of many kinds of) averaging of the microscopic field ##\mathbf b##. While ##\mathbf H## does not seem to be result of such direct averaging - there is no microscopic##\mathbf h##. Instead, ##\mathbf H## is defined only in macroscopic theory as the quantity that gives only part of total current density - the conduction current density due to mobile charges - via
\nabla \times \mathbf H = \mathbf j_{\text{cond.}}
  • #96
I understand, but I still need an answer for the following. Take a parallel plate cap w/ dielectric, ε>1, and excite it with an ac generator plus resistor. There is a sinusoidal I & V in the cap. The conduction current in the cap leads and plates and partial mag field intensity will obey the relation you posted above:
What about the mag field inside the dielectric per Ampere's Law, aka "displacement current"? It is:
curl H = dD/dt.
Is there a B inside the dielectric but no H present? I find that ir-reconcilable since the dielectric contains no ferrous material, hence B = μH. So even inside the dielectric, μ = μ0, so that B & H co-exist. Why one would be the basis vs. the other seems pretty arbitrary unless I am missing something else not covered yet. The atomic structures are displacing in the dielectric. Electrons are moving towards one direction, with nuclear protons moving towards the opposite direction, both in a sinusoidal fashion. By definition these displacing charges constitute an ac current, and thus are surrounded by an ac mag field intensity, as well as density.
Inside the dielectric must exist both B & H in unison, inter-related per B = μ0H, as long as no ferrous material is involved.
Again, I am having trouble understanding the line of demarcation between "mAcroscopic vs. mIcroscopic". Thanks.
Any comments would be appreciated.
Claude
  • #97
Of course, both fields are present and non-zero in the dielectric. The distinction between macro and micro is that macroscopic field is that used in basic theory when we ignore the atomic structure of the material. The microscopic field varies randomly on the scale of molecules since it reflects their presence.
  • #98
I'm not sure if this is answered yet, but why are H and D different units?
Can't we define: epsilon*div(D) = free charge density?
Can't we define: curl(H)/mu - epsilon*dD/dt = free current density?
Can't we do the same for P and M with the bound charges and currents?
Then E = P + D and B = M + H
All have the same units.
What does this neglect?
  • #99
Ok we are in agreement, but no closer to solving the question "mAcro vs. mIcro". You gave a definition, but I would like an example akin to my cap given above, showing that in a vacuum, or non-ferrous material, that just 1 quantity is needed. Thanks in advance.
Claude
P.S. In my cap example, the dielectric being non-ferrous would mean that 2 quantities are un-needed, only 1 being necessary. But it looks like we get 2 of them. How do we decide which is basis, which is derived?
  • #100
Formally it's pretty simple: The fundamental microscopic description is quantum electrodynamics for many-body systems, macroscopic is a description derived from that via the one or other type of coarse graining, i.e., the derivation of tranport equations for the matter coupled to mean fields (Vlasov-Boltzmann-Uehling-Uhlenbeck -> Vlasov-Boltzmann) and some simplifications. The usual "macroscopic classical electrodynamics" we learn in introductory E+M is then linear response theory, where "matter" is reduced to the electromagnetic four-current and consititutive relations (response functions like the dielectric function, conductivity, ...).
To really establish these connections is, of course, rather complicated.
  • #101
My point exactly. To establish B or H as a basis, with the other being derived, certainly is complicated. You'll get no argument from me at all. But why sweat it?
A person who goes through an entire career thinking of B as "B" (the basis), but regarding H as "B/μ" (derived) should not encounter any problems as long as they do their math correctly. Every equation from Maxwell to Biot-Savart to Lorentz, etc., can be expressed in terms of either, B or H. It's arbitrary so why waste energy arguing?
But my caveat above must be remembered. For non-ferrous or soft ferrous material operating in non-saturated mode, it is safe to say that B = μH, treating μ as a constant, so that B and H have a linear relation. But with hard ferrous material operating into saturated mode, the linear equation is not accurate as μ varies with flux level. We then must use graphical methods to compute energy, force, induced emf/mmf, etc.
We seem to have a consensus on that point. Other thoughts are welcome. BR.
Claude
  • #102
I just think of mu as dB/dH in nonlinear materials. Surely that works in analytic evaluations of energy etc.?
  • #103
I would say that dB/dH works for computing inductance when an inductor has a dc bias, and we use the small signal permeability for inductance computation. Then dB/dH is the slope of the B-H curve at the operating point (flux).
But for energy, I don't think that dB/dH does a lot of good. If a magnetic core is driven into saturation, the area inside the B-H loop represents ir-recoverable energy (loss), while the area between the curve and vertical (B) axis represents recoverable stored energy, which gets returned on alternating ac cycles.
Also, for core losses, like hysteresis and eddy currents, empirical measurements are plotted on a graph, which are what nerds like me use when designing xfmrs, or motors/generators, etc.
The dB/dH quantity has useful value, but that alone does not fully characterize a magnetic core specimen when subjected to large flux swings into the saturated zone of operation. A combination of dB/dH, area outside curve, area inside curve, and empirical graphs, provide us with detailed insight into magnetic material behavior and optimization.
Claude
  • #104
Maybe the article by L. L. Hirst,The microscopic magnetization: concept and application, Reviews of Modern Physics, Vol. 69, No. 2, April 1997
may be useful to all interested in this question.
  • #105
DrDu said:
… L. L. Hirst,The microscopic magnetization: concept and application, Reviews of Modern Physics, Vol. 69, No. 2, April 1997 …
ftp://ftp.phy.pku.edu.cn/pub/Books/%CE%EF%C0%ED/%CE%EF%C0%ED%D1%A7%CA%B7/Review_of_Modern_Physics/microscopic%20magnetization.pdf :wink:
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
