Why does higher mobility = higher frequency of operation (transistors)
In summary, the conversation discusses the high electron mobility transistors that use a 2 dimensional electron or hole gas. The band structures and process for achieving high mobility are well-described, but there is a lack of understanding on how these transistors fail to accurately amplify signals at higher frequencies or switch faster. It is suggested that for BJTs, the failure could be due to the lag time for the concentration profile in the base to reach steady state, which is related to the diffusion constant and mobility. However, this theory is not fully confirmed. Additionally, the use of HBTs and HEMTs are mentioned as potential solutions to improve transistor performance.
Randron
I am going to give a presentation on High Electron Mobility Transistors (the ones that use a 2 dimension electron or hole gas), and although I can find many detailed descriptions of the band structures and what causes the 2DEG's high mobility, I haven't found a clear description of the process by which field effect transistors (or any transistor) start to fail to accurately amplify a signal at higher frequencies (or switch faster).
For the BJT, it seems that the source of this failure could be the lag time for the concentration profile in the base to reach steady state, which would be related to the diffusion constant, which is related to the mobility. Am I correct about this?
I am no expert but I found this which may illuminate for you some reasons for the high performance of these 2DEG devices:
“Unexpected features of branched flow through high-mobility two-dimensional electron gases”
http://arxiv.org/abs/1009.3670
Hope this helps.
Bobbywhy
While this was a very interesting description of the electron flow in 2DEGs, I don't think it deals with my original question about transistor performance.
Mobility --> Transit Time across the base --> upper bound on BJT Ft
However PN-junction BJTs are primarily bandwidth limited by junction capacitance (with BC capacitance multiplied by Miller effect). This why you see cascodes: feeding into a common base helps to reduce the effective RC time constant which determines the bandwidth.
Where HBTs enter the picture is to eliminate conventional PN junction capacitance (and increase injection efficiency). HEMTs are majority carrier devices plus the nature of the 2DEG (lack of scattering from dopant atoms) gives better mobility than possible with minority carrier currents or majority currents with dopants.
Yes, you are correct. The higher mobility of the electrons or holes in a transistor allows them to move more quickly through the device, which in turn allows for higher frequency operation. This is because the speed at which a transistor can switch or amplify a signal is limited by the time it takes for the carrier concentration to reach steady state in the device. This is known as the transit time or the lag time.
In a BJT, the concentration profile in the base region needs to reach steady state for the transistor to accurately amplify a signal. This is dependent on the diffusion constant, which is directly related to the mobility of the carriers. As the mobility increases, the carriers are able to move through the device more quickly, reducing the lag time and allowing for faster switching and higher frequency operation.
In the case of High Electron Mobility Transistors (HEMTs), the 2DEG is formed at the interface between two semiconductor materials with different bandgaps. This creates a very high mobility channel for carriers to move through, resulting in faster switching and higher frequency operation.
In summary, the higher mobility of carriers in a transistor allows for faster switching and higher frequency operation by reducing the lag time for the concentration profile to reach steady state. This is why higher mobility is essential for the operation of transistors, especially at high frequencies.
1. Why does higher mobility affect the frequency of operation in transistors?
Higher mobility refers to the ability of charge carriers (electrons or holes) to move through a material. In transistors, the movement of charge carriers is crucial for the switching and amplification of electrical signals. Therefore, higher mobility results in faster and more efficient movement of charge carriers, resulting in a higher frequency of operation.
2. How does mobility impact the performance of transistors?
Mobility plays a significant role in the performance of transistors because it affects how quickly and efficiently signals can be processed. Higher mobility results in faster switching speeds, lower power consumption, and higher gain, which are all essential for high-performance transistors.
3. What factors influence the mobility of charge carriers in transistors?
The mobility of charge carriers in transistors is influenced by various factors such as the material used, temperature, impurities, and electric field. For example, materials with a high density of free electrons, low impurity levels, and a low temperature tend to have higher mobilities.
4. Can the mobility of transistors be increased?
Yes, the mobility of transistors can be increased by using materials with higher intrinsic mobilities, reducing impurities and defects in the material, and optimizing the device design to minimize scattering of charge carriers. Researchers are continually working to improve the mobility of transistors to enhance their performance.
5. Is there a trade-off between mobility and other transistor characteristics?
In most cases, there is a trade-off between mobility and other transistor characteristics. For example, materials with higher mobilities may be more challenging to process, resulting in higher manufacturing costs. Additionally, increasing the mobility may also lead to a decrease in other properties, such as breakdown voltage. Engineers must consider these trade-offs when designing transistors for specific applications.
  • Electrical Engineering
