Need help making a solar panel AA battery charger
In summary, this person is looking to build a solar powered AA battery charger. They have some questions about how to charge a battery and how difficult it would be to make the charger prevent overcharging. They are also looking into using different types of cells and solar panels.
vandel212
Hi,
I'm working on a project to build a solar powered AA battery charger. This is definitely not my profession, I only have a small understanding of electrical engineering. Mostly from what I learned in high school electrical class. Here is what I'm looking to do:
I want to charge 16 AA batteries. There will be 2 sets of batteries. 8 (series) AA, connected in parallel. If your are wondering why they are in parallel, ultimately this will be used to charge a tablet, so I want to up the capacity. If you are wondering why I don't buy one... They don't make one.
So I have a few questions:
1) To charge a battery, I need to hook it up backwards, that is I hook the positive of the power source to the negative of the battery, and the Negative of the power source to the positive of the battery. Right?
2) How much voltage do I need to put through this to charge the batteries?
3) How difficult would it be to make this charger prevent over charging?
Hi vandel212,
Nominally around a volt more than 8 x the fully charged voltage of a single AA cell should suffice, but with smaller solar cells you can go to a higher open circuit voltage.
Not so easy to implement. A bit of overcharging of NiMH cells is tolerable. You didn't indicate what chemistry cells you plan to use. NiMH would be safest.
I have reservations about charging two sets of cells in parallel unless you take steps to equalize the charging currents. Would be better to charge each set independently (or in series).
Is there any restriction on the area of solar panels you are able to use?
Yes, they are NiMH batteries. No real restrictions on the solar panels.
Larger panels will accomplish the charging faster, but then be more likely to overcharge the cells. It's a compromise you will have to ponder.
NiMH cells are typically 2500mAH. If you charge at 250mA, you'll need around 15 to 25 hours of bright sunlight (or more hours of duller sunlight) to fully charge them from near flat. By that stage, the solar panels will be having a struggle to squeeze out a lot of current, so you could probably allow another 10 hours of gentle over charge without worrying. So that's at least 5 days before you'd need to remember to switch off the sun. :smile: Is that do-able? (I'm figuring on 7 good hours of sun per day.)
I think solar panel voltage goes up in steps of 0.6V, but you may not be able to buy them in such small increments. I think a panel of at least 11V is needed, so I guess that means buying 12V, and perhaps later put a diode in series to drop the voltage a bit, if needed. There is room to experiment, especially where you don't wish to do much electronics construction.
Can you give a link to the data sheet for some panels you're looking at?
I do think you should use C cells, to avoid the problems of running strings of AA's in parallel.
16 AA cells are not going to fully charge a typical tablet (say, 7000mAH).
There are modules available which convert a DC voltage to a higher DC voltage. Cheap, straightforward, low-loss, and easy to hookup. You could halve your total NiMH's then use such a module to double the voltage for charging the tablet. Use the bigger cells, C or D, perhaps.
What materials do I need to make a solar panel AA battery charger?
To make a solar panel AA battery charger, you will need a solar panel, a diode, a rechargeable AA battery, a battery holder, wires, and a soldering iron. You may also need a voltage regulator and a resistor depending on the type of solar panel you are using.
How do I connect the solar panel to the battery charger?
To connect the solar panel to the battery charger, you will need to solder the positive wire from the solar panel to the positive terminal of the diode, and then solder the negative wire from the solar panel to the negative terminal of the battery holder. Finally, solder the positive wire from the battery holder to the positive terminal of the battery, and the negative wire from the battery holder to the negative terminal of the diode.
What type of solar panel should I use for my battery charger?
You can use either a monocrystalline, polycrystalline, or thin-film solar panel for your battery charger. Monocrystalline panels are the most efficient, but also the most expensive. Polycrystalline panels are slightly less efficient but more affordable, while thin-film panels are the least efficient but also the most affordable option.
How long will it take to charge an AA battery with a solar panel?
The charging time for an AA battery with a solar panel will depend on the capacity of the battery, the efficiency of the solar panel, and the amount of sunlight available. Generally, it can take anywhere from 4 to 8 hours to fully charge an AA battery with a solar panel.
Can I use a solar panel AA battery charger indoors?
While a solar panel AA battery charger is designed to be used outdoors to harness solar energy, it is possible to use it indoors as well. However, the charging time will be significantly longer as the solar panel will not receive direct sunlight. It is recommended to use the charger outdoors for optimal performance.
  • Electrical Engineering
