If the inventory of the reactor of about 20,000kg
  • Thread starter matt222
  • Tags
    Reactor
In summary: I am sorry, I am really confused because I cant understand the concept.As you know that for 2H2O we have 4kmol H2, so for 1H2O we have 2kmol H2 2kmol H2=2x2kg/kmol=4kg so 4kg or 2kmol H2 produce 124m^3 so 2kmol H2 produce 62m^3 is this wrong?Yes. You are missing the fact that you have 20,000kg of Zr, which is not going to be completely reacted with water - that's why you have to use 10% (or whatever percent) in your calculations
matt222
132
If the inventory of the reactor of about 20,000kg of Zr given the reaction:
Zr+2H2O---> ZrO2+2H2, Q=616MJ/Kg-mole of Zr
1- find the 10% of the heat generated from Zr oxidation by steam in MJ
2- Find the 10% hydrogen generated from Zr oxidation by steam in kg and the volume fraction (given initial pressure 1 bar and volume 90,000m^3, treat hydrogen as an ideal gas.
3- what is the energy released from the combustion of H generated and what will be the power if it is released within 10s, assumption is the amount of Oxygen is enough to burn the total H generated, heat of combustion is 240MJ/Kg-mol
4- what will be the pressure increased by the H generation from 10% oxidation given initial pressure 1 bar and volume 90,000m^3, treat hydrogen as an ideal gas, ignorw the T rise.
1- it is simple :
molar mass for Zr is 91.22 kg/kmole
10%x 20000kgx 616/91.22 =13.5x10^3 MJ
2- it is by: 2kg/kmol of 2H, so 2x13.5x10^3/(616)=43.8kg
I didnt understand the second part of volume fraction?
3- energy release from the combustion of H:
H2+1/2O2---->H2O+ 240MJ/Kgmol
240x43.8=10.51x10^3MJ
the power is going to be:
10.51x10^3MJ/10=10.51x10^2MW
4-I have no idea but I need a hint
is my work true
I guess they mean volume fraction in the mixture after the reaction - it still contains remaining water AND produced hydrogen. However, it is not clear to me what is the temperature. Perhaps just 100°C, as that's enough for water to be a steam at 1 bar.
Convert between mass/moles and volume using ideal gas equation, nothing more fancy.
so PV=nRT, so in this case 90,000m^3 going to be the total volume right?
n=2kg/kmol for hydrogen once we find the volume of hydrogen just divide it by the total volume of 90,000m^3 is it right?
the T=100c you are right
Yes.
Note that this case is specific - total number of moles of gas doesn't change (one mole of H2O is replaced with one mole of H2 - this is in the stoichiometric coefficients). It doesn't have to be true, which may add an additional step to calculations.
so the is going to be V of hydrogen=8.32x10^3x373x2/1x10^5=31m^3
which is very small!
volume fraction=31/90,000=3.45x10^-4!
What do you think
There is in general something wrong with your numbers.
Why do you mix 616 (which is enthalpy change) with masses, when calculating stoichiometry?
oops yes you are right its mistake it should be 13.5x10^3/616=21.9kg>>what about now?
No, it shouldn't be. You can't calculate mass produced using enthalpy change (which would be obvious if you were paying attention to the units). You start with masses, you end with masses. This is a simple stoichiometry.
I confused really because this is not my background field!
can you refer me to a wiki link for understanding more because I really lost
91.1kg/kmol for Zr...2kg/kmol of 2H
10%x20,000kg of Zr...Y
in this case Y is the required mass for this problem! which is equal to 43.91kg! almost the same as what Igot before!
No, it is still wrong. 2 kg is a correct mass of a kilomole of hydrogen, but you are not producing 1 kilomole of hydrogen (H2) per kilomole of Zr.
91.1kg/kmol for Zr...4kg/kmol of 2H
87.82kg what about now? this is what i understand from the link? really almost will be crazy from chemistry lol
can you give me example to understand this problem please
matt222 said:
4kg/kmol of 2H
Not 4kg/kmol of 2H but 2 times 2kg/kmol of H2. Think what each 2 in 2H2 means.
That's the correct mass of hydrogen which is a first part of the answer. Not you have to convert it to the volume.
so the is going to be V of hydrogen=8.32x10^3x373x4/1x10^5=124m^3
volume fraction=124/90,000=1.38x10^-3! what about this one?
Units please - I am not going to guess what you are doing.
I think you are wrong, but without knowing what each number represents I can't be sure.
so the is going to be V of hydrogen=8.31 x10^3(pa m^3/kmolK)x373 (K) x4 (Kmol)/1x10^5(pa)=124m^3
this is after showing the units!
