How pipes in parralel works in comparison to pipes in series
In summary, the conversation discusses the comparison of pipes in parallel and in series, and the calculation of pressure drop across four parallel pipes. It also mentions the similarities between pipes and resistors in a circuit, and the use of Kirchoff laws to solve for flow rates in a network. The conversation also touches on the topic of boiling and how it occurs.
bajaj_383
can anybody focus something on how pipes in parallel will work in comparison to the same pipes in series.i want to calculate pressure drop across 4 parallel pipes emerging from a tank & entering inside the other tank . pipes of sam dia,& same length.
thnks
Just like resistors in a circuit in parallel or series.
This is the same post in a thread on pipe flow (flow in elbows and pipes) in the Mechanical & Aerospace Forum.
As Russ alluded to:
In order to solve for the flow rates in all of the network paths, a series of simultaneous equations must be developed that include every pipeline in the network. The Kirchoff laws form the basis for the development of the equations used to balance the flow in the network and are listed below:
Starts on page 15 of the PipeFlo pdf file provided by Q_Goest.
how does boiling takes place
to find the reason behind the boliling of soln.
1. How do pipes in parallel and pipes in series differ in terms of flow rate?
When pipes are connected in parallel, the flow rate is divided among the pipes, resulting in a higher overall flow rate compared to pipes in series, where the flow rate remains the same throughout the pipes.
2. Which configuration, parallel or series, is more efficient for water flow?
Pipes in parallel are more efficient for water flow because the total flow rate is higher, allowing for faster and more efficient distribution of water.
3. Do pipes in parallel and pipes in series experience different amounts of pressure?
Yes, pipes in parallel experience a decrease in pressure due to the division of flow among the pipes, while pipes in series experience an increase in pressure as the flow remains constant throughout.
4. How do pipes in parallel and pipes in series differ in terms of maintenance?
Pipes in parallel require more maintenance as each individual pipe must be checked and maintained separately, while pipes in series only require maintenance on one main line.
5. Which configuration, parallel or series, is more cost-effective?
This depends on the specific situation and needs. Pipes in parallel may require more materials and maintenance, but they can provide a higher flow rate. Pipes in series may be more cost-effective for simpler systems with lower flow rate requirements.
  • Classical Physics
  • Mechanical Engineering
20K
