General and specific existence and uniqueness proofs
In summary, the conversation discusses the process of proving the existence of an object, particularly in the context of mathematics. The conversation touches on the differences between direct and indirect existence proofs, as well as the importance of well-definedness and uniqueness in establishing existence. A specific example from "Gauge Fields, Knots and Gravity" is also provided and discussed.
SmithWillSuffice
Short question: Can anyone provide me with a nice synopsis of how to go about proving the "existence" of some object as often requested in math questions such as, "prove that X really exists and is unique"? In other owrds, in general, when presented with an "existence" question, is there a nice way to interpret such a question, and set about trying to answer it?
Long form of question:
I can handle the uniqueness part usually (or at least I know what I need to prove). And for many problems existence is fairly simple to ascertain, but I got stuck for example trying to understand how to demonstrate existence of a pullback map of a 1-form. This bugged me because it exposed to my mind a general lack of education about how to attack general "existence" type questions---i.e., when it's not obvious that you have an equation with an unknown and a putative solution that can be just plugged into the original equation. When you have an existence question that is not in the form of an equation in an unknown and a conjectured solution, then how do you go about establishing existence?
Specific example:
Taken from "Gauge Fields, Knots and Gravity", Baez and Munian.
(Exercise 32.): Define a pullback of a 1-form $(\phi^\ast $ by
\[ \label{eq1}
(\phi^\ast\omega)_p = \phi^\ast (\omega_q)
where $q=\phi(p)$, and $\omega_q$ is an element of the cotangent space on a manifold $N$ say and $\phi : M \rightarrow N$ is a map.
Now we are given that for a tangent space vector $v$ from $T_pM$, and $\nu$ from $T_q N$ a cotangent vector, then
\[ (\phi^\ast \nu) (v) = \nu(\phi^\ast v) \]
again $q=\phi(p)$. (So $\p\in M$ is mapped by $\phi$ to $q\in N$.)
So locally we have a pullback of a cotangent vector. The Exercise is to prove that the former expression (\ref{eq1}) for 1-forms is a global extension of the local pullback. Thus,
"Exercise 32. Show that the pullback of 1-forms defined by the above formula (\ref{eq1}) really exists and is unique."
I came up with an argument to answer this question, but I cannot fathom if it is correct or is exactly what is intended by an "existence" proof.
I somewhat naively just argued that at any $p\in M$ the map $\phi^\ast\omega_q$ can act on a tangent vector $v_p$ (so $v\in T_pM$) by the local pullback to $\omega(\phi^\ast v_p)$. But $v_p$ could be a local value of a vector field $v$ at the point $p$. It's pullback $\phi^\ast v$ is then by definition a vectr field on $N$, in other words the pullback of the tangent vecotr $v_p$ is a tangent vector on $N$. This, I believe, establishes that the formula
\[ (\phi^\ast\omega)_p = \phi^\ast (\omega_q) \]
is well-defined, i.e., it "exists"! Or have I missed something in this justification?
My problem is this: I cannot tell if I have really demonstrated existence of the pullback of 1-forms. The only other existence theorems I've come across in physics are usually those involving solutions to equations defined in terms of unknowns (or DE's where a solving function is given and one can check it exists wherever it is supposed to), whereas above we have what looks more like an equality or definition, not an equation in search of a solution variable.
But after completing my agument I seemed none the wiser about what I accomplished. I thus thought I'd write to physics forums here to see if anyone had a general perspective to offer on how to interpret and set about demonstrating mathematical existence type questions.
ASIDE: As for uniqueness of the pullnack for 1-forms, supposing two pullbacks of the same 1-form $\omega$ on $N$ say, $phi^\ast \omega$ and $\psi^\ast \omega$ yield the same 1-form on $M$, then I can show that the two associated maps $\phi$ and $\psi$ are equal, thus I conclude that the pullbacks are equivalent, which proves uniqueness.
Existence proofs can be accomplished by demonstating the existence of a thing directly or in directly (e.g.:
Direct: there exisits a value of x such that x+3=0; proof: x=-3 is such a value.
Indirect: there exists a value of x such that x+3=0; proof: Let f(x)=x+3. Then f is seen to be continuous (as it is a ploynomial) and we have f(1)=4 and f(-5)=-2, so by the intermediate value theorem, there exists a value of x such that -5 < x < 1, and such that f(x)=0.)
As for Uniqueness proofs, proof by contradiction is rather handy: having shown the existence of some thing, say x such *blah* is true, then suppose that there exists two such things, say x and x' such *blah* is true, and then show that if *blah* is true for both x and x', then invariably it follows that x=x'.
No there is no universal method of proof. You just have to find a reason why something must exist, be it by construction or an appeal to something non-constructive.
And 'well-defined' is not the same as 'exists', really, though it might be though part of the proof that what 'exists' is, erm, well, 'well-defined', which usually means 'is independent of any choices made'.
You also have uniqueness wrong. You must show that the thing you pull back to is unique, not the map \phi which is after all fixed. Ie given any choices (local data) the answer you get is always the same, so this is the well defined part. That is if I give you the data at a point int two different ways then phi^* does the same thing to both.
Here's an example.
Show that every real positive number has a well defined positive square root.
Existence: consider x^2-s for s positive, this is negative at x=0, and positive for x sufficiently large, hence it has a zero at x=r and r^2=s and r is positive. Now we need to show uniqueness: if r and t are square roots, then r^2=t^2 ie (r-t)(r+2)=0 thus r=-t so one is negative, or r=t and we are done.
FAQ: General and specific existence and uniqueness proofs
1. What is a general existence proof?
A general existence proof shows that a solution to a problem exists, without necessarily providing a specific solution. It establishes that there is at least one solution that satisfies certain conditions.
2. What is a specific existence proof?
A specific existence proof provides a particular solution to a problem, often with specific values for variables. It demonstrates that a solution exists and provides a method for finding it.
3. What is a uniqueness proof?
A uniqueness proof shows that a solution to a problem is the only possible solution, and that no other solutions exist. It establishes that there is only one solution that satisfies certain conditions.
4. How do general, specific, and uniqueness proofs differ?
General and specific existence proofs show that a solution exists, while uniqueness proofs show that the solution is unique. General and uniqueness proofs do not provide a specific solution, while specific existence proofs do. Additionally, specific existence proofs are typically more rigorous and detailed than general or uniqueness proofs.
5. In what fields of study are existence and uniqueness proofs commonly used?
Existence and uniqueness proofs are commonly used in mathematics, physics, and engineering, as well as in other scientific fields that involve solving equations or proving the existence of solutions to problems.
