Understanding Power Drain in Series and Parallel Circuits | MCAT Prep Tips
In summary: The easy way to check this is by doing some calculations. First, within a series circuit, a larger resistor will dissipate more power than a smaller resistor. Second, within a parallel circuit, a smaller resistor will dissipate more power than a larger resistor. Third, between two circuits, each with the same voltage source, the one with a smaller equivalent resistance will dissipate more power.
PStudent111
Alright, so, is my thinking correct in that:
1. Within a series circuit, a larger resistor will drain more power than a smaller resistor.
2. Within a parallel circuit, a smaller resistor will drain more power than a larger resistor.
3. Between two circuits, each with the same voltage source, the one with a smaller equivalent resistance will drain more power.
I'm doing some MCAT prep and for some reason the power drain concept is difficult for me but I've think I've got the hang of it now.
Any thoughts?
Hi PStudent111! :smile:
Yes.
The easy way to check this is …
For 1, the current (I) is the same, so you use P = IV = I2R, which is proportional to R.
For 2 and 3, the voltage (V) is the same, so you use P = IV = V2/R, which is inversely proportional to R. :wink:
Not necessarily. This is only true if something in the circuit maintains the same current when the resistance is changed.
For example suppose you changed the resistor to one with an exceptionally high resistance, Let's say you replaced it with a 1m air gap. Virtually no current would flow through the 1m air gap so the power loss would approach zero. However no power would be delivered to the load either so it wouldn't be a very useful circuit.
Instead of using the word "drain" it might be better to use the word "dissipate".
I think the OP means that there are 2 resistors in series. In such a case the current will be the same through both resistors and the one with a higher resistance will dissipate more power.
Perhaps. He did say "a larger" rather than "the larger".
This is a good example of where some calculations are better than arm waving. If you draw the circuit out, specifying the conditions ( supply voltage, resistor values etc.) and work out the current and power for the supply and the various resistors in the circuit, for various values, you will see the pattern. I mean work the values out yourself and not use an emulator. The sums are easy enough.
Of course, using symbols rather than numbers, the algebra will give you a better idea of what is happening - but it is not necessary if you really don't like Maths.
1. What is power drain in series and parallel circuits?
Power drain refers to the rate at which energy is consumed or dissipated within a circuit. In series circuits, the power drain is equal at all points in the circuit. In parallel circuits, the power drain is divided between the branches of the circuit.
2. How does power drain differ in series and parallel circuits?
In series circuits, the power drain is the same at all points, while in parallel circuits, the power drain is divided between the branches of the circuit. This is due to the different relationships between voltage and current in each circuit type.
3. How do you calculate power drain in a series circuit?
In a series circuit, the power drain can be calculated by multiplying the voltage by the current at any point in the circuit. This is because the voltage and current are the same at all points in a series circuit.
4. How do you calculate power drain in a parallel circuit?
In a parallel circuit, the power drain can be calculated by adding the power drain of each branch of the circuit. This is because the voltage and current are different in each branch of the parallel circuit.
5. Why is understanding power drain important in circuit analysis?
Understanding power drain is important in circuit analysis because it allows us to determine the efficiency of a circuit and identify potential issues. It also helps us to make informed decisions when designing and troubleshooting circuits.
  • Electrical Engineering
