Can underwater pressure be equated with weight? (after conversions)
In summary, pressure and weight are different quantities with different units. The weight exerted on the base of the tank is due to the volume of water and its density, while the pressure at a given depth is well defined by atmospheric and hydrostatic forces. If the tank had sloping sides, the contributions of pressure on the sides would need to be added or subtracted. The expression "weight" should be replaced with "force on the bottom" unless the tank is cuboidal with vertical sides. In SI units, weight is measured in Newtons, not kilograms. The tank with a base made of glass that can only withstand 395 kg of weight would fail if filled with 200 liters of fresh water to a height of 10 meters
user100
It is a established fact that pressure i.e ρgh will be same at a given depth. Suppose in a tank filled with water the gauge pressure works out to 1 bar, then the total pressure at the depth of tank would be 1 bar + 1 bar atmospheric pressure = 2 bar pressure.
2 bar pressure equals 2 kgf/ cm2
Question
Suppose the base of the tank is 200 cm2, can it be said that "water in tank exerts 400 kg WEIGHT on the base of tank" [i.e 200 cm2 * 2kgf/cm2]
The weight exerted on the base of the tank, is due to the volume of water, & it's density (sea or fresh). I assume fresh water. The height of the tank, to exert 1 atmosphere of pressure, would be ~ 10 meters. So, 1,000 cm ht. x 200 cm2 base = 200 liters tank volume.
At 1 kg per liter, the total weight of water, exerted on the base, would be 200 kg. The atmosphere would exert a pressure equivalent to the weight of an additional 200 kg of water, on the base of the tank. However, the atmospheric pressure, being exerted in all directions, is negated. So, weight and pressure, are not the same. A fresh water filled 1 inch diameter tube, 10 meters tall, would still exert 1 atmosphere of pressure, at it's base, but weigh only about 5 kg.
Likes 1 person
Pressure and weight are different quantities with different units. Sometimes, their numerical value can be the same but that is not significant. So the weight is independent of the pressure, and they would not be the same numerical value if the shape or orientation of the tank changed. Your example works because you happen to have chosen a particular situation where the pressure happens to be the same over the whole area of the bottom of the tank and the sides are vertical so there is no downwards or upwards force on them - just horizontal forces. If the sides were sloping either way than the contributions of pressure on the sides would need to be added in (or subtracted).
So the expression should rather be 'the force on the bottom' - unless the tank is cuboidal with the sides vertical.
The weight of water has a definite value and the pressure at a given depth is also well defined (atmospheric plus hydrostatic).
Note, in SI units, we do not have a 'weight' in kg. Weight is in units of Newtons because it is a force. In the dreaded Imperial system, there is always a problem if you are using pounds for mass and force.
Likes 1 person
ok. But assume i have the base made of glass which can withstand only 395 kg of weight So if i fill the tube (with base of 200cm2) to a height of 10 metres. As u had explained the capacity will be 200 litres fresh water, if it's a vertical tube. Then, when the water reaches 10 metres height will the pressure be enough to break the glass?. i.e will 2 bar pressure acting on 200 cm2 be enough to break the glass?
Thanks for the reply. But can u explain further regarding "If the sides were sloping either way than the contributions of pressure on the sides would need to be added in (or subtracted)."
i.e the instances where weight would be higher than pressure or vice versa, when sopes are slanting either way. A link to any material will be very useful. thank you.
Presumably you mean it can only withstand 395kg distributed uniformly over the 200cm^2 area of the base? or do you mean a 395kg point load in the middle of the base?
If it will withstand only 395kg distributed uniformly then clearly it will fail if you apply 400kg distributed uniformly.
If it will withstand a 395kg point load then it might or might not withstand 400kg distributed. Point loads are generally worse than distributed loads.
i.e the instances where weight would be higher than pressure or vice versa, when slopes are slanting either way. A link to any material will be very useful. thank you.
I thought that might get you going! :wink:
What I meant was that the pressure on any surface will be ρgh, at any point of the surface where the depth is h. If the container is a truncated conical funnel shape (a frustum, point down), the downward force on the cone sides near the water surface will be less than near the bottom but will still add to the force at the bottom. Likewise, with the funned inverted, there will be a downward force over all the bottom (plane) surface but pressure acting upwards on the inverted sloping surface will cause an upwards force, subtracting from the total force acting on the flat bottom. This sort of argument will apply to all shapes container - always giving you the weight force as the same for the same mass of water.
The point is that the 'weight' has contributions from any non-vertical surface.
Weight cannot be 'higher or lower' than pressure because they are two different quantities in two different units. The force on the bottom (pressure times area) can obviously be different from the weight, which is the sum of all vertical forces.
1. What is the equation for calculating underwater pressure in terms of weight?
The equation for calculating underwater pressure is P = ρgh, where P is pressure, ρ is density, g is acceleration due to gravity, and h is depth. This equation can be used to equate underwater pressure with weight after converting the units.
2. How do you convert units when equating underwater pressure with weight?
To convert units, you must first determine the units of measurement for pressure and weight. Pressure is typically measured in Pascals or PSI, while weight is measured in Newtons or pounds. You can then use conversion factors to convert between these units. For example, 1 Pascal is equal to 1 Newton per square meter.
3. Can underwater pressure and weight be equated in all situations?
No, underwater pressure and weight cannot be equated in all situations. This equation assumes that the density of the fluid is constant, which may not be the case in certain situations. Additionally, the equation does not take into account external factors such as currents or objects moving through the water.
4. How does depth affect the equivalence between underwater pressure and weight?
The deeper an object is submerged in water, the greater the pressure it experiences. This means that as depth increases, the equivalence between underwater pressure and weight also increases. This is because depth is a component of the equation for pressure (ρgh), and as h increases, so does pressure.
5. Is the equation for underwater pressure the same as the equation for air pressure?
No, the equations for underwater pressure and air pressure are different. For air pressure, the equation is P = ρgh, where P is pressure, ρ is density, g is acceleration due to gravity, and h is height. The main difference is that for air pressure, height is used instead of depth. Additionally, the density of air is much lower than the density of water, resulting in different values for pressure.
  • Mechanics
12K
  • Classical Physics
  • General Discussion
  • Mechanical Engineering
  • Mechanics
12K