Why 4 kmols? Is that amount of hydrogen produced?
sorry i mixed up it should be 2kmol which is the number of hydrogen mol
so the is going to be V of hydrogen=8.31 x10^3(pa m^3/kmolK)x373 (K) x2 (Kmol)/1x10^5(pa)=61m^3
volume fraction=62/90,000=6.89x10^-4!
I think you will be happy right
No, you are not producing 2 kmols of hydrogen. You took both numbers - 4 kmols and 2 kmols - from the stoichiometric equation, ignoring mass of Zr present. Following this line of thinking amount of hydrogen produced will not depend on the amount of Zr and it will be always 2 (or 4) kmols (even if there is no zirconium present). That's wrong - that's not what stoichiometric coefficients say.
Note that you have already earlier calculated (correctly!) amount of hydrogen produced using stoichiometry - you just calculated its mass, not number of moles. Now either convert this mass to moles or - better - use similar approach to calculate number of moles of hydrogen produced. THEN put this number of moles of hydrogen into ideal gas equation.
1 : : 2
0.5 : : x
x=1
so the is going to be V of hydrogen=8.31 x10^3(pa m^3/kmolK)x373 (K) x1 (Kmol)/1x10^5(pa)=31m^3
volume fraction=31/90,000=3.44x10^-4
what about now
You don't have 1 Zr (in whatever units), you have 20,000 kg of Zr.
Please reread the section on "how to read balanced reaction equation" from the lectures. You are right about the ratio, but you are all the time doing the same mistake - you are treating stoichiometric coefficients as if they were amounts of substance. THEY ARE NOT.
1 mole of Zr: : 2 mole of 2H2
1 mole : : x
x=2
so the is going to be V of hydrogen=8.31 x10^3(pa m^3/kmolK)x373 (K) x2 (Kmol)/1x10^5(pa)=62m^3
sorry but i am not professional on these kind of material this is my first time in my life to do this!
Sorry, all I can do is to repeat - you don't have 1 moles of Zr, you have 20,000 kg of Zr.
How many moles (or kmoles) is 20,000 kg of Zr? That will be the number that will be the basis of your calculations:
1 mole of Zr : 2 mole of 2H2 - this is ratio given by the stoichiometric coefficients
number of moles of Zr in 20,000 kg : x moles of H2 produced - substances in your reaction must be in the same ratio
1 mole of Zr=91.2kg/mol, so total for one 1 of Zr we have= 10%x20,000/91.2=21.93mol total moles
21.93mol : x moles of H2 produced
x=43.86moles total
V of hydrogen=8.31 x10^3(pa m^3/kmolK)x373 (K)x 43.86/1x10^5(pa)=1359.5m^3
Omitting units and making two errors you managed to get the correct answer, as your errors canceled:
Should be 21.93 kmol, as molar mass of Zr is 92.1g (not kg) per mole.
x=43.86moles total
You started with kmoles, so you should get 43,86 kmol
You didn't write 43.86 of what - you wrote moles above, would you put moles here, you would be off by the factor of 1000. Accidentally equation expects you to put kmoles, as these are units of the R (ideal gas constant) in the version you used. That was the second error - and it put you back on track.
1 mole of Zr=91.2g/mol, so total for one 1 of Zr we have= 10%x20,000/91.2=21.93kmol total moles
21.93kmol : x moles of H2 produced
x=43.86 kmoles total
V of hydrogen=8.31 x10^3(pa m^3/kmolK)x373 (K)x 43.86 kmoles/1x10^5(pa)=1359.5m^3
what about the final new look
Much better, although you are still doing tricks (perhaps you are not even aware you are doing them):
OK
No idea what it means "one 1 of Zr".
You are again mixing units - getting correct result. I am not convinced you know what you are doing, I have a feeling result is correct accidentally.
20,000 of what? 91.2 of what?
  • #31
20,000kg and 91.2 kg/kmol
  • #32
If so - that's OK. Note that you wrote a line earlier "1 mole of Zr=91.2g/mol", so it wasn't clear what you use.
  • #33
what about part 3 of the question is ok?
for part 4 I got the idea now:
PV=nRT
P=nRT/V=(43.86 kmoles x 8.31x10^3 (m^3pa/kmol k) x 373K)/90,000m^3=1511pa
so the pressure increased is going to be 1.015bar!
what do you think?
  • #34
Change in pressure is a function of change of number of moles of gas.
What gases are present? How does their amount change?
  • #35
the gases are hydrogen and air and the question asked me to treat it as ideal gases!
ΔPV=ΔnRT, but how could we get the change of n since no information given for the air!
their amount will be changed due to pressure increase or decreased
  • Mechanical Engineering
9K
12K
