- #71
GENIERE
Skyhunter said:I am greatly concerned for the survival of modern society, if we do not alter our current consumption practices.
The former depends on the later; you need to increase the scope of your analysis.
We are getting off topic.GENIERE said:The former depends on the later; you need to increase the scope of your analysis.
Solar is not electric. I have a solar powered water heating machine on the roof, which consists of a tank and plastic, coated tubes. It's common in the Chinese countryside and it's one of the reasons why China consumes but a fraction of Amercian energy consumption and Chinese still look clean.russ_watters said:I don't think there are any alternatives that are viable. That's why I asked: What is the alternative? It wasn't a rhetorical question, I am really asking you what you think the alternatives are.
You mentioned "solar and electric" - well solar is electric, but if you mean direct solar power and battery power, do you understand that neither is currently capable of coming anywhere close to the performance of gas/diesel powered cars? And at the same time as they give you much, much less performance, they also cost much, much more.
Also, I'm not sure what you mean by "government milking us" - are you talking about gas taxes?
How many Watts of enlightment?Skyhunter said:We are getting off topic.
I should have said enlightened society. Modern society is infected with consumerism, but it has many institutions that aid individuals on their path to enlightenment. I would like to see more enlightenment and less consumerism.
Depends on location and sofort, but average 10 % of the potential energy from a crude is indeed wasted to produce fuels. Biofuels may help us a bit but are no long term solution. All of us should have read "Visions" of our beloved Dr. Kaku. To be able to survive as a species we have to go to a next level of energy which is indeed only achievable the nuclear way. Fuse me baby!GENIERE said:QUOTE=edward]Does anyone have a link on how much energy is consumed to produce a gallon of gasoline? I think it would be quite high. If the crude is pumped in Saudi Arabia then transported to a U.S. refinery, then pumped through pipe lines to tank farms, then trucked to your local gas station where the final bit of energy is used to pump it into your tank.
Refineries use electricity, most probably generated by fossil fuels, even coal. The coal has to be mined and shipped to the power plant. All of the stages of transportation and processing use fossil fuels.
Gees no wonder we have pollution.:yuck:[ /QUOTE]
I believe about 10% of the crude is required to obtain the gasoline distillate. Heating oil and diesel fuel require less. The later are more efficiently made but produce more particular pollutants when used. I don’t know about the losses incurred in transport, maybe Mercator will comment.
The efficiencies of producing alcohol from grain or biomass may, at least according to some researchers, be negative. Proponents may say otherwise. I don’t know enough to comment. It is a lot less efficient than gasoline production but may have other benefits to consider.
Every direction I’ve explored has always lead me to the nuclear option.
I believe about 10% of the crude is required to obtain the gasoline distillate. Heating oil and diesel fuel require less. The later are more efficiently made but produce more particular pollutants when used. I don’t know about the losses incurred in transport, maybe Mercator will comment.GENIERE said:QUOTE=edward]Does anyone have a link on how much energy is consumed to produce a gallon of gasoline? I think it would be quite high. If the crude is pumped in Saudi Arabia then transported to a U.S. refinery, then pumped through pipe lines to tank farms, then trucked to your local gas station where the final bit of energy is used to pump it into your tank.
Townsend said:I guess I should specify that I wouldn't tax diesel fuel as much since it is much more efficient than gasoline.
At first, it would be hard for to people to get used to driving smaller more efficient vehicles but they would get use to it and the economy would bounce back.
