Solving Problems with zheev Subroutine in Do Loop
  • Thread starter Rositta
In summary, the conversation is about using the zheev subroutine in a do loop to diagonalize a 5-by-5 matrix. The matrix is only being looped through 2000 times, but the correct eigenvalues are only being obtained for a few cases. The code also includes a main program and a subroutine to find the eigenvalues. The issue is resolved by setting Lwork to -1 before the first call to ZHEEV.
Rositta
I'm using zheev subroutine in a do loop (up to 2000 times) that contains other subroutines and functions. The matrix to diagonalize is only 5-by-5 however zheev gives the correct eigenvalues for only few cases even after reducing the number of times in the do loop. Any hint would be highly appreciated...
Technology news on Phys.org
Without seeing your code, there's not we can do to help you diagnose the problem.
Sorry.. Here is the main programme:
=>program xggauss
IMPLICIT NONE
! declare variables for part1
integer:: nval,i,k0
integer,parameter::kf=20
real*8,parameter::pi=3.141592653589
real*8:: x1,x2,dx,func,ss,x,r,del
complex*8::sphshift
! declare variables for part2
real::vb,bb
real*8,dimension(1:kf)::eb,k,kk,perturb
complex*8,dimension(1:kf)::delta
real*8::Eval(5)
integer,parameter::LDA=5
complex*16,dimension(LDA,LDA)::Evec
parameter(vb=1.,bb=1.)
external func,sphshift
print*,'lower limit='
read*,x1
print*,'upper limit='
read*,x2
print*,'number of intervals='
read*,nval
dx=(x2-x1)/nval
write(*,'(f6.3,1x,a,t12,a,t23,a/)') x1,'to','qgauss','expected'
do 12 k0=1,kf
k(k0)=k0*0.001
eb(k0)=k(k0)**2
kk(k0)=sqrt(vb+eb(k0))
do 11 i=1,nval
x=x1+i*dx
call ggauss(func,kk(k0),x1,x,ss)
11 continue
perturb(k0)=(2*bb/kk(k0)**2)*(1/(14*sqrt(pi)))*ss
delta(k0)=sphshift(k(k0),kk(k0))
call eigvals(perturb(k0),sphshift(k(k0),kk(k0)),Eval,Evec)
write(*,'(1x,I5,1x,f6.4,1x,f10.8,2x,f10.8,2x,f15.13,2x,f15.13,(2x,f15.13,1X,f20.18))')k0,k(k0),kk(k0),eb(k0),ss,perturb(k0),delta(k0)
CALL PRINT_RMATRIX('Eigenvalues', 1, 5, Eval, 1 )
print*,'********************************************************************************'
12 continue
end program xggauss
real*8 function func(x,r)
real*8:: x,r
func=x**4*((x*r)*((3/(x*r)**2-1)*(sin(x*r)/(x*r))-(3*cos(x*r)/(x*r)**2)))**2
end function func
complex*8 function sphshift(x,y)
real*8:: x,y,cb1,cb2,cb,db1,db2,db,del2,fb1,fb2
cb1=sin(x)*(4*x**2-9)+cos(x)*(9*x-x**3)
cb2=sin(x)*(9*x-x**3)-cos(x)*(4*x**2-9)
db1=sin(x)*(3-x**2)-3*x*cos(x)
db2=cos(x)*(3-x**2)+3*x*sin(x)
cb=db1*(sin(y)*(4*y**2-9)+cos(y)*(9*y-y**3))-cb1*(sin(y)*(3-y**2)-3*y*cos(y))
db=cb2*(sin(y)*(3-y**2)-3*y*cos(y))+db2*(sin(y)*(4*y**2-9)+cos(y)*(9*y-y**3))
del2=atan(-cb/db)
fb1=cos(del2)*sin(del2)/x
fb2=sin(del2)**2/x
sphshift=cmplx(fb1,fb2)
end function sphshift
and this is the subroutine I'm using to find the eigenvalues:
=>subroutine eigvals(perturb,sphshift,W,Q)
implicit none
real*8,intent(in)::perturb
!declare variable for zheev subroutine
integer::Info,Lwork
integer,parameter::m=5
integer,parameter::LDA=m
integer,parameter::Lwmax=100
complex*16,dimension(LDA,m),intent(out)::Q
complex*16,dimension(1:Lwmax)::Work
real*8,intent(inout)::W(m)
double precision::Rwork(3*m-2)
complex*8::sphshift
complex*16,dimension(m,m)::eek:ct,ones
data oct/(1.,0.),(0.,0.),(0.,0.),(0.,0.),(5.,0.),(0.,0.),(-4.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),&
(0.,0.),(6.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(-4.,0.),(0.,0.),(5.,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.)/,&
ones/(1.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),&
(0.,0.),(1.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.),(0.,0.),(0,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.)/
integer::i,j
intrinsic int,min
do i=1,m
do j=1,m
Q(i,j)=perturb*oct(i,j)+sphshift*ones(i,j)
end do
end do
CALL ZHEEV('V', 'L', m, Q, LDA, W, WORK, LWORK, RWORK, INFO )
Lwork=min(LWMAX,int(WORK(1)))
IF(INFO.GT.0) THEN
WRITE(*,*)'The algorithm failed to compute eigenvalues.'
STOP
END IF
end subroutine eigvals
I think you are trying to call ZHEEV to find the size of the work array, then call it again to solve the eigenproblem.
You need to set Lwork = -1 every time before the first call. Your code doesn't seem to set it to anything before the first call to ZHEEV. Most likely your code crashes "randomly" because Lwork eventually has a bad value.
Thaks a lot AlephZero. All the eigenvalues are calculated correctly now :)
1. How does the zheev subroutine work in solving problems with a do loop?
The zheev subroutine is used in solving eigenvalue problems, specifically for symmetric matrices. It utilizes the LAPACK library to compute the eigenvalues and eigenvectors of a matrix, which are then used to solve the problem in a do loop.
2. What are the advantages of using the zheev subroutine in a do loop?
One advantage is that it is more efficient and accurate compared to manual calculations. It also allows for easier implementation of the problem, as the subroutine takes care of the complex calculations.
3. Can the zheev subroutine be used for non-symmetric matrices?
No, the zheev subroutine is specifically designed for symmetric matrices. For non-symmetric matrices, a different subroutine, such as zgeev, should be used.
4. How can I ensure the accuracy of the zheev subroutine in solving my problem?
The accuracy of the zheev subroutine depends on the precision of the input matrix. It is important to ensure that the matrix is well-conditioned and free from errors or inaccuracies. Additionally, using double precision data types can also improve the accuracy of the results.
5. Are there any limitations to using the zheev subroutine in a do loop?
Yes, the size of the matrix can be a limitation. The zheev subroutine can only handle matrices of a certain size, depending on the available memory and computational resources. It is important to check the documentation and specifications of the subroutine before using it in a do loop.
