Why Do Induction Ovens Heat Ferromagnetic Materials More Efficiently?
In summary: They just don't have the ability to "switch" their magnetic properties.In summary, the ferromagnetic material heats up faster because of the hysteresis loss.
fluidistic
263
I do not understand why ferromagnetic materials are more easily heated by an induction oven than a non/low ferromagnetic material such as copper or aluminum.
Are Eddy currents more easily induced into a ferromagnetic material than a conductor lacking a high ferromagnetic property? Why is it so?
An induction cooker for instance creates losses by magnetic hysteresis. It works only with iron pans, not copper.
Some other induction heaters are designed for other materials, work at other frequencies, and prefer simple conductive material.
According to wikipedia,
wiki said:
In an induction cooker, a coil of copper wire is placed underneath the cooking pot. An alternating electric current flows through the coil, which produces an oscillating magnetic field. This field induces an electric current in the pot. Current flowing in the metal pot produces resistive heating which heats the food. While the current is large, it is produced by a low voltage.
and they are talking about
wiki said:
a cooking vessel must be made of a ferromagnetic metal
And also
wiki said:
Some additional heat is created by hysteresis losses in the pot due to its ferromagnetic nature, but this creates less than ten percent of the total heat generated
So this does not seem to be the answer. I'm still clueless as why a ferromagnetic material heats much faster than a non/low ferromagnetic material.
Possible explanations:
- Wiki botched it. It does happen.
- Losses result from induced current, but only because the skin effect increases the resistance, and the skin is made much thinner in ferromagnetic materials.
Why shouldn't you try to put some figures at it? Search for "Kelvin effect". Cookers use high frequencies, like >20kHz.
Ferromagnetic materials switch their internal magnetism back and forth with every switch of the external magnetic field. However the process has hysteresis, that is it is not completely reversible. The internal magnetic domains lag behind the changing external field, so the sweep back and forth describes a hysteresis loop. The larger the area in this loop the greater the loss on each cycle. This loss turns up as heat. Look up 'hysteresis loop' for graphs and further details.
This effect does not exist in non magnetic materials.
FAQ: Why Do Induction Ovens Heat Ferromagnetic Materials More Efficiently?
What is an induction oven?
An induction oven is a type of cooking appliance that uses electromagnetic induction to heat up cooking vessels made of ferromagnetic materials. This method of heating is different from traditional ovens that use heating elements or gas burners.
How does an induction oven work?
An induction oven uses an alternating electric current to create a magnetic field, which in turn creates eddy currents in the ferromagnetic material of the cooking vessel. These eddy currents generate heat, which is then transferred to the food inside the vessel.
What are the advantages of using an induction oven?
One of the main advantages of using an induction oven is its efficiency. Since the heat is directly generated in the cooking vessel, there is minimal heat loss, making it more energy-efficient than traditional ovens. Additionally, induction ovens heat up faster and provide more precise temperature control.
What types of cookware can be used on an induction oven?
Cookware made of ferromagnetic materials such as cast iron, stainless steel, and some types of steel can be used on an induction oven. However, cookware made of materials such as aluminum, copper, or glass will not work on an induction oven unless they have a layer of ferromagnetic material on the bottom.
Are there any safety concerns with using an induction oven?
Induction ovens are generally safe to use as they do not produce an open flame or use gas. However, there is a risk of burns if the cooking vessel is hot, and caution should be taken when handling the cookware. Additionally, the electromagnetic fields produced by induction ovens may interfere with certain medical devices such as pacemakers, so it is important to consult with a doctor before using an induction oven if you have a medical device.
