What causes a boomerang to flatten out in flight
  • Thread starter sarm2005
  • Tags
    Flight
In summary, the combination of a rotating airfoil with varying air speeds on the leading and trailing edges, along with the potential for differing lift at the front and back, creates a pitch torque that results in a roll reaction for a boomerang. However, this is not the case for the Aerobie flying ring, which has a special shape that allows it to fly without precession effects and even climb without changing pitch in certain conditions.
sarm2005
I understand why it turns to travel in a circular path. But why does it flatten out from vertical when you throw it.
Science news on Phys.org
First you have the combination of a rotating airfoil with more air speed on the "leading" edge of the air foil and less air speed on the trailing edge of the air foil. Depending on the airfoil shape, this could cause a direct rolling torque, that would result in a pitch reaction.
In addition, the boomerang may produce more lift at the "front" than at the "back" (or vice versa) and the pitch torque would result in a roll reaction.
Depending on the design, and given enough altitude, a boomerang will fly in a figure 8 pattern, although if through from the ground, many designs will land before making the transition to the second half of the figure 8 pattern.
The Aerobie flying ring is a special case. There's very little different in lift between the left and right side, or the front and back side, allowing an Aerobie to fly without the normal precession effects you get from boomerangs or frisbees. An Aerobie is best thrown with no perceptible angle of attack, relying on the airfoil's special shape to generate lift. It will actually climb without changing pitch if thrown horizontally with sufficient air speed, most noticable if it flies into a gusting headwind.
Link to boomerang website (earlier chapters have some generic stuff about aerodynamics):
http://www.researchsupporttechnologies.com/boomerang_site/boomerang5.htm
Aerobie physics:
http://www.aerobie.com/Products/Details/RingScientificPaper.htm
The flattening out of a boomerang in flight is due to the principles of aerodynamics. When a boomerang is thrown, it experiences a force called lift, which is created by the interaction between the shape of the boomerang and the air it travels through. This force is perpendicular to the direction of the boomerang's motion and causes it to rise and turn in a circular path.
As the boomerang moves through the air, its curved shape creates an area of low pressure on the top surface and an area of high pressure on the bottom surface. This pressure difference causes the boomerang to rotate and creates a lift force. However, as the boomerang gains speed and rotational motion, the angle of attack (the angle at which the boomerang meets the air) changes, causing the lift force to decrease.
As the lift force decreases, the boomerang's upward motion slows down and it begins to flatten out. This is because the force of gravity is acting on the boomerang and pulling it down towards the ground. Eventually, the lift force and the force of gravity reach a balance, causing the boomerang to maintain a stable, flattened trajectory.
In summary, the flattening out of a boomerang in flight is a result of the balance between lift force and gravity, which is influenced by the boomerang's shape, speed, and angle of attack.
Related to What causes a boomerang to flatten out in flight
What causes a boomerang to flatten out in flight?
A boomerang will flatten out in flight due to the aerodynamic principles of lift and drag. As the boomerang spins, it creates lift on one side and drag on the other. This imbalance causes the boomerang to tilt and eventually flatten out.
Why does a boomerang need to be thrown at a specific angle?
The angle at which a boomerang is thrown is important because it determines the direction and amount of lift and drag created. If the boomerang is not thrown at the correct angle, it will not generate enough lift and drag to sustain its flight and will not return to the thrower.
Can wind affect the flight of a boomerang?
Yes, wind can have a significant impact on the flight of a boomerang. Strong winds can disrupt the balance of lift and drag, causing the boomerang to veer off course. It is best to throw a boomerang in calm weather conditions for optimal flight.
Why do boomerangs have a curved shape?
The curved shape of a boomerang is designed to create lift and drag as it spins through the air. This shape allows the boomerang to generate enough lift to overcome the force of gravity and return to the thrower.
Can the weight of a boomerang affect its flight?
Yes, the weight of a boomerang can impact its flight. A heavier boomerang will require more force to throw and may not generate enough lift to return. On the other hand, a lighter boomerang may not have enough momentum to complete its flight and return to the thrower.
  • General Discussion
