Gravitational pull at the center of the Earth
In summary: Gravity.In summary, the shell theorem is a well-proven theory that states the gravitational force decreases as you approach the center of a sphere.
Secant
First, I'm not a physicist. But I do think of the subject often. A simple observation, as you move away from Earth the gravitational pull decreases. OK let's say we can drill a hole through the center of the Earth what is the gravitational pull as we reach the middle? Is your answer fact, theory, or accepted theory. I add this part, because I grow tired of answers being set forth as fact and not accepted theory. Therefore if it is fact, has it been proven? That is, given that we have drilled a few holes in the Earth more than a mile or so. And I admit I being somewhat silly here, has anyone drop something in it that proves what you are saying.
you drill a hole ,and drop it, you will know if its fact or theory
Secant said:
First, I'm not a physicist. But I do think of the subject often. A simple observation, as you move away from Earth the gravitational pull decreases. OK let's say we can drill a hole through the center of the Earth what is the gravitational pull as we reach the middle?Is your answer fact, theory, or accepted theory. I add this part, because I grow tired of answers being set forth as fact and not accepted theory. Therefore if it is fact, has it been proven?That is, given that we have drilled a few holes in the Earth more than a mile or so. And I admit I being somewhat silly here, has anyone drop something in it that proves what you are saying.
Fact, theory, accepted theory..Oh my :eek: http://galileo.phys.virginia.edu/classes/152.mf1i.spring02/GravField.htm (Towards the bottom. Field Inside a Spherical Shell)
Ranger,
Great web reference. Monty37 not so great reply. But no one has answered the proof part of my question. Has anyone proven that the formula mentioned are correct for inside a sphere. Yes the formula are well proven for outside and on the surface of a sphere. But we are talking INSIDE. So has anyone demonstrated that gravity in affect decreases as you approach the center due to the opposing forces of mass.
No, nobody has even drilled a hole to the center of the earth.
If you mean in a small sphere here on the center of the earth, maybe, but the gravitational force of that small sphere is so tiny that it is most probably not measurable.
On the other hand, if you got an insulating charged sphere, you will see that the electric field in that sphere shows the exact same behavior. I think it's safe to say that anyone has tested that experimentally, although I've never heard of it...
I must say, if you don't believe the spherical shell theorem then you must be very skeptical... It follows logically that you think gravity as Newton explained it is completely false (not only a tiny bit false, as it is, but completely). I very much doubt that you actually think that, so why do you want experimental proof of this?
Here's a similar question:
How much will a 10kg sack of potatoes weigh on the Moon?
No one has ever brought a sack of potatoes to the Moon, let alone weighed it there.
However, I can say with confidence that the answer will be 16.3N.
Is that answer based on fact or on theory?
We have not actualy drilled a hole to the centre of the Earth and dropped a rock down there, but the physics is well understood.
The problem you are encountering in my opinion is that it is the type of question that laypeople think they can answer intuitively - except that the answer is non-intuitive. It merely requires a better understanding of the physics than most laypeople have.
Nick89, good answer. DaveC42.. not so good. There is nothing wrong in asking for proof. A simple example, when Neal Armstrong walked on the moon he dropped a feather and a hammer they both fell at the same rate as was predicted, but my point is up to that point in time no one had actually PROVED the formula in a simple/straightforward way.
Nick it's not that I don't believe in the theorem. But you said it yourself it is a THEOREM, not fact. So does anyone know if someone has done a "Neal Armstrong" here on this theorem.
Because I'm about to take this 'conversation' to a whole new level.
It is fact actually. The shell theorem is derived using only Newton's laws for gravitation. If the shell theorem is false, either Newton was completely wrong, or maths is completely wrong. Due to the fact that Newton's theory of gravitation works extremely well (at low speeds), in other, tested, cases, we can establish that the shell theorem must be true. If it's not true, Newton's laws would not be true, and we could not have experimentally tested any other law that relies on Newton's laws.
But that does not make it fact.
But he did not drop a sack of potatoes. We extrapolate based on known physics. Of course, I am using a silly example.
Nevermind. I see your point. You want to see experimental evidence of the general formula; it doesn't have to be a specific case of 'all the way to the centre of the Earth'.
