Why the surface plasmon always use gold or silver as a metal film?
In summary, the conversation discusses the use of gold and silver as metal films in surface plasmon on prism geometries. The reason for using these metals is likely due to their dielectric properties at the interface between the metal and air. It should also be noted that gold and silver are only suitable for visible light frequencies and that the plasma frequency for surface plasmons is 1/sqrt(2) smaller than the bulk plasma frequency. Additionally, gold surfaces do not have an oxide layer which may affect their optical properties.
Poseidonho
I found a lot the the surface plasmon on prism geometry are using gold for metal film, and part of it are using silver. Why we need use gold or sivler as a metal film, is it about the condutivity?
I believe it has to do with the dielectric properties of the interface between gold/silver and air. Also, keep in mind that gold/silver is only used for visible light frequencies.
The plasma frequency for surface plasmons is 1/sqrt(2) smaller than the bulk plasma frequency.
In the case of gold and silver that's in the visible. Gold surfaces also don't have an oxide layer which may change the optical properties.
thanks alot:!)
Related to Why the surface plasmon always use gold or silver as a metal film?
1. Why are gold and silver commonly used as metal films for surface plasmons?
Gold and silver have unique optical properties that make them ideal candidates for surface plasmon applications. They both have a high electron density which allows for strong interaction with light, and their electrons are easily excited to create plasmons. Additionally, gold and silver have low resistivity and high reflectivity, making them efficient at transmitting and reflecting light.
2. Can other metals be used for surface plasmon films?
While gold and silver are the most commonly used metals for surface plasmon films, other metals such as copper, aluminum, and titanium can also be used. However, they may not have the same optical properties as gold and silver, and their performance may vary depending on the specific application.
3. What factors determine the choice of metal for surface plasmon films?
The choice of metal for surface plasmon films depends on various factors such as the desired plasmon frequency, the type of light being used, and the specific application. Some metals may be more suitable for certain frequencies or wavelengths of light, while others may have better performance in specific environments.
4. Are there any drawbacks to using gold and silver for surface plasmon films?
While gold and silver have many desirable properties for surface plasmon applications, they also have some drawbacks. They are both expensive and can be difficult to fabricate into thin films with precise thicknesses. Additionally, their properties can be affected by environmental factors such as oxidation.
5. How do researchers determine which metal is best for their surface plasmon study?
Researchers typically consider the specific requirements and goals of their study, such as the desired plasmon frequency and the type of light being used. They may also perform simulations or experiments using different metals to determine which one will provide the best results for their particular application.
11K
  • Atomic and Condensed Matter
  • Art, Music, History, and Linguistics
  • Chemistry
