Why is the Majorana mass of a neutrino so big compared to the
H.In summary, the conversation discusses the recent paper by Prof. Vafa on string phenomenology. The paper suggests that the Majorana mass of neutrinos can be much larger than the Dirac mass, which is a common concept in neutrino physics known as the See Saw mechanism. The left neutrino and right anti-neutrino have small masses, while the right neutrino and left anti-neutrino have large masses. This is further explained through references provided by Rock B and P.H.
yyoon@fas.harvard.edu
[Moderator's note: Quoted-printable stuff NOT corrected. Sometimes I
correct small errors, but a) there are several here and b) it is not
obvious what the meaning should be. Please submit only 100% 7-bit ASCII
plain-text posts. Even if YOU can read something fancier, many readers
can't. -P.H.]
I read the abstract of Prof. Vafa's recent paper on string
phenomenology. (arXiv:0806.0102)
But, I don't really understand the following part:
"This effect can simultaneously generate a viably small =A5=EC term as well
as an acceptable Dirac neutrino mass on the order of 0.5=A1=BF 10^(-2=A1=BE0=
..5)
eV. In another scenario, we find a modified seesaw mechanism which
predicts
that the light neutrinos have masses in the expected range while the
Majorana mass term for the heavy neutrinos is =A1=AD 3=A1=BF10^(12=A1=BE1.5)=
GeV."
So, it seems that the Majorana mass of neutrino is much much bigger
than the Dirac mass of neutrino.
Why is it so? As far as I know, the mass of neutrino is very small.
But, how can this light neutrinos have so big Majorana mass? Or,
rather, as stated in the excerpt, is there something called "the heavy
neutrinos" different from the light neutrinos which I am familiar
with?
Or, rather, even though it's unlikely, is Prof. Vafa suggesting that
"another scenario" of his is incorrect, since it predicts a big
Majorana mass?
I am confused,
Youngsub.
> Majorana mass?
It has nothing per se to do with string theory, but is a somewhat
standard part of folklore in neutrino physics. The *left* neutrino and
*right* anti-neutrino have small masses. The *right* neutrino and
*left* anti-neutrino, on the other hand, are usually stipulated to
have large masses. This is part of the See Saw mechanism and is used
to explain why the left neutrino (and right anti-neutrino) have such
small masses.
> Why is it so? > Youngsub.
Stimulated by Rock B's explanation, I've just learned from the
references in Wikipedia that explain this whole matter
straightforwardly:
http://en.wikipedia.org/wiki/Neutrino
http://en.wikipedia.org/wiki/Sterile_neutrino
http://en.wikipedia.org/wiki/Seesaw_mechanism
Regards - P
FAQ: Why is the Majorana mass of a neutrino so big compared to the
1. Why is the Majorana mass of a neutrino so big compared to other particles?
The Majorana mass of a neutrino is not actually considered "big" compared to other particles. In fact, it is one of the smallest masses in the Standard Model of particle physics. However, it may seem big when compared to the massless neutrinos predicted by the Standard Model.
2. What determines the size of the Majorana mass of a neutrino?
The size of the Majorana mass of a neutrino is determined by the interactions between neutrinos and the Higgs field. The Higgs field is responsible for giving particles their mass, and the strength of its interaction with neutrinos determines the size of their mass.
3. How does the size of the Majorana mass of a neutrino affect its behavior?
The size of the Majorana mass of a neutrino affects its behavior in a number of ways. It determines how fast the neutrino can travel, how it interacts with other particles, and even whether it can change between different types of neutrinos (known as neutrino oscillation).
4. Is there a limit to how big the Majorana mass of a neutrino can be?
There is currently no known limit to how big the Majorana mass of a neutrino can be. However, experimental evidence suggests that it is very small, on the order of less than 1 eV (electronvolt).
5. Why is the Majorana mass of a neutrino important in understanding the universe?
The Majorana mass of a neutrino is important in understanding the universe because it can provide insight into the origin of mass in the universe. It can also help explain the observed asymmetry between matter and antimatter, and provide clues about the nature of dark matter.