That's right DaveC... Since we have drilled a few holes more than a mile deep. I'm thinking (definitely simplistically) if we dropped some instrument down the hole would it prove this theorem. Or as Nick mentioned have what we have drilled not deep enough to 'prove' this.
You guys ready to take this to the next level. Because this is the question I raised to myself that took me here to begin with. What formed the planet. I have read bits and pieces on this subject and bottom-line there are definitely a couple of theories, but they both revolve around gravity, and yet both theories admit that gravity unlikely does not have the force to cause the 'clumping' to ultimately form a planet.
So I postulate this idea. What if it is the equivalent of a micro black hole that caused the coalescent of matter to form a planet. The hole large enough to coalesce matter but not so great to collapse it into a greater black hole. Or if you prefer some other entity (worm hole) for example, ie don't get wrapped up on black holes (I'm using that as just one possibility) but some other force at play, be it black, worm, or string. This idea could be elevated if we saw gravity actually increased as we approached the center of the Earth and not decreased. Because I do believe in Newton laws as they relate to spherical objects, I just question as to if there is something else at play as it relates to a planet. Therefore the need of fact vs theory.
I'm not sure what you mean. Are you saying I should have started this thread elsewhere?
Observations must be interpreted using some theory anyway. If you were to do an experiment by drilling a hole of some length into the Earth and measure the strength of gravity as a function of depth, then the results will also depend on the theory that explains how your measurement apparatus works.
In the hypothetical case where gravity works differently so that it is not proportial to M(R)/R^2, most of the physics literature would be flawed which would mean that the scientific measurement devices cannot be trusted. This then means that while you could verify that gravity and the measurement apparatus works according to theory, you cannot really quantitatively detect a large violation of the M(R)/R^2 formula as in that case your measurement device would most likely be flawed as well.
In the sense you are asking for, yes there is. There are in fact many things wrong with what you are asking for.
First off, you are asking for an experiment that in all likelihood can never be performed. Sans a force field that rivals the imagination of science fiction writers, there is no way to send a probe to the center of the Earth. Rejecting the premise that the weight is zero at the center of the Earth implicitly makes an argumentum ad ignorantiam, an appeal to ignorance: That a premise is false because it has not been proven true.
There is no such thing as proof in science. Scientific theories cannot be proven to be true. They can only be proven to be false. Dave C's example was a good one. We do not know, with absolute certainty, how much a 10kg sack of potatoes will weigh on the Moon until someone has done the experiment. Even then, we won't know with absolute certainty whether that sack will have a different weight the next time someone does the experiment.
Science, like the law, does not work on the basis of absolute certainty. Both science and the law work on the basis of reasonable doubt. With this metric, there is no doubt, within reason, what that sack of potatoes will weigh on the Moon (or atop Mt. Everest) without even doing the experiment. The physics and the mathematics are very well understood and there is no reason to think otherwise.
The same goes for the weight of something at the center of the Earth. Assuming that our models of how gravity works are correct, the mathematics (and the underlying math can be proven) says that the weight at the center of the Earth will be zero. One of these assumptions is that the gravitational attraction toward some object is the cumulative gravitational attraction toward the elementary particles that comprise the object. To say that the gravitational attraction at the center of the Earth is non-zero contradicts this basic assumption.
The gravitational attraction at the surface of the Earth is directed inward everywhere on the surface of the Earth. If gravitational attraction is a continuous function, then mathematically there must exist a point somewhere inside the surface at which the gravitational attraction is zero.
Finally, gravity is similar in form to electrostatic force. Gauss' law for gravity and Gauss' law for electrical flux are very similar in form. The latter says that the electric flux through any closed surface is proportional to the enclosed electric charge while the former says the gravitational flux through any closed surface is proportional to the enclosed mass. Gauss' law for electrical flux has been demonstrated and is the underlying reason why you are told to get inside your car in a lightning storm.
You need to read up on the difference between theorems and theories.
DH,
The points you make are quite true and I might add very well thought out. In particular, the one that in most case you can not prove an idea to be true, but rather only prove that it is not. And this is exactly what I'm asking. Has an experiment been performed using the Earth as the sphere that shows the idea not to be true. Of course, ideally, it would prove the idea to be true. And I'm not so naive to think we can drill hole to the center of the Earth. Shoot we can barely scratch the mantle's surface. But perhaps a 2 or 3 mile hole might be enough I simply don't know. The math works for sphere, I'm asking does it work for the sub-surface of the Earth or indeed is the possibility of other forces might also be at work?
