Panama canal: why don't the two sides level out?
  • Thread starter twain
In summary, water flowing between the Pacific and Atlantic oceans would equalize the levels if there was no ocean current. The locks on the Panama Canal are necessary because the canal climbs over the hills and makes use of mountain lakes.
twain
36
The sea level is different from one side of the Panama canal to the other. The pacific side is 20 cm higher.
Why don't the levels equalize by water flowing around south america?
Because of the locks. They only let enough water flow in/out to raise/lower the ship inside each lock. In such a way, they do not allow for a continuous flow of water between the two oceans but only small intervals of water.
If there would not be any ocean currents at all then indeed it would not be possible for any level difference to exist, since by nature water forms a level surface.
I suppose that the 20 cm difference arises because of prevailing ocean currents. Presumably at each side of the Panama canal the ocean currents come out in such a way that difference in level arises.
Shouldn't the levels fluctuate seasonally if they were due to ocean currents?
By the way Born2bwire the locks are to carry ships over a mountainous area that is higher than both oceans, and also I asked why doesn't water go all around south america to equalize.
I think the major ocean currents are pretty consistent all throught the seasons.
The driving force is that around the equator the water is heated more than at higher latitudes. That differential heating tends to cause a circulation where surface water flows away from the equator, and deep water flowing back. The Earth's rotation tends to redirect that flow (coriolis effect), and geographic features also tend to redirect.
In all the ocean currents are determined more by geographic features than by seasonal features.
The Pacific Ocean is 20cm higher than the Atlantic. Not just through the canal.
This answers your question perfectly:
http://www.psmsl.org/train_and_info/faqs/#3
3. Is sea level of the Atlantic and Pacific oceans the same?
If so why are locks required in Panama?
Sea level is about 20 cm higher on the Pacific side than the Atlantic due to the water being less dense on average on the Pacific side and due to the prevailing weather and ocean conditions. Such sea level differences are common across many short sections of land dividing ocean basins.
The 20 cm difference business is determined by geodetic levelling from one side to the other. A datum called Panama Canal Datum is used. When you use spirit levelling you follow a 'level' surface (to our perceptions, see 1) which will be parallel to the geoid (which is geometrically a 'lumpy' surface). The geoid is the surface of constant gravitational potential (plus a 'centrifugal potential' term) which on average coincides with the sea surface i.e. a 'level' surface in everyday language. The 20 cm difference at Panama is not unique. There are similar 'jumps' elsewhere e.g. Skagerrak, Indonesian straits.
If the canal was open sea and not locks (i.e. if somehow a deep open cutting had been made rather than the canal system over the mountains) then there WOULD be a current flowing from Pacific to Atlantic. An analogy (although not a perfect one because there are many other factors) is that you could compare Panama to the Drake Passage off the south tip of Chile which has a west-east flow (but mostly wind-driven of course, but Pacific-Atlantic density must play some role).
Locks are needed in the Panama Canal because the canal climbs over the hills and makes use of mountain lakes. Therefore, locks would be needed even if sea level was the same on the two sides. (So, for example, there are also locks on canals here in England which is much less mountainous than Panama).
Note also that the tides have opposite phase on the 2 sides of Panama, so, if there was a sea level canal, there would be major tidal currents through it.
Likes njnbutterfly
So if we go to a long lake and disolve a lot of salt on one side of the lake, the opposite side will rise?
If you dissolve a lot of salt the densities change so you'd expect some variation.
Also re-read what is in the link relating to gravity.
Let me propose another setup.
Let there be two lakes, close to each other but not connected. Let the two lakes have the same level, and the same depth. Dissolve a lot of salt in one of the lakes, then establish a conduit between the bottoms of the two lakes (say, a water filled pipe.)
With that setup I expect that water will move through the conduit from the higher density lake to the lower density lake. The equilibrium point will be the point where the pressures at the two sides of the conduit are equalized.
So I think it's a case of communicating vessels, with a bias due to the density difference.
Shouldn't the two densities have equalized by now? It's been billions of years.
Only if there were no changes (no salt added or removed, weather and currents etc). But unfortunately, nature isn't that simple.
Maybe because there are more rivers flowing to the atlantic than to the pacific, per cubic foot of sea water?
What?
Are you not reading what's been posted above?
I gave you the exact reasons why the Pacific is higher than the Atlantic. There's really no more to it.
You said changes prevent density equalization and therefore cause the difference in level. But changes happen on both sides. Currents too flow on both sides and seem completely unconnected. Are you yourself satisfied that currents cause one side to be heavier?
What are you talking about? Stop making things up.
Please read my initial post in this thread. I quoted you an entire section of a site explaining exactly why the ocean levels are different.
I have never said the differing levels prevent density equalisation. Ever.
EDIT: Your edit noted.
Look at your #11 post:
- Shouldn't the two densities have equalized by now? It's been billions of years.
- Only if there were no changes.
What did you mean then, if not that changes lead to no equalization of density?
RE. Bolded: That is exactly what I meant, but that isn't what you wrote.
The salt levels would only have equalised if there was no further input / removal of salt, among other things. This is not how nature works.
Again, I have never said the different levels prevents the salt level equalising.
