Is Rotational Kinetic Energy Analogous to Work in Torque Analysis?
In summary, the rotational kinetic energy of a rigid body is equivalent to the work done by the resultant force.
DaTario
1,039
35
Hi all,
If we take the integral of tau (the resultant torque) times the angular displacement theta, with respect to the angular variable theta, are we to expect the result to correspond to the variation in rotational kinetic energy?
Is is this the case, does this integral have any particular name (analogous to work) ? "WORQUE" :)
Thank you
DaTario
Yes.
It's just called work.
It is also called work? But it reffers to different physical manifestation. Considering for example a disk rolling down an incline. The variation in kinetic energy is dou to the work done by the resutant force while the variation in rotational kinetic energy is produced by this "worque" ...
best wishes
DaTario
Realize that integrating torque over an angle is equivalent to integrating force over a distance. Both give a change in kinetic energy and can be called work. It requires work to increase translational KE and it requires work to increase rotational KE.
Ok, I know both energies are energies, but the numerical results in each calculation are not the same.
But if you are saying that both expressions are called work, it is ok to me.
In a certain way I was expecting something like rotational work or something like that.
Thank you
Best wishes
DaTario
Just to add to Doc Al's comment...
recall that a rigid body is a many-particle system.
The grouping of certain terms into a "rotational" part is just for convenience.
I like the name "WORQUE", I think I'll start using it instead.
My boss is from NY, he tells me to get to "worque" all the time! :rofl:
Should that be New Yorque?
I guess I understand this part.
I am a little bit confused, as in the case of a disk rolling down an incline 1/2 * M V^2 is the kinetic energy of the CM while 1/2* I Omega^2 is related to the rotational motion.
As robphy indicated, the real deal is that each piece of the rigid body--each tiny element of mass--is moving with some speed. So each mass element has some KE. Add them all up, and that's the total KE.
It's just easier to take advantage of the fact that it's a rigid body and separate out a component of kinetic energy associated with the translational motion of the center of mass and a component associated with rotation motion about the center of mass. But that sum is equal to what you'd get if you just added the KE of each mass element.
Very nicely said. But now comes my question: the work of the resultant is the net variation of the CM component of the total KE.
Will the integral of Tau (resultant torque) with respect to Theta (angular displacement) correspond to the net variation of the rotational component of the total KE ?
best wishes
DaTario
Can't you do the maths for once, DaTario?
For a point on a rigid body, acted upon by an external force [itex]\vec{f}[/tex], with distance [itex]\vec{r}[/itex] from the mass centre, with velocity [tex]\vec{v}=\vec{v}_{C.M}+\vec{\omega}\times\vec{r}[/tex] its contribution to the power of the rigis body is:
[tex]\vec{f}\cdot\vec{v}=\vec{f}\cdot\vec{v}_{C.M}+\vec{f}\cdot(\vec{\omega}\times\vec{r})=\vec{f}\cdot\vec{v}_{C.M}+(\vec{r}\times\vec{f})\cdot\vec{\omega}[/tex].
See if you can glean the result from this.
I am not asking you to make calculations. You misinterpreted me. I am asking if someone has this complementary information about the work-energy theorem.
If it is clear to you I would be pleased to know if the integral of Tau (resultant torque) with respect to Theta (angular displacement) corresponds to the net variation of the rotational component of the total KE?
Could you explain what is the purpose of this forum, if it isn't for people to interact, to exchange information and to debate?
That is your main mistake.
Which is given by..the calculations.
I just gave you the information, I'm not into hand-wavy airiness, neither should you, if you actually want to learn some physics, which is the main point of this forum.
This is something you should be able to answer yourself. Take a simple, two-dimensional case, so you don't have to worry about vectors. Write down an equation relating the torque and angular displacement to the force, velocity and linear displacement of each small part of the object. Use this to set up two integrals, one for [itex]F dr[/itex], and one for [itex]\tau d\theta[/itex]. Check whether the results are equal.
Yes, if by work you mean [itex]\int \vec{F}_{net} \cdot d\vec{r}_{cm}[/itex].
Yes, as long as the torque is taken with respect to the center of mass.
Doc Al, Thanks.
Ben Niehoff, welcome and thanks.
Aridno, you have talents.
best wishes
DaTario
(Groan) You are both dorques. Actually, I liked both, but now put a corque in it.
1. What is torque and how is it related to work?
Torque is a measure of the force that causes an object to rotate around an axis or pivot point. In the analogy of work, torque represents the effort or force applied to a lever to lift an object. Just as work is done when a force is applied to move an object over a distance, torque is produced when a force is applied to rotate an object.
2. How does the length of a lever affect torque in the work analogy?
The length of a lever in the work analogy represents the distance from the pivot point to where the force is applied. The longer the lever, the more torque can be produced with the same amount of force. This is because the longer lever allows for a greater distance for the force to act on the object, resulting in a greater torque.
3. What is the role of the fulcrum in the work analogy with torque?
The fulcrum in the work analogy represents the pivot point or axis around which the object rotates. In order to produce torque, the fulcrum must be fixed and immovable. This is because the fulcrum acts as the point of resistance to the applied force, allowing for the rotation of the object.
4. How does the amount of force applied affect torque in the work analogy?
The amount of force applied in the work analogy is directly proportional to the amount of torque produced. This means that the greater the force applied, the greater the torque produced. However, the direction of the force also plays a role in determining the direction of the torque.
5. Is there an equation that relates torque and work in the work analogy?
Yes, the equation for torque is T = F x d, where T is torque, F is the applied force, and d is the distance from the pivot point to where the force is applied. This equation can also be written as W = F x d, where W is work. This shows that torque and work are closely related, with torque being a specific type of work that involves rotational motion.
  • Mechanics
  • Mechanics
  • Classical Physics