And I believe the laws of gravity to be accurate, but if a test was performed sub-surface only to discover that there 'seem to be an issue' then that would open the discussion to 'Well what else is going on down there'.
I might add that Einstein and Tesla both asked themselves why before delving into the math. In both cases believing that the math at the time seem to be true at the time found instances that it was not. They used simple observation of nature as the analogy to formulate their famous theories.
Bottom-line and thinking outside the box. If gravity can not explain why the planet formed is there another force that either acting as the seed to planet formation (with gravity eventually taking over) once enough mass was accumulated or perhaps this force is still there. I asked the gravity question as one avenue to my thinking outside the box. I would love to hear your 'speculation' on how a planet formed if gravity is not the force that initialized the process.
Ok, let's say we DID dig a hole, 2 or 3 miles deep, and verified that the gravitational force is indeed proportional to the radius (and hence, zero at the center). Do you then believe the force is zero at the center? Why would that be any different to what you know now??
Heck, we may have even done that experiment before!
And no, no experiment has been performed that proved the shell theorem wrong. If it were, it would probably be headline news, even in the 'normal newspapers', since that would mean the very foundation of nearly all our understanding of gravity are WRONG.I think I know what you're getting at here... You mean that people in the past have been 'blinded' by what other people had told them was true, like how the Earth was the center of the universe for example. I agree, there were loads of people who simply did not even want to try to disprove that idea, it simply had to be true, because it had always been that way.
The differences with those people, is that they did not have any firm foundation on which their claims were built. The fact that the Earth was supposed to be in the center of the universe was pulled from thin air, just because it is what god had intended.
Our theories of gravity on the other hand, have a firm basis, in maths, and other physics. They are not pulled out of thin air, and they are tested in many many many other cases. Just that we did not test this one tiny detail, does not mean we are ignorant and are simply assuming that it is true.
As others put it, we KNOW, within a certain range, the weight of a cow on the moon, even though we have never actually brought a cow to the moon to verify it.
If it wasn't zero, which direction would it point to, and why?
It will point in the direction away from the tunnel that connects the hole to the surface.
Eerh, actually this proof is illustrated in basically every high school physics class. I believe it's a two or three liner.
Where did you get the idea that gravity is not responsible for planet formation? I see no mention of that in this thread, other than you saying it is so and citing no references.
While it is true that planet formation is not a completely well understood phenomenon, our present theories are the best we have.
Look, any amount of science rests on underlying assumptions. From these assumptions we derive things, and if these things turn out to accurately represent the real world, then the assumptions are strengthened. Asking for proof is okay up to a point, but we cannot individually prove every single special case. After all, that's why we have LAWS, and not a book of statements: #1932432: In Geneva, Switzerland, a hammer dropped from the hand of a man 6'3" tall will fall at a rate of 9.8m/s^2, #1932433:...
You are in essence asking for an extremely expensive experiment with very little payoff. Gravity is an exceptionally weak force. Do you realize how big a hollow sphere would be needed to prove this conjecture correct? A very expensive experiment with little chance of meaningful outcome is not going to be funded. There are many better places to spend the rather limited funding on which science operates.
What forces? We have a pretty good idea of the nature of the forces of nature. There is little reason to think otherwise, and there is little if any reason to think that boring a hole to the center of the Earth will show anything. If there are some unknown forces at play in the universe (as some not-quite-fringe scientists claim), certainly there are better ways to demonstrate this.
Gravity is central to models of planet formation.
That would be quite an extraordinary result. That gravitational force is proportional to radius is a freshman physics oversimplification of the real picture. The freshman physics version assumes the Earth is of a constant density throughout. The real picture is that the rocks that form the Earth's surface and mantle are compressible. The density increases with pressure the deeper you go. Even more importantly, the Earth's composition is anything but uniform. In particular, the Earth's core is iron, which is a whole lot denser than rock.
The real picture is that gravity will decrease slightly with depth and then will increase. The maximum gravitational attraction occurs not at the surface but about 2890 km below the surface at the core-mantle boundary. The Earth's core comprises nearly 1/3 of the Earth's total mass but less than 10% of the Earth's total volume.
