Transition from frictionless surface to frictional surface
In summary: Yes exactly.Suppose we can stretch our hands and bodies enough such as to always hold together with our hands lying exactly over the boundary. We can exert a force to each other such that the net force i am applying to you is upwards +F, and (due 3rd law of Newton ) the net force you are applying to me will be downwards -F. Assuming all that the normal force (from the frictionless surface) on the left portion where you standing will be B1-F, while that on the right portion (from the frictional surface) will be B2+F, where B1.B2 the weight of the left and right portions.
Nathanael
1,650
246
Suppose you have an object sliding along a frictionless floor, but it's approaching a line where the floor changes from being frictionless to some constant coefficient of kinetic friction [itex]\mu_k[/itex]
When it is partially on the frictionless surface and partially on the frictional surface, would you calculate the frictional force by multiplying [itex]\mu_k[/itex] by the entire weight of the object? Or would you only multiply it by the portion of the weight that is above the frictional surface?
I think you would just multiply [itex]\mu_k[/itex] by the portion of the weight of the object that is above the frictional surface, but my textbook says nothing about this sort of situation.
(My question also applies to the transition between one surface to another when the two surfaces have a different [itex]\mu_k[/itex])
The weight on the frictional surface; the rest of the weight is on the frictionless surface.
I think there is an extreme case where this doesn't hold, if the left portion of the body exerts somehow a net force on the right portion of the body that has a vertical component (parallel to the weight).
I don't quite understand what you're describing. (Rather, I don't understand how this could occur.)
Can you perhaps think of an example?
Lets say you are attached to the left portion of the body and i am attached to the right portion.
Oh, I see. So even though there is an amount of weight above the frictional surface, it's possible that the weight is somehow supported by the side over the frictionless surface. (I didn't misinterpret you, right?)
Good point, I didn't think of that unique possibility.
Yes exactly.
This scenario does not work due to conservation of angular momentum. The upward force from you amounts to a torque on your partner. The downward force from your partner amounts to a torque on you. Once you trace it all out, there is no interaction you can do to cause an unbalanced force on the object (as long as you stand still and do not start rotating in place at an ever-increasing rate).
Unfortunately, Nathanael's supposition about the distribution of support force still does not hold for all objects. It will pretty clearly work for rugs being dragged across a floor by a horizontal force. The distribution of the support force matches the distribution of the rug's weight. But it fails for tables and chairs. The distribution of support force does not match the distribution of a table's weight. The support force will shift abruptly from one side of the line to the other as each leg crosses the line, not slowly as the table's weight crosses the line.
What conservation of angular momentum you talking about, there are the external normal forces from the surfaces and the weights which are also external forces to the system.
Indeed, the effect might even be enough for the table to tip over.
Diagram may help (It's not intended to be a FBD).
With friction acting below the centre of mass there will be a weight transfer onto the part on the surface that has friction.
Even for flat bottomed rigid objects on uniform surfaces it's not clear what happens when there is uneven weight distribution. My guess is the coefficient of friction itself changes.
Consider a system consisting of you and your partner. Consider an axis of rotation going through your combined center of mass. What forces are present?
There is the force of gravity. But that has no net torque about your center of mass.
There is the interaction between the two of you. But that is internal to the system and cannot change your net angular momentum.
There is the support force of the object holding the two of you up. The point of the exercise was to apply unbalanced forces to the object. It follows that the object is applying unbalanced forces to the two of you. That's a net torque.
Where is the resulting change in your angular momentum?
Nathanael said:
I think you would just multiply [itex]\mu_k[/itex] by the portion of the weight of the object that is above the frictional surface.
That is right as a general principle, but as others have said the hard part is dividing the weight between the two parts of the surface.
If the center of mass of the object is above the surface, when the object is decelerating there is more weight on the front of the object than on the back. It is easier to work out the details if the object touches the ground at a few separate points rather than over an area (e.g. a table, a bike or car, etc).
As an extreme example, think about a tall block of material, or a human sliding on ice. When it hits the friction surface, it might even topple over, rather than continue sliding.
Textbooks don't mention "real world" situations like this, because modelling them "accurately" is complicated, often requires computer simulations rather than algebra and calculus, and is not a very effective way to learn the basic principles.
You seem to have forgotten to include the torque of the friction force itself
The "friction force itself" would apply between the object and the floor. It does not apply to the system in question -- the two people standing on top and trying to apply an unbalanced external force.
I agree that you are correct in suggesting that there may be a lateral force between the people standing on top of the object and the object itself. If the object is slowing down and the people are standing in place relative to it, there is certainly some such lateral force. Unless their center of gravity is at their feet, that lateral force will produce an external torque on the system composed of the two people.
The key point that I was trying to make was that no internal interaction between the two people on the platform can change their angular momentum. If they are to produce a net external torque, they need to do something other than "I'll push up on your right hand if you push down on my left".
