Faling to loop the loop in a rollercoaster. How does this happen?
In summary, if the velocity decreases so much that the centripetal force is no longer enough to keep the person on the roller coaster moving in a circle, they will fall off the ride.
shahir_elmadr
At the top of the loop, we are in an upside down position, with our head being pointed towards the centre of the circle. As long as the ride is fast enough, it's impossible for us to fall out. But what happens if the ride slows down? if the rollercoaster slows down, the centripetal force is smaller. Which means the contact force from the seat will be smaller, right? if the velocity decreases further, the contact force at the top decreases to zero, since centripetal force is the sum of weight + contact/reaction force. If the rollercoaster slows down even further and the weight becomes greater than the required centripetal force, we are supposed to fall down.
Why do we fall down if the weight becomes greater than the centripetal force? What is the physics behind this motion?
welcome to pf!
hi shahir_elmadr! welcome to pf! :smile:
apply good ol' Newton's second law …
Ftotal = ma :wink:
to keep moving in a circle, you must have the appropriate centripetal acceleration
(this is geometry, not physics :wink:)
if the net force isn't enough to give you that acceleration (this is physics), you can't stay in the circle :smile:
Thanks for the help, man. But I guess I failed to explain my question clearly. I am saying that if the velocity decreases so much that, at the top of the loop, the weight becomes greater than the 'required centripetal force', the person on the roller coaster is going to fall head-on vertically downwards.
Centripetal force at the top of the loop = weight + contact force
If velocity decreases and keeps decreasing, the centripetal force also decreases, and the contact force decreases until it becomes zero. If the velocity doesn't decrease any further, the coaster will 'just' make the loop. But if it does, then it's supposed to fall downwards. I just don't understand why?
hi shahir_elmadr! :smile:
shahir_elmadr said:
… if the velocity decreases so much that, at the top of the loop, the weight becomes greater than the 'required centripetal force', the person on the roller coaster is going to fall head-on vertically downwards.
no, he'll follow a parabola just like any projectile …
he'll leave the rails at the angle at which the reaction force is zero, and gracefully follow a parabola until he crashes into the opposite side of the loop :wink:
(and if he actually reaches the top, he'll stay on even if the reaction force there is zero)
When riding a rollercoaster, we experience a sensation of weightlessness at the top of the loop. This is because the centripetal force, which keeps us moving in a circular motion, is equal to our weight. This means that we are effectively weightless at this point. However, if the rollercoaster slows down, the centripetal force decreases and may become smaller than our weight, causing us to fall downward. This is due to Newton's First Law of Motion, which states that an object in motion will stay in motion at a constant velocity unless acted upon by an external force. In this case, the external force is the decrease in the centripetal force, causing us to fall downward. This is also known as the principle of inertia. Additionally, the decrease in velocity also decreases the contact force from the seat, making it easier for us to fall out of the rollercoaster. In order to avoid this, rollercoasters are designed to maintain a certain speed throughout the ride to ensure that the centripetal force is always greater than our weight, keeping us safely in our seats.
1. What is "failing to loop the loop" in a rollercoaster?
"Failing to loop the loop" refers to when a rollercoaster train is unable to complete a full vertical or upside-down loop, either due to insufficient speed or mechanical issues.
2. How does this happen?
Failing to loop the loop can happen for a few reasons. If the rollercoaster train does not have enough speed, it will not be able to maintain the necessary centripetal force to complete the loop. Additionally, if there are any mechanical issues with the track or train, it may not be able to make it through the loop smoothly.
3. Is it dangerous for riders?
Yes, failing to loop the loop can be very dangerous for riders. If the train does not complete the loop, it may come to a sudden stop or even derail, potentially causing injuries to the riders.
4. What measures are taken to prevent this from happening?
Rollercoasters are designed and tested extensively to ensure that they are able to complete loops safely. Engineers use mathematical calculations and computer simulations to determine the necessary speed and track design for a successful loop. Regular maintenance and inspections also help prevent any mechanical issues that could lead to failing to loop the loop.
5. Has this ever happened before?
Yes, there have been instances of rollercoasters failing to loop the loop in the past. However, these incidents are rare and often occur due to human error or unexpected mechanical failures. Rollercoasters are constantly evolving and improving, making it less likely for this to happen in modern designs.
11K