There are changes in nature, salt is constantly added and removed alongside other factors that prevent the levels equalising.
Please read the link I provided, it explains it perfectly well.
I don't know if there's a language barrier here or not, but you aren't reading what I write correctly. As such, you are posting what amounts to non-sense based on what I've never said.
Good. You mean that changes lead to no equalization of density and you agree that no equalization of density leads to differing levels, correct?
In other words, A leads to B and B leads to C, does it not follow that A leads to C? In other words, that changes lead to differing levels? You do not say it word for word, but you say the equivalent.
But since there is further input / removal of salt, one has to be denser, which is like saying
"if you input food to two childen, one will be fatter".
Well I suggested that one child seems to be fed more food. One ocean receives more salt. Where from? More rivers.
I have read it since the first time you gave it, and copy-pasted it. It does not account for a difference in density. It does not answer why SALT does not diffuse around south america to equalize densities.
You proposed that salt content does not equalize because, word for word, "only if there were no changes (no salt added or removed, weather and currents etc) [would the densities have equalized]. Well consider that salt is added to both sides, weather is similar on both sides, and only currents are perhaps one-sided in a salt-obstructing effect. But currents go in closed paths don't they? How can they obstruct diffusion?
Rivers are fresh water, so how would the ocean get salt from them?
You proposed that salt content does not equalize because, word for word, "only if there were no changes (no salt added or removed, weather and currents etc) [would the densities have equalized]. Well consider that salt is added to both sides, weather is similarly varying on both sides, and only currents are perhaps one-sided in their salt-obstructing effect. But currents go in closed paths don't they?
You enjoy closed systems don't you. I've read your other threads and it's a general theme.
Currents aren't "closed paths".
It is the continual processes occurring in both oceans, along with other factors (gravitational variation), that prevent them from equalising.
Good, then that is a strong indicator that salts should distribute themselves worldwide, is it not?
They do distribute themselves. But because of the processes going on, it prevents them balancing out.
What the processes are I'm not entirely sure, but the fact they haven't balanced out tells you they are there and a bit of research will explain to you.
What exactly are you trying to get at by saying they haven't distributed themselves and not accepting there is a process(es) preventing it?
That there is a better explanation, that one ocean is fed with more salt. Mystery processes that conspire to produce observed result, or a simple explanation? Remember Occam's razor.
I've never said they are "mystery processes", only that I don't know what they are.
Scientists have the explanation, you just need to look.
Here is a page on the very subject:
http://eesc.columbia.edu/courses/ees/climate/lectures/saltyatlantic.html
It explains why the Atlantic is so salty.
Rivers contain more salt than the water that leaves the ocean via evaporation so the net effect is an increase in salinity.
EDIT: OK, that page is ok and the references appear to check out.
The rest of the site is a different matter. As such, I'm removing the link and subsequent part of my original post.
If you only consider those two processes, certainly.
twain said:
You have access to online papers by any chance? I was hoping to get this one also:
http://arxiv.org/abs/0903.4603v1
I don't see how that is relevant to the discussion.
No, I don't have access to papers.
Your posts are all heavily focussed on religious matters (or arguments I should say). Are you trying to prove or disprove them?
That is a false accusation and therefore an insult and a provocation. Forum rules do not allow such behaviour.
I wasn't accusing you of anything. I simply asked if you were working towards a final goal regarding religion. It was a simple "is this a religious based question or not?". If you are not a simple "no" would have sufficed.
There is no insult and no provocation.
There is nothing in the rules about me questioning your motives.
I only asked because your threads have flagged up religious debates surrounding those exact issues relating to creationism when I did some legwork (as others in your evolution thread brought up and is mentioned in the paper you linked to above).
  • #31
Related to Panama canal: why don't the two sides level out?
1. Why were the two sides of the Panama Canal not leveled out?
The two sides of the Panama Canal were not leveled out because of the difference in elevation between the Atlantic and Pacific Oceans. The Atlantic side is about 20 feet higher than the Pacific side, making it impossible to create a level canal without extensive excavation and construction.
2. How did engineers overcome the elevation difference in building the Panama Canal?
Engineers used a system of locks to raise and lower ships between the two sides of the canal. The locks act as water elevators, using gravity and water flow to move ships up and down the different levels of the canal.
3. What was the purpose of building the Panama Canal at its current location?
The Panama Canal was built at its current location because it is the narrowest point of the Central American isthmus, making it the most feasible location for a canal. Additionally, the location provides a natural waterway between the Atlantic and Pacific Oceans, making it an ideal spot for international trade and transportation.
4. How long did it take to build the Panama Canal?
The Panama Canal took approximately 10 years to build, from 1904 to 1914. However, the French had previously attempted to build a canal in the same location in the late 1800s, but were unsuccessful due to various challenges such as disease and engineering difficulties.
5. How has the Panama Canal impacted global trade?
The Panama Canal has greatly impacted global trade by providing a shortcut for ships traveling between the Atlantic and Pacific Oceans. This has reduced travel time and costs for international trade, making it a crucial route for the transportation of goods and resources. It has also increased the economic importance of countries in the region, such as Panama and other Central American countries.
  • Earth Sciences
  • Earth Sciences
  • General Discussion
  • Earth Sciences
  • Earth Sciences
