How Can I Use Distance Sensors to Locate Footsteps in Gait Analysis?
  • Thread starter Frederick84
  • Tags
    Method
In summary: Actually, the only reason that I didn't mention optical sensing is because I considered it to be two-dimensional v/s the 3 that Frederick seems to need. Multi-angle vision would cover that nicely, as long as the inputs remain properly co-ordinated. Good call.Gait analysis is often carried out using pressure sensing panels or footplates. One system I've used before is made by Tekscan.
Frederick84
Hi,
I am working on a project to collect data on walking gait of patient, ie stoke patient. I need solution to locate the position of the patient's feet and the distance apart by using just distance sensor.
any one got good idea ??
How precise, complex are you looking for? Would something as simple as dipping their feet in ink and having them walk on paper work?
Cause, I am planning to place a distance sensor on the foot, then use them to meaure the distance, however it can't locate the position.
As i need the data to be transfer via RS232 to MATLAB to generate the results, therefore I can't use the method you suggested.
Thank for the input.
Perhaps it would be useful to contact an optical effects company such as Industrial Light and Magic. A lot of CGI characters are based upon motion studies of live actors. I think that most of those are accomplished using laser scanning, but the first efforts involved sensors such as magnetic, radar, acoustic, and simple radio transmitters. A professional in the business might be able to give you some really great insights.
My personal approach, being an uneducated amateur, would probably be to use an RF transmitter with triangulating receivers.
I like Danger's ILM idea. You can use the video pickup technique, which is very well developed. Put little white marker balls on parts of the feet and legs, and use a video camera to film the patiet's gait on a treadmill. You can film from both sides if bilateral data are important.
Alternatively, a very basic system of digital image correlation using two cameras could be carried out as suggested above. Have a marker on both shoes/feet, make sure your two cameras (mounted at an angle of ~20deg to each other or so) can both see the marker clearly, then track the motion of the marker between synchronised frames. DIC does this with many many markers, and in a stereoscopic configuration of cameras can give you three dimensional position data.
1. How does the "Method to Locate Footstep" work?
The "Method to Locate Footstep" is a scientific technique used to determine the location of a person based on the sound of their footsteps. It utilizes acoustic principles to analyze the frequency and intensity of the footsteps and compares it to a database of known footstep sounds to determine the approximate location of the person.
2. What equipment is needed for the "Method to Locate Footstep"?
The "Method to Locate Footstep" requires a microphone or other audio recording device, a computer or other device for sound analysis, and a database of known footstep sounds. The equipment used may vary depending on the specific method and technology being used.
3. Can the "Method to Locate Footstep" be used in all environments?
The "Method to Locate Footstep" can be used in most environments as long as there is a clear and distinguishable sound of footsteps. However, certain factors such as background noise, terrain, and weather conditions can affect the accuracy of the method.
4. Is the "Method to Locate Footstep" reliable for locating multiple individuals?
The "Method to Locate Footstep" can be used to locate multiple individuals in a given area as long as their footsteps can be differentiated and the database contains their specific footstep sounds. However, the accuracy may be affected if there are multiple people walking in close proximity or if their footsteps sound similar.
5. How accurate is the "Method to Locate Footstep"?
The accuracy of the "Method to Locate Footstep" can vary depending on the specific method and technology being used, as well as external factors such as background noise, terrain, and weather conditions. In controlled environments, the method can have a high level of accuracy, but in real-world situations, it may not always be 100% accurate.
  • Materials and Chemical Engineering
  • General Engineering
  • Quantum Interpretations and Foundations
  • STEM Educators and Teaching
  • Electrical Engineering
