- #1
TGO
- 2
- 0
I've had a number of ideas for inventions lately. I lack a strong background in physics and chemistry to an advanced level so please try and forgive me for my ignorance as I would like to learn what I can at an appropriate pace and enjoyable manner. Sorry if to some of you more familiar with the advanced fields these devices involve have to go through the miserable agony of reading these stupid ideas if they are indeed stupid like they probably are. However, one of the most enjoyable ways to learn is throwing the hypotheticals and the wild ideas out in the open so here goes...
Idea 1:
Impact-reactive Stun and Smoke Concussive Explosive (ISSCE)
The basic idea is an explosive device, spherical in shape. It has 2 chambers. The first chamber is the detonation device for the concussive stun mechanism (similar in functionality to the M84 stun grenade). The second chamber would house the detonation device for the smokescreen releasant mechanism (similar in functionality to the L83A1 smoke grenade). However this device would not just be a simple combination of two ingenius inventions. It is a step up as this device would require no timely means of detonation. No pin, no fuse. Both chambers would detonate simultaneously. All it requires is the force of hitting a surface, such as the ground to detonate. Making it perfect for a number of uses (escapes, entries, etc.).
Idea 2:
Artillery Negation and Deflection (AND)
This suit would essentially be made up of several layers. The outter layer would emit a powerful electromagnetic fieled. Artillery fire from regular firearms would bounce completely off or skew off course from the wearer of the suit due to the electromagnetic force surrounding the suits outter layer. The suit would also have 2 detachable barrels that contain a chamber loaded with projectile EMP devices that could be fired from either of these barrels located on each wrist area part of the suit, and cling to any metalic based target and then procede to detonate as soon as attached shortcircuiting targets from miles away from safety to avoid confrontation with heavier artillery such as tanks and missles. One curious thought I had, is if the electromagnetic force generated from the outter layer of the suit was strong enough, would it be capable of literally moving landmines as you walk closer to them? In any case. If heavier artillery could be handled from a distance safely, and light artiliery from regular firearms couldn't touch you, I'm having a hard time imagine just what an army could do to react to such a device. I was even hopeing it would be possible to add in a few internals layers that would attract and trap oxygen into the suit, and used the converted energy obtained to focus it to joint muscle parts of the suit, such as the knees, elbows, hands and feet so essentially you would have more force behind your movements and actions. You'd be more agile, stronger, and the weight of what I could only imagine would be a heavy suit would be easy lifting for you with all the extra force helping you support the weight. The question is how much energy could be trapped and how much of a difference could it make? Would you feels 2 times stronger? 10? Or barely any stronger at all with that extra energy being put into force and used at your whim? Heck, assuming I scrapped the idea of the electromagnetic deflection and EMP projectile barrels and commited the entire structuring of the suit to the act of trapping oxygen or some kind of external fuel that is all around us (perhaps sunlight if not oxygen), and used it to fuel force into an action such as jumping, would it be a noticable difference if charged long enough in the sun or left outside (since I know the absorbtion process would probably take some time). Would you be able to jump twice as high, move twice as fast, lift twice as much, or would it be a miniscule difference?
The feasibility of any of the above and many some ideas on just how they could become feasible (if at all possible) would be appreciated. It's always fun for me to throw around some insane hypotheticals. Again, sorry to the veterans out there for seeming moronic haha. I'm just really curious if any of these inventions are possibilities. And not thatits nearly as interesting or probably useful, but I also thought of a final small minuature invention...
Idea 3 (well a mini-idea at least):
Basically a small beacon like device with a propeller that could be wound up. When wound up it would have a dial to change what elevations it would be preprogrammed to fly to and it would fly and substain its elevation. Once there it would flash a red and blue distress light, emit a loud noise, and possibily emit a radio transmission of some kind that could show up on radar. Just enough to get the attention of any go'er byes or rescue aircraft or boats that may be nearby if you are stranded on an island for example. Perhaps it could even release a luminous smoke signal (phospherus based) at night? Havn't come up with a name for this idea yet. Mainly because it is probably the worst of the 3 haha.
Okay now that's it, thanks guys for any and all responses and help!
Idea 1:
Idea 2:
