First order perturbation theory, quantum physics
In summary, the conversation discussed calculating the eigenvalues and -functions for a particle in an infinite potential well with length L and no time-dependence. The next task was to find the new eigenvalues and -functions for a perturbed case where a small potential "rectangle" V(x) with length a and height q was added at the center of the well. First order perturbation theory was to be used. It was suggested to properly normalize the eigenfunctions and consider the units of \psi when using the formula for finding the new eigenvalues. The volume element dV was also discussed and its implications for different coordinate systems. Normalizing psi and replacing x^2 dx with just dx was the solution to finding the new eigenvalues.
Antti
27
I have an infinite potential well with length L. The first task was to calculate the eigenvalues and -functions for the energy of a particle in the well. The requirements were
[tex]\psi(0, L) = 0[/tex] and there is no time-dependence.
I've calculated:
[tex]\hat{H}\psi(x) = E\psi(x)[/tex]
[tex]E = \frac{(\pi\hbar n)^{2}}{2 m L^{2}}[/tex]
[tex]\psi(x) = sin(\frac{\pi\n x}{L})[/tex]
Now the question. We add a small potential "rectangle" V(x) at the center of the potential well. It has length a and height q, a << L. What are the new eigenvalues and -functions for the perturbed case? I am supposed to use first order perturbation theory.
I've done like this:
There's a formula saying:
[tex]E_{n_p} = \int \overline{\psi_{n}} H' \psi_{n} dV =[/tex]
[tex]\int \overline{\psi_{n}} H' \psi_{n} x^{2} dx[/tex]
Which gives the new eigenvalues. I tried just using H' = V(x) = q at first. But the dimension of E didn't match. If you substitute V(x) (which is an energy) into the above equation you see that the dimension will be Energy*distance^4 after integration. So what to do with H' ?
Hello,
So, two things:
First make sure that your eigenfunctions are properly normalized, e.g. in one dimension:
[tex]\int \overline{\psi_n}\psi_n\,dx = 1[/tex].
Also, what does this equation imply about the units of [tex]\psi[/tex]? (hint: the dx infinitessimal has units of length)
Second, what is the volume element dV? If we are in one dimension then dV = dx. If we are in cartesian coordinates in 3 dimensions then dV = dxdydz and if we are in spherical coordinates then [tex]dV = r^2drd\theta d\phi[/tex] which appears to be the volume element you are using without the angular terms.
Hope this helps
Thanks! It helped. Normalizing psi and replacing x^2 dx with just dx did the trick :)
1. What is first order perturbation theory in quantum physics?
First order perturbation theory in quantum physics is a mathematical tool used to approximate the energy spectrum and wavefunctions of a quantum system that has been slightly perturbed by an external force or potential. It allows for the calculation of small deviations from the unperturbed system, making it a valuable tool in understanding the behavior of quantum systems.
2. How does first order perturbation theory differ from other perturbation methods?
First order perturbation theory is based on the assumption that the perturbation is small compared to the unperturbed system, and thus only considers the first-order correction to the energy and wavefunction. Other perturbation methods, such as second or higher order perturbation theory, take into account higher-order corrections, but may be more computationally intensive.
3. What are the limitations of first order perturbation theory?
First order perturbation theory is only accurate for small perturbations, and it may not be applicable for large perturbations or for systems with degenerate energy levels. In addition, it assumes that the perturbation is time-independent, and may not be suitable for time-dependent perturbations.
4. How is first order perturbation theory used in practice?
In practice, first order perturbation theory is often used as a starting point for more advanced perturbation methods. It is also commonly used in quantum chemistry to calculate the effects of external fields on the electronic structure of molecules. Additionally, it can be applied to various other systems in quantum physics, such as atoms, nuclei, and condensed matter systems.
5. Can first order perturbation theory be extended to higher orders?
Yes, first order perturbation theory can be extended to higher orders, such as second or third order perturbation theory, which take into account higher-order corrections. However, the accuracy of these higher order methods may depend on the specific system and the strength of the perturbation. In some cases, it may be necessary to use other methods, such as variational or numerical techniques, to obtain more accurate results.