I think that point is made more clearly if one disregards the acceleration of the object. But perhaps I should have stipulated people of negligible height instead.
I was assuming something like a puck; you can imagine what will happen for various situations by considering that object freely sliding on ice, then, suddenly encountering a patch that has sand scattered on it.
The ice skater would probably topple, the table maybe flip over, and the puck (depending on weight, etc) would probably just slow down, then come to a stop.
In the case of the puck it would feel less total force when the edge of the puck encounters the sand, and the total resistive force would increase as the puck makes the transition.
Something similar happens with a toboggan that runs out of snow and hits a patch of grass; if the patch is small, you just feel a jerk. If the patch is bigger, you get thrown forward, and maybe off.
This is my experience from growing up in the frozen north, and spending quality time outdoors during the winter.
I said that the human bodies are attached to the left and right portions respectively which means that they can't move or rotate unless the respective portions do so also. Essentially they become extensions of those portions.
If they are extensions of the object, any forces they exert on each other cannot induce any net torque on the object.
Yes the net torque is zero cause we have to equal and opposite forces at the same points where the hands are meeting.
Right. But recall the point of the exercise. You want the fellow on the right to be pushing down on the object harder than the fellow on the left. That is, by itself, a non-zero net torque. And that cannot happen.
Try looking at it this way. The down force on the left hand on the fellow on the right amounts to a counter-clockwise torque on him. [Looking at him from the back]. The up force on the right hand on the fellow on the left also amounts to a counter-clockwise torque on him.
You have said that neither fellow starts moving. They stand in place on the object. Let us ignore for the moment any linear acceleration of the object. That means that there must be a counter-balancing torque on each fellow. That torque must come from their feet. The left hand fellow stands more heavily on his left foot than on his right. The right hand fellow stands more heavily on his left foot than on his right.
So while it remains true that the right hand fellow is standing more heavily then the left hand fellow, both their left hand feet are standing more heavily than their right. The net effect is zero.
Well you continue to view the human bodies as separable from the left and right portions of the main body. I would rather treat one human body and its respective portion as one rigid body(left and right segment). Still you are kinda right that there seems to be torque from the left segment to the right segment and vice versa. My assumption is that this torque is canceled by the external torque of the normal forces and the friction.
The fact that you prefer to analyze a situation one way does not negate an analysis that proceeds in a different fashion. The notion of "cancelling" the torques produced by an internal force pair with the torques produced by external forces does not make sense to me. The torques from all of the internal forces within a system will add to a grand total of zero regardless. There is nothing left to "cancel".
Ok so you telling me that the net torque the left segment applies to the right (or the right to left) is always zero. Can u prove that the net force the left segment applies to the right is also zero?
I can prove that the net torque of all objects inside a system (closed or otherwise) on one another adds to zero. That was the claim.
Start by choosing a reference point about which torques will be computed. The point is arbitrary, any point will do. By Newton's third law, all the forces occur in pairs. The pair members are equal and opposite. The torque associated with each force is the vector cross product of the force and its displacement of its point of application from the chosen reference point. For contact forces, the displacement of the points of application of the third law force pair will be identical. So the resulting torques will be equal and opposite. They will add to zero. Non-contact forces will be directed along a line going between the points where they act. The torque produced by each of the partner forces is determined by the perpendicular displacement from the reference point to this line. The two cross products will again be equal and opposite. The torques will add to zero.
Since all of the torques add to zero pairwise and since Newton's third law guarantees that this accounts for all torques, we have the result.
1. What is friction and how does it affect motion?
Friction is a force that opposes motion between two surfaces in contact. It is caused by the microscopic irregularities on the surfaces that interact and resist the motion. Friction can either slow down or stop motion.
2. How does the transition from a frictionless surface to a frictional surface impact the movement of an object?
The transition from a frictionless surface to a frictional surface can significantly impact the movement of an object. When an object moves from a frictionless surface to a frictional surface, the force of friction will act on the object, causing it to slow down or come to a stop.
3. What factors influence the amount of friction between two surfaces?
The amount of friction between two surfaces depends on several factors, including the nature of the surfaces, the force pressing the surfaces together, and the roughness of the surfaces. The type of motion (sliding, rolling, or fluid) also plays a role in determining the amount of friction.
4. How can the transition from a frictionless surface to a frictional surface be beneficial in certain situations?
The transition from a frictionless surface to a frictional surface can be beneficial in situations where we want to control or slow down the movement of an object. For example, it is necessary for vehicles to have frictional tires to maintain control and stop when needed.
5. How can we reduce the effects of friction on an object?
There are several ways to reduce the effects of friction on an object. One method is by using lubricants such as oil or grease to reduce the contact between the surfaces. Another way is by using materials with smoother surfaces or by using rolling instead of sliding motion. In some cases, applying a force in the opposite direction of the motion can counteract the force of friction.
  • Mechanics
  • Mechanics
