Do two magnets separated by a distance have potential energy relative
In summary, two magnets separated by a distance do have potential energy relative to each other. This potential energy is a result of the magnetic force between the two magnets, which is strongest when they are close together and decreases as the distance between them increases. The potential energy can be converted into kinetic energy if the magnets are allowed to move towards or away from each other. This concept is important in understanding the behavior of magnets and their interactions with other objects.
jaredvert
61
To each other? Repondez!
You should be able to figure that out - what is the definition of potential energy?
Kkkkkkk
Ok so here is something I don't understand. I've had electricity and magnetism course but I never learned of any such thingn. Why not?
You'll have to ask the people who taught the courses.
What level was the course taught at?
Is this stuff told of later on?
I suspect you will already have learned the law of conservation of energy, and the definition of potential energy.
Your course on magnetism should also have taught you about magnetic forces. If those bits are there, you should have been able to figure it out.
Yes but I know of no equation for potential energy between magnets.
... that does not answer the question I asked: what is the definition of potential energy?
You should have learned that the potential energy of a system is the amount of work needed to get it into that configuration.
You should have equations for the force between two magnets, and an equation for work, and so on.
The course may not have covered magnetic potential energy because the fundamentals had already been taught. After all, how much time will you have for the exam?
What level was the course taught at?I suspect you will already have learned the law of conservation of energy, and the definition of potential energy.
Unfortunately I am not sure how to calculate the force between two magnets, only between mag fields and wires
It's similar - permanent magnets are more complicated than bits of wire.
You are learning the situations for simple geometries so the maths is easier.
i.e. if you have two bar magnets length L which are separated by a distance D>>L, then you can use the magnetic dipole equation.
http://en.wikipedia.org/wiki/Force_between_magnets
But you can easily tell that there must be a "magnetic potential energy" because you have to do work to push two like poles close to each other. You can get two magnets and measure it.
Yeah I mean I was sure there was a pot energy between them but I didn't know the force between them so I couldn't calculate the pot energy between them. Are these equations created empirically?
Also I've read the whole giancoli physics based on calc 3 and I've never run into forces between permanent magnets.
That is usually the easiest way to do it in practice - but you can make approximations for simple geometries.
People who make magnets for a living need to be able to predict how strong-a magnet they'll get from a particular process.
I think this is a college level field of materials engineering.
You wouldn't - even though you have probably handled permanent magnets as part of practical demonstrations. At that level, and well into college, permanent magnets are mostly treated qualitatively.
You should have had a little bit on how permanent magnets work, at least in terms of "magnetic domains". There should also be a bit of maths about a magnetic dipole field ... this is the field due to a very small current loop. You can see the analogy between that and the field due to a permanent magnet.
1. Does the distance between two magnets affect their potential energy?
Yes, the potential energy between two magnets is inversely proportional to the distance between them. As the distance increases, the potential energy decreases.
2. How does the strength of the magnets affect their potential energy?
The strength of the magnets does not directly affect their potential energy. However, stronger magnets may have a greater force of attraction or repulsion, which can affect the potential energy between them.
3. Can two magnets with the same polarity have potential energy?
Yes, two magnets with the same polarity can still have potential energy. This is because they will repel each other, and this repulsive force creates potential energy between them.
4. Is potential energy the same as kinetic energy in magnets?
No, potential energy and kinetic energy are two different forms of energy. Potential energy is the energy an object has due to its position or configuration, while kinetic energy is the energy an object has due to its motion.
5. How can the potential energy between two magnets be calculated?
The potential energy between two magnets can be calculated using the formula U = -G(m1m2)/r, where U is the potential energy, G is the gravitational constant, m1 and m2 are the masses of the two magnets, and r is the distance between them. This formula is similar to the formula for calculating potential energy between two masses in the gravitational field.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
15K
