LTE SIMO signal to noise ratio
In summary, the homework Equations states that the SNR of z is SNR_z=\frac{|(\alpha h_1+\beta h_2)t|^2}{E[|\alpha n_1+\beta n_2|^2]}=\frac{|(k h_1+h_2)t|^2}{|k|^2 \sigma_1^2+\sigma_2^2}, where SNR_z varies from SNR_x to SNR_y as |k| varies between infinity and 0.
madmike159
Base station transmits signal t which is received by two antennas such that:
x = h1t + n1
y = h2t + n2
where n1 and n2 are independent additive white Gaussian noise with variances σ21 and σ22 respectively.
h1 is the channel gain between the base station and receive antenna 1 and h2 is the gain between the base station and receive antenna 2.
The receive terminal combines the signals x and y as follows:
z = αx + βy
Find the optimal values of α and β.
What is the resulting SNR of z? How does this compare to the SNR of x and y?
The only hint given was that k = α/β and that
SNRz = f(k)
I have tried finding the power of each signal since the variance is the power of the noise, and then trying to find a ratio of α/β to give a constant which should allow α and β to be adjusted to find the optimal values.
However I haven't come to a solution that actually expresses SNR of z, x or y. Some of the calculations I have made are lengthy and don't arrive at a solution, but I could upload them if you wish.
Any help or pointers would be greatly appreciated.
The SNR of x is [tex]SNR_x=\frac{E[|h_1 t|^2]}{E[|n_1|^2]}.[/tex] With that hint, you can find the SNR of y and z. Divide SNR_z through by alpha to express it in terms of k.
Note that the noise cross term in the denominator is zero (do you see why?). Differentiate SNR_z with respect to partial k and set to zero. That's the approach to solving the problem.
The hard part is evaluating the partial derivatives, especially if the signals, noise and k are complex. Do you know if you are dealing with real or complex quantities?
I am not sure if it will be complex or not. My original post contains all the information we were given. I will have a go at finding the SNR of y and z and post my results here.
I have spoken to my lecturer and he said that the power of the received can be assumed to be constant, so the expectation can be omitted.
So I assume we would get
SNRz = α ( h1t / σ21) + β ( h2t / σ22)
Then would it simply be a case of changing values of α and β to ensure the signal with the best SNR is chosen ( i.e z = 2x + 0.1y)?
No, not quite. First you have written the voltage SNR, but usually SNR is a power quantity (and using it is a must if your variables are complex). Second, the signal part of z is (αh_1 + βh_2)t, while the noise is αn_1 + βn_2. The power SNR is therefore [tex]SNR_z=\frac{|(\alpha h_1+\beta h_2)t|^2}{E[|\alpha n_1+\beta n_2|^2]}=\frac{|(k h_1+h_2)t|^2}{|k|^2 \sigma_1^2+\sigma_2^2}.[/tex] SNR_z varies from SNR_x to SNR_y as |k| varies between infinity and 0.
Edit: Added expectation to denominator.
So to find the optimal value, I would differentiate with respect to k?
Yes, paying attention to the complex nature of your quantities (i.e., |k|^2=k k*).
I would have thought that |k|2 would = k2
Since |k| = (k2)1/2
Ok, if you aren't familiar with complex variables just treat everything as real.
I understand that |k|^2=k k* if k is complex. I just tried differentiating SNR_z but ended up with a very long function (from the quotient rule), which didn't appear to simplify. I will try again with complex values.
Don't give up. It does simplify.
Is with our without complex values, or does it not matter?
That sentence doesn't make sense! Do it with reals, it's hard enough that way. If you are careful with your terms, when you simplify you'll have a famous result that has been used widely in wireless comms.
You do use the quotient rule to differentiate? I just tried again and got a very long answer where only one small part cancels out, certainly not something I recognize as a famous result.
Yes.
I worked it last night and got the expected result.
Ok, well clearly I am going wrong somewhere or missing something important. I have a load of other questions to do for this assignment so once I have those done I will have another go at it.
Thanks
Ok. At that time you can post your work and we find your error.
Yea sure, I will try right it out on here, its pretty long and messy though (a clear sign I have gone wrong).
I have just directly differentiated the top line and bottom line with respect to k, using the quotient rule (assuming that |k|2 = k2).
This is what I got:
http://gyazo.com/c5301f7e5c8f23d85622e1d2fbc9bb82
(I can never get the math input working on here)
I can't access sites like that through the firewall at work so I can't see your work. But why are you integrating? Differentiate w.r.t. k and set to zero! (Do you understand why you should be doing that?)
That was a typo, no idea why I put integrating, I did mean differentiating.
I believe that setting the differential to 0 would allow the minimum point to be found (that is the point where the noise is lowest/SNR is the highest)
Good, you had me really worried!
I take it what I did was still wrong though. Any pointers on what I am doing wrong?
Well your start is good but you have only just started. In fact, you don't even have an equation, just the right side of an expression. Keep going! Make an equation by setting your expression to zero. Don't forget to add the missing "t" to the first term.
Multiply through by the ()^2 denominator term, expand, collect terms and simplify to get a quadratic equation in k. Solve for k. Expand terms again, and simplify to get the answer.
Ok thanks. When you say the missing t term, should there be a t on the top of the left fraction?
Probably, I can't remember your attachment exactly. You should be able to figure it out.
1. What is LTE SIMO signal to noise ratio?
The LTE SIMO signal to noise ratio (SNR) is a measure of the quality of the signal received by a device in a wireless communication system. It is the ratio of the signal power to the noise power in a given channel and is typically expressed in decibels (dB).
2. How is LTE SIMO SNR calculated?
The LTE SIMO SNR is calculated by dividing the received signal power by the noise power. The received signal power can be measured at the receiver, while the noise power can be estimated by measuring the noise floor or by using a noise figure provided by the system.
3. What is the ideal LTE SIMO SNR?
The ideal LTE SIMO SNR is typically considered to be around 20 dB. This means that the signal power is 100 times higher than the noise power, resulting in a strong and clear signal for the receiver.
4. How does LTE SIMO SNR affect signal quality?
The LTE SIMO SNR directly impacts the signal quality in a wireless communication system. A higher SNR means a stronger and clearer signal, resulting in better overall signal quality and a more reliable connection. A lower SNR can lead to signal loss, dropped calls, and slower data speeds.
5. How can LTE SIMO SNR be improved?
There are several ways to improve LTE SIMO SNR. These include using directional antennas, reducing interference from other devices, and increasing the transmit power of the sender. Additionally, implementing advanced signal processing techniques and using error correction codes can also help improve SNR and overall signal quality.
  • General Engineering
10K
  • General Discussion
  • STEM Academic Advising
