Does a Falling Wire Near a Magnet Experience a Magnetic Force?
In summary: At the ends of the wire, v is perpendicular to B - thus, there is a magnetic force acting on the charges there. However, the wire itself is parallel to B, and as a result, the charges have no space to move - there is no current.
physmath96
Suppose a single wire (in a horizontal position) falls toward a pole of a magnet. Does the wire slow down?
A diagram is attached.
  • Diagram.pdf
IMHO I don't think so, as the straight wire has no loop back connection to each end.
Thus, no current flow, no back emf.
But a copper "ring" would be a different story.
Just my thoughts, could be wrong.
That's what I initially thought. There is a magnetic force acting on the charged particles at the ends of the wire, but these charges have nowhere to go and thus, there is no current. However, I was wondering if the magnetic forces acting on the ends of the wire could exert torque on the wire...
physmath96 said:
There is a magnetic force acting on the charged particles at the ends of the wire...
How do you come to that assumption? Why are there "charged" particles on the ends of the wire in your scenario? The copper wire has many charged particles but is electrically neutral in your description.
The wire has charged particles, right? If the wire falls, then the charged particles (which are confined to the wire) are also falling. If charged particles move in a direction perpendicular to the magnetic field, a magnetic force acts on them. In this case, the magnetic field (at the ends of the wire) is perpendicular to the motion of the charged particles in the wire. Thus, there should be a magnetic force acting on the ends of the wire, right?
Well conductors (e.g., metals) have electrons in their atoms. Some of the electrons are quite mobile, i.e., they can readily move if an external force is applied, e.g., through potential difference applied to the conductor, or if the conductor is moved through a magnetic field.
Perhaps this will help.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/conins.html
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magfie.html
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/genwir.html
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/hall.html
The answer one seeks lies therein.
In this case, a wire segment is moving through a magnetic field. The equation that applies to this case is: emf = vBL, which holds only when v (velocity), B (magnetic field), and L (length) are mutually perpendicular. Looking at the diagram, one can see that the three values are not mutually perpendicular, and thus, no emf will be induced. The wire will not slow down.
I don't think he was wondering about the emf. I think he wanted to know what force would be applied, if any. In this case, a force will only be applied if v and B are not parallel (qv x B).
What is electromagnetic induction?
Electromagnetic induction is the process of generating an electric current in a conductor by changing the magnetic field around it. This occurs when a conductor is moved through a magnetic field, or when a magnetic field is changed around a stationary conductor.
What is the relationship between electricity and magnetism in electromagnetic induction?
Electromagnetic induction is based on Faraday's law of induction, which states that a changing magnetic field will induce an electric current in a conductor. This shows the intimate relationship between electricity and magnetism, as they are fundamentally linked through the concept of electromagnetism.
What are some practical applications of electromagnetic induction?
Electromagnetic induction has many practical applications in our daily lives. It is used in generators to produce electricity, in transformers to change the voltage of electric currents, and in devices like electric motors, induction cooktops, and wireless charging systems.
What is the role of Lenz's law in electromagnetic induction?
Lenz's law is another important concept in electromagnetic induction. It states that the direction of an induced current will always oppose the change that caused it. This means that when a conductor is moved through a magnetic field, the induced current will create a magnetic field that opposes the original magnetic field.
How does electromagnetic induction affect the design of electronic devices?
Understanding electromagnetic induction is crucial in the design of electronic devices. Engineers must consider the effects of electromagnetic induction when designing circuits and components to ensure that unwanted currents or voltage spikes do not occur. They also use electromagnetic induction principles to create devices like inductors and transformers that are essential in many electronic systems.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
9K
