Exploring the Time Constraints of Black Hole Mergers
In summary, the conversation discusses the time it takes for black holes to merge and the concept of event horizons. It is explained that for an external observer, the merger of two black holes would appear to happen in finite time, with all matter still outside the merged event horizon. The concept of different frames of reference is also mentioned.
Mordred
2,090
106
THe universe is around 14 billion years matter falling into the singularity appear to take infinite time. So how would two black holes have had the time to complete a merger under those conditions? According to my understanding of GR we should be able to see mergers still in progress as the time reference at the event horizon and at the singularlity with itas infinite density would give us the apearance of infinite time taken which is well beyond the age of the Universe. Would the event horizon simply shift in size and encompass both singularities essentailly entailing two separate singularities inside one event horizon? If I recall Hawking radiation this process also takes a long time to reduce a large Black hole to nothing. So even if all the matter was pulled away from the smaller black hole to the larger, The smaller black hole would still not have had enough time to reduce to nothing. or am I correct in that last statement?
An outside observer never sees matter cross the the event horizon. However, the event horizon itself responds approaching matter. As two collapsed stars with event horizon approach, their horizons merge in finite time for an external observer, with all matter of both stars still outside the merged event horizon.
Interestingly, if a planet approaches an event horizon, the horizon grows well before the planet reaches the horizon. The current event horizon reflects (in part) all matter that will eventually be trapped.
side note was looking for examples of mergers when I found this article printed yesterday.
http://www.space.com/12790-monster-black-hole-cannibal-galaxy-collisions.html
I've also watched the Nasa simulation of black hole mergers done in 2010 I'll link a post of it.
its neat how the gravity waves are shown in this.
Thanks for your reply makes more sense now
The universe is around 14 billion years matter falling into the singularity appear to take infinite time.
And yet if you are falling with that matter, all takes place in "normal" (local) time.
Among the things Einstein brought to science is the understanding that there is no single "correct" frame of reference, all frames (observers) are "relative"...There is no universally correct observational frame...So what you see is likely different from what a distant observer sees.
Yeah I knew the part regarding normal time if your falling into the singularity, I was more interested in what we would see with the time dilation when we look at it from Earth.
PAllen said:
...As two collapsed stars with event horizon approach, their horizons merge in finite time for an external observer, with all matter of both stars still outside the merged event horizon.
Interesting. But what you call an event horizon is not an event horizon, but the potential event horizon should the entire matter of each star be within the horizon boundary.
No, it really is the event horizon. The event horizon is defined against a total 4-manifold. It necessarily reflects the complete future history. The definition is the surface from which no light will escape to infinity. Imagine a light wave or photon so nearly trapped (assuming no more matter falls in) that it takes a thousand years to escape far from the event horizon. Now, assume in 800 years a baseball approaches the event horizon. This can be enough so the light never escapes. Without the baseball, this light would be just outside the event horizon. However, because a baseball will fall in 800 years from now, it is actually inside the event horizon.
I was also speaking of observers well outside the event horizon, so, as I said, no matter is ever seen to cross the growing event horizon.
I don't know what "800 years from now" means without reference to a coordinate chart.
I am referring, of course, to the 'egocentric coordinate system' (Fermi-Normal coordinates based on my world line).
Make a silly quibble, get a silly answer.
(Apologies to Sydney Coleman for use of egocentric frames).
Sorry if you think it's quibbling.
I don't think it is though. I take it that Fermi normal coordinates are those of a feely falling observer.
I believe I could define some coordinate system in which there are no event horizons forming, even aysmtotically. Then again, the event horizon is an artifact of Schwarzschild metric and not the Fermi metric. So we are talking about the coordinate singularity in one metric using the coordinates of another.
I said several times already that I was speaking of observers distant from the horizon. Given that, it does not matter what coordinate system is used for the statements I made (as long as time is interpreted to be proper time, and the observer stays distant from the horizon and does not have extreme motion, which I thought goes without saying). By Fermi-normal coordinates I do not necessarily refer to a free falling observer. I mean you use a chosen worldline as time axis, and foliate spacetime with spacelike geodesics 4-orthogonal to this world line.
The event horizon singularity is coordinate dependent. The event horizon itself is a geometric feature of the manifold. A given null geodesic either reaches spatial infinity or it does not. This is not coordinate dependent, thus the horizon is not coordinate dependent. Its shape as a 2-surface does dependent on how spacetime is foliated into spacelike hypersurfaces, but you can't get rid of it or change anything substantive about its properties.
(I really thought you were just being pedantic, rather than didn't understand or disagreed with what I was saying).
1. What are black hole mergers?
Black hole mergers occur when two or more black holes come together and combine into a single, larger black hole. This phenomenon is predicted by the theory of general relativity.
2. How do black hole mergers affect the surrounding space-time?
Black hole mergers cause ripples in space-time known as gravitational waves. These waves can be detected and studied, providing valuable insights into the nature of black holes and the universe.
3. What are the time constraints for black hole mergers?
The time constraints for black hole mergers vary depending on the size and distance of the black holes involved. In general, the process can take anywhere from a few seconds to several billion years.
4. How do scientists study the time constraints of black hole mergers?
Scientists use advanced computer simulations and data from gravitational wave detectors, such as LIGO and Virgo, to study the time constraints of black hole mergers. These tools allow them to model and observe the dynamics of these events.
5. What can we learn from exploring the time constraints of black hole mergers?
Studying the time constraints of black hole mergers can help us better understand the behavior of black holes, the properties of space-time, and the evolution of the universe. It can also provide valuable insights into the nature of gravity and the validity of general relativity.
