Does getting which-way info introduce a phase difference?
In summary, the conversation discusses the effects of obtaining "which-way" information on the state of particles and their coherence. It is suggested that obtaining this information can cause a phase difference or de-coherence between the particles, but erasing the information can restore coherence. The concept is further explained using the example of slits and the behavior of entangled photons in two-photon interference experiments. It is also clarified that "which-way" information typically refers to experiments involving a single photon, so there is no entanglement.
San K
911
does getting which-way info introduce a phase difference (or cause de-coherence) between both the "waves"?
and does erasure of which-way information restore coherence?
a difference from what?
the 'which-way' information completely changes the state, like the slits be 1 and 2, then you have 1+2 without any information, then 1 OR 2 with information
you can't phase change your way between (1+2),(1),(2)
forgot to mention, sorry...
phase difference between two entangled photons (two-photon interference)
Which way information usually referes to dual-slit type experiments, there's only one photon there at anyone time so there is no enganglement.
Related to Does getting which-way info introduce a phase difference?
1. What is the "which-way" information and how does it relate to phase difference?
The "which-way" information refers to the path or trajectory that a particle takes in a quantum system. In quantum mechanics, the act of observing this information can introduce a phase difference, which is a change in the amplitude or energy of the wave function of the particle.
2. How does obtaining "which-way" information affect the behavior of a quantum system?
Obtaining "which-way" information can cause a collapse of the wave function, leading to a loss of interference and a change in the behavior of the system. This is known as the "observer effect" in quantum mechanics.
3. Can obtaining "which-way" information be done without introducing a phase difference?
No, according to the Heisenberg uncertainty principle, it is impossible to simultaneously know both the position and momentum of a particle. Therefore, obtaining "which-way" information will always introduce a phase difference in a quantum system.
4. Are there any experiments that demonstrate the effect of obtaining "which-way" information on phase difference?
Yes, the double-slit experiment is a classic example that demonstrates the effect of obtaining "which-way" information on phase difference. When the path of the particle is known, the interference pattern disappears, indicating a phase difference has been introduced.
5. How does the presence of an observer affect the introduction of phase difference when obtaining "which-way" information?
The presence of an observer is not necessary for the introduction of phase difference when obtaining "which-way" information. Even if the path of the particle is not directly observed, any interaction or measurement of the system will introduce a phase difference due to the uncertainty principle.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