Depends what you did with the material removed to build the tunnel. It's not like it's mass vanishes, and the Earth is mostly fluid anyway. But I don't think this is what the OP is interested in. Assuming a point-symmetrical mass, where should the pull be directed to, if it wasn't zero in that point?
Hey guys thanks for the feed back. DH, in particular. DH, first I'm asking if an experiment HAD been done (not proposing one to be done), based on your answer, I'm assuming no this experiment has not been done. So indeed IN THEORY the math should work as applied to the Earth as applied to sphere as a model.
In response to what forces. You answered your own question. "We have a pretty good idea", which translates to "we don't know what we don't know." Which, by the way, is the fun in science. Right? Personally, I reserve the right to leave the door open on other forces that have not been discovered yet.
There's no question that gravity plays a role in planet formation. But everything I have read on the matter ultimately concludes that there is insufficient evidence to suggest that gravity can do it by itself. By the way, I'm not going down the creationist path that I would leave to some other kind of site. I'm asking for "informed speculation" that if gravity is insufficient to alone create a planet. Then what other forces might be in play. I'm putting out there that a micro-black hole acts as the seed to first accumulate matter, however it falls short of a regular block hole of collapsing matter into itself. When I started thinking about this idea, one way to disprove this idea is by asking "In the case of the Earth, has anyone PROVED that gravity decreases as approaching the center". The apparent answer is no one has proved that the case. So therefore, my theory is still plausible.
A favorite professor of mind from 40 years ago taught me "Anything is possible, however, most things are not very probable." I like to concentrate on the possible and leave the probable up to you guys.
Secant said:
DaveC426913 said:
Well, your hypothesis is going to have a tough time explaining the subject of https://www.physicsforums.com/showthread.php?t=322140".
I'm sorry, that was too subtle.
The other thread was talking aobut just how many planets there are out there. Your hypothesis involves a highly exotic mechanisim for planet-formation.
The implcaiton of your hyposthesis is that ALL planets are formed from micro black holes. Which means the universe must be littered with them.
Secant said:
DH,
If gravity can not explain why the planet formed...
This is your hidden question.
you have developed your hypothesis on a flawed premise. Let's vback up and answer this question to your satisfaction and then see if there's anything left over unexplained.
No, I grant his point here. Newton's theory predicts this, but we haver not experimentally observed it yet.
Like it was with black holes, or the lifepsan of relativistically-moving particles. Our theories predicted them but we still had to observe them.
He is simply asking for empirical evidence of Newton's Shell. He is enititled to expect that. And you don;t have to go to the centre. Going a few miles down and taking some very accurate measurments would suffice.
Most laypeople who try to solve this come up with answers like 'you would be crushed or pushed in from all sides' or ' you'd be pulled apart'.
Yes they're wrong, but the point is, asking 'what direction' doesn't lead one directly to the correct answer of 'no direction at all'.
...everything I have read on the matter ultimately concludes that there is insufficient evidence to suggest that gravity can do it by itself...
This is the paradox at the core of this thread. Let's set aside the micro-black hole stuff until the above is addressed. Because if we don't, this thread will certainly be locked. You can count on it.
This is once again an appeal to ignorance. We do have a good idea of how the process starts and how it finishes. Where things get murky is in the middle. Just because we cannot yet explain how planetesimals form does not mean that some unknown force is involved. All that it means is that we cannot yet explain how planetesimals form.
Waiting for 22 posts to put forth your hypothesis does not reflect well upon you at all. The exact opposite is the case. You have a hidden agenda. Exposing your agenda at the onset would have resulted in an immediate lock for violation of this site's rules. Waiting for 22 posts does not change the fact that this hidden agenda violates this site's rules.
Quantum mechanical black holes are themselves hypothetical entities. Why invoke a hypothetical entity to explain something that can be explained without magic? The unknowns with planet formation is not the initial formation of small (meter-sized) objects. It is the conglomeration of those meter sized objects into kilometer sized objects. A better explanation for our lack of understanding of this intermediate process: We do not yet have the computer power to simulate what happens at that stage.
