Absolute Value Equations: Setting Restrictions
In summary, the conversation was about solving absolute value equations and finding restrictions for valid solutions. The first equation was not an absolute value equation and could be solved by combining like terms. For the second equation, the variable x was split into cases based on its value in relation to -1/2 and -1/3. Solutions were found for each case and checked against the given restrictions.
vertciel
63
Hello everyone,
For the following absolute value equations, I have no trouble solving them and finding the valid [tex] x [/tex] solutions by plugging all the x solutions into the original equation.
However, I am just wondering if could someone please show me how to set restrictions for the following equations? I want to know how to solve these equations in two ways instead of just one.
Thank you very much.
1. [tex] | 2|x + 3| - 5 | = 7 [/tex]
2. [tex] | x - | 2x + 1 || = 3 [/tex]
Mathematics news on Phys.org
The first one isn't an "absolute value" equation at all since the variable, x, does not appear in the absolute vaues: |2|= 2 and |-5|= -5 so that equation is just 2x+ 15= 7.
For the second one, |2x+ 1| "changes" when 2x+ 1= 0 or x= -1/2. Now separate it into cases:
If x< -1/2, then 2x+ 1< 0 so |2x+1|= -(2x+1)= -2x-1. Your equation is now |x+ 2x+ 1|= |3x+1|= 3. |3x+1| "changes" when 3x+ 1= 0 or x= -1/3. Since -1/3< -1/2, x< -1/2 immediately gives x< -1/3 so we have -(3x-1)= -3x-1= 3. Solve that equation. If the solution is less than -1/2, that is a solution to the original problem. If not, this gives no solution.
If x>= -1/2, then 2x+ 1>= 0 so |2x+1|= 2x+ 1. Your equation is now |x- 2x- 1|= |-3x-1|= 3. |-3x-1| "changes" when -3x- 1= 0 or x= -1/3. Now we have two possibilities: -1/2<= x< -1/3 or -1/3<= x.
If -1/2<= x< -1/3, then |-3x-1|= -(-3x-1)= 3x+ 1 and the equation becomes 3x+ 1= 3. Solve that for x and check if the answer is between -1/2 and -1/3. If it is, that is a solution to the original equation, if not, this gives no solution.
Finally, if x>= -1/3 then |-3x-1|= -3x-1 and the equation become -3x-1= 3. Solve that for x and check if the answer is >= -1/3.
halls i think you misinterpreted the first equation, it's a little ambiguous. he probably meant |2(|x+3|)-5|.
What is an absolute value equation?
An absolute value equation is an equation that contains the absolute value of a variable. The absolute value of a number is its distance from 0 on a number line. For example, the absolute value of -5 is 5 because it is 5 units away from 0.
How do you solve absolute value equations?
To solve an absolute value equation, you must first isolate the absolute value expression on one side of the equation. Then, you can set up two separate equations, one with a positive value inside the absolute value and one with a negative value inside the absolute value. Solve each equation separately to find the possible solutions.
Why do you need to set restrictions when solving absolute value equations?
Setting restrictions is necessary when solving absolute value equations because the absolute value function can produce two possible solutions for each equation. However, not all solutions may be valid for the given equation. Therefore, setting restrictions helps to narrow down the possible solutions and ensure that only the valid solutions are considered.
What are some common restrictions when solving absolute value equations?
Some common restrictions when solving absolute value equations include restrictions on the variable such as "x is greater than 0" or "x is less than or equal to 5". These restrictions can also be in the form of inequalities, such as "x is greater than 2" or "x is less than or equal to -3".
How can you check if your solutions satisfy the restrictions in an absolute value equation?
To check if your solutions satisfy the restrictions in an absolute value equation, you can simply plug in the solutions into the original equation and see if they make the equation true. If the solution does not make the equation true, then it does not satisfy the restrictions and is not a valid solution.
  • General Math
  • General Math
  • General Math
  • General Math