I've read that dust particles get easily electrically charged in the vacuum of space. The particles can then easily stick together kicking off the pre-gravitational phase of the growth of planetessimals.
Hey DaveC and DH. First of all, no hidden agenda's here, but I felt I needed an answer to my gravity question before continuing. You're right that perhaps I should have state my hypothesis at the beginning, but then hindsight is 20/20. I deeply appreciate the lively discussion that we have going.
DH, you are right on the 'intermediate' steps. But I do think it is a bit of a cop out to dismiss something because we don't have the computer power. That is what speculation and brainstorming is for to augment that what we can't not prove using current tools or knowledge.
And don't get too wrapped up with black holes. If you check my earlier statements (post number 11) I stated micro black holes as a possibility to any number of possibilities that might explain what gravity appears not to be able to explain. Perhaps you all would like to speculate on other ideas (aka forces that could cause 'meter' size objects to come together but yet did not take place in some places [ie the asteroid belt])
On a side note, DaveC, I do think (speculate) that the universe it littered with black holes or something akin to a black hole.
We already know why planetesimals did not coalesce to form a planet in the asteroid belt: Jupiter.
Wait. What are we dismissing? Do you mean we're dismissing your hypothesis?
Hypotheses are not simply invented out of whole cloth like daydreams. They start with evidence.
Again, hypotheses are not invented like daydreams.
Your evidence?
It had better be compelling enough to refute the evidence we have already acquired.
  • #31
OK I give up. Apparently thinking outside the box is not allowed here. So for myself I'm bringing this to a close.
On the topic of Jupiter, yes I know that is the accepted theory. But, I was asking to postulate a new theory on planet formation not accepted theory on why we have what we have. And in terms of speculation, think with the new theories that we now have in place (accepted or not), not with theories that were used 30 years ago that helped form the current theory on planet formation.
Recall, Einstein literally woke up one morning with that great Aha moment and 6 weeks later we had a very famous equation. I'm not going to even begin to suggest that would happen here. But I have found in my own field of research, that occasionally throwing out accepted theory can lead (sometimes) to some pretty interesting concepts.
So guys, good bye and fun exploring.
  • #32
Thinking outside box is a tool for certain situations. You are using the wrong tool for the job. You are providing a solution to a non-problem. Thinking outside the box is inappropraite if the answer is inside the box.
And even if there weren't a satisfactory answer for this problem, what you are doing is not simply looking outside the box, you're looking in the next county. Why not look within a few feet of the box before getting on your bike and peddling?
  • #33
Before you can think outside of the box you must know where the sides of the box are. You are not thinking outside of the box, in reality you are simply lost in a dark, dusty corner. When we try to turn on a light, you close your eyes.
  • #34
if you drill a hole to the center of the Earth and out the other side.
you drop your sack of bananas it will drop quickly to the center and pass it, then it will oscillate back to the center and pass it, then oscillate back to the center,...etc. forever
  • #35
Other than the fact that this has nothing to do with the topic...
It would only work if drilled through the polar axis. Anwhere else and your sack of bananas will intersect the wall as the Earth turns.
And then there's the matter of keeping the hole in vacuum.
1. What is the gravitational pull at the center of the Earth?
The gravitational pull at the center of the Earth is approximately 9.8 meters per second squared, which is the same as the acceleration due to gravity at the Earth's surface.
2. Does the gravitational pull at the center of the Earth vary at different depths?
Yes, the gravitational pull at the center of the Earth does vary at different depths. This is due to the varying density of the Earth's layers, which affects the strength of the gravitational force.
3. How does the gravitational pull at the center of the Earth compare to that on the surface?
The gravitational pull at the center of the Earth is much stronger than at the surface. This is because the mass of the Earth above you is canceled out when you are at the center, resulting in a stronger pull towards the center.
4. Can objects float at the center of the Earth due to the gravitational pull?
No, objects cannot float at the center of the Earth due to the gravitational pull. The pull is strong enough to keep all objects towards the center, and there is no buoyant force to counteract it.
5. Is the gravitational pull at the center of the Earth the same as at the center of other planets?
No, the gravitational pull at the center of the Earth is not the same as at the center of other planets. It varies depending on the mass and density of each planet, as well as the distance from the center.
  • Other Physics Topics
  • Astronomy and Astrophysics
  • Classical Physics
